489|0
65
IPQ4018/IPQ4028 802.11ac Wave2 wifi IPQ4019/IPQ4029 [复制链接]
Featuring with industrial-grade IPQ4018/IPQ4028 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range;
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
   Absolute Maximum Rating
Rating
Supply Voltage
24V~48
Operating Temperature Range
-40 to +60
ºC
Storage Temperature Range
-65 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
   Hardware Specifications
CPU
IPQ4018 (Quad core ARM Cortex A7 at 710 MHz)
Antenna Connector
2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps Gigabit Ethernet
 2xRJ45
SFP connector
1xSFP fiber module connector (optional)
3G/4G connector
1xminipcie 3G/4G connector support with two sim card
USB connector
1xUSB 3.0 connector
POE
24V~48V passive POE
DC Jack
24V~48V power supply
ROHS Compliance
YES
Dimension
115mm x 105mm x 16mm
Nor Flash
2MB~32MB
Nand Flash
128MB
DDR
256MB
   Radio TX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
802.11a
6 Mbps
27dBm
30dbm
±2dB
54 Mbps
23dBm
26dbm
±2dB
802.11n HT20
MCS0, MCS8
26dBm
29dbm
±2dB
MCS7, MCS15
22dBm
25dbm
±2dB
802.11n HT40
MCS0, MCS8
25dBm
28dbm
±2dB
MCS7, MCS15
21dBm
24dbm
±2dB
802.11ac
MCS0, MCS10,MCS20
25dBm
28dbm
±2dB
MCS9,MCS19,MCS29
19dBm
22dbm
±2dB
   Radio RX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Sensitivity
802.11a
6 Mbps
-96dBm
54 Mbps
-78dBm
802.11n HT20
MCS0, MCS8
-92dBm
MCS7, MCS15
-73dBm
802.11n HT40
MCS0, MCS8
-90dBm
MCS7, MCS15
-70dBm
802.11AC HT40
MCS0, MCS10,MCS20
-90dBm
MCS9,MCS19,MCS29
-67dBm
802.11AC HT80
MCS0, MCS10,MCS20
-88dBm
MCS9,MCS19,MCS29
-62dBm
Radio TX Specifications(2412MHz-2482MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
802.11g
6 Mbps
27dbm
30dbm
±2dB
54 Mbps
25dbm
28dbm
±2dB
802.11n HT20
MCS0, MCS8
26dbm
29dbm
±2dB
MCS7, MCS15
25dbm
28dbm
±2dB
802.11n HT40
MCS0, MCS8
26dbm
29dbm
±2dB
MCS7, MCS15
24dbm
27dbm
±2dB
   Radio RX Specifications(2412MHz-2482MHz)
Operating Mode
Data Rate
Sensitivity
802.11g
6 Mbps
-96dBm
54 Mbps
-78dBm
802.11n HT20
MCS0, MCS8
-92dBm
MCS7, MCS15
-73dBm
802.11n HT40
MCS0, MCS8
-90dBm
MCS7, MCS15
-70dBm
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
