2136|2
Google Protobuf 库 [复制链接]
MicroPython 1.17+ 的 Google Protobuf 实现
主要特点:
  • KISS 和 ideomatic 代码库
  • 嵌入式代码(包括自动生成的)应尽可能小且快
  • 纯python代码
  • 应该在尽可能多的设备上工作
支持的功能
  • Protobuf 2 syntax
  • Scalar types encoding and decoding with implicit and explicit defaults
  • Nested messages
  • Message type fields
  • Enums without implicit default value
  • Repeated fields (partly implemented)
TODO
  • Protobuf 3 syntax
  • Repeated fields complete and test (including packed)
  • Test message fields
  • OneOf fields
  • Maps
Groups won't be implemented since they are considered depricated. Required fields check is not implemented for now in favour of efficiency.
已测试的硬件
  • PC (Mac)
  • ESP32-wroom
  • ESP8266 (LoLin V3)
import animal_upb2
animal = animal_upb2.Animal()
animal.name = "Dog"
encoded_message = animal.encode()
animal1 = Animal.decode(encoded_message)
游客,如果您要查看本帖隐藏内容请回复
66666厉害   详情 回复 发表于 2022-11-13 01:31
7608
这个好像是第三方序列化接口啥的吧,pbuf 到处能看到应用
默认摸鱼,再摸鱼。2022、9、28
66666厉害
