2691|4
7096
【创龙TL570x-EVM】按键控制LED灯 [复制链接]
【前言】例程给了Python控制LED闪烁、检测按键的程序,结合两个案例学习综合一个按键控制例子。
【分析】LED闪灯,是循环检测是否退出的标志来维护的,我这里加入thread线程来开启。按键程序是even来检测的,如果再加入线程就会出现不能退出的现象。
【实现思路】按测键检来判断按键是否按下,然后更新延时秒数来控制LED灯闪烁的快慢。
1、初始化LED:
 def __init__(self):
        self.led_path = "/sys/class/leds/"    # Led path
        self.leds     = []          # Save the led found
        self.enumerate_led()
        self.led_time = 0.1
        self.key_sta = 1
    """ enumerate all led """
    def enumerate_led(self):
        led_name = "user-led"
        """ find led """
        for filename in os.listdir(self.led_path):
            if led_name in filename:
                self.leds.append(os.path.join(self.led_path, filename))
        if len(self.leds) == 0:
            return False
        led sort, e.g.
        /sys/class/leds/user-led0
        /sys/class/leds/user-led1
        /sys/class/leds/user-led2
        self.leds.sort()
        print "find leds:"
        for led in self.leds:
            print led
        return True
2、LED闪烁程序:
""" control led flash """
    def flash_led(self):
        led_num = len(self.leds)
        while not KeyDevice.quit_flag:
            """ Turn on leds """
            for i in range(led_num):
                """ Set the led brightness value to 1 to turn on the led """
                ret = os.system("echo 1 > %s/brightness" % (self.leds))
                if ret != 0:
                    print "Error: Failed to turn on %s" % self.leds
            """ Keep the leds on for 500 ms """
            time.sleep(self.led_time*self.key_sta)
                """ Set the led brightness value to 0 to turn off the LED """
                os.system("echo 0 > %s/brightness" % (self.leds))
            """ Keep the leds off for 500 ms """
3、按键检测程序:
def open_device(self, key_dev):
        try:
            """ open key device, if success, return True"""
            self.key_dev = evdev.InputDevice(key_dev)
            return True
        except Exception as e:
            print e
            return False
    def listen_key_pressed(self):
        try:
            print "Please press the key to test.\n"
            Listen for the button to be pressed
            event.value: 1: pressed; 0: released
            for event in self.key_dev.read_loop():
                if event.type == evdev.ecodes.EV_KEY:
                    if event.code == evdev.ecodes.KEY_PROG1 and event.value == 1:
                        print "User key0 pressed!\n"
                        self.key_sta = 1
                    elif event.code == evdev.ecodes.KEY_PROG2 and event.value == 1:
                        print "User key1 pressed!\n"
                        self.key_sta = self.key_sta + 1
                        if self.key_sta >20:
                            self.key_sta = 1
            if not KeyDevice.quit_flag:
                print e
4、CTRL+C退出程序:
 @classmethod
    def stop(cls):
        print "ctrl + c ..."
        cls.quit_flag = True
        sys.exit()
5、CTRL+C信号:
def sig_handle(signum, frame):
    KeyDevice.stop()
    sys.exit()
6、启动:
if __name__ == '__main__':
    key_dev = "/dev/input/event0"   # key deivce path
    try:
        """ Ctrl+c handler """
        signal.signal(signal.SIGINT, sig_handle)
        key_device = KeyDevice()
        """ open key device """
        res = key_device.open_device(key_dev)
        if not res:
            print "open %s failed!" % key_dev
            exit(3)
        t1 = threading.Thread(target=key_device.flash_led)
        t1.start()
        """ Listen for the button to be pressed """
        key_device.listen_key_pressed()
    except Exception, exc:
        print exc
【实验现象】程序启动后,三个灯快速闪烁,按下按键4,灯闪得慢下来,慢到2秒一次时,再按一下又回到原来的闪烁频率。
本次实验主要学习了python 检测GPIO的输入输出控制。
【总结】python编程还是相对容易的,但是遗憾的就是event只在python2.7中支持,现象已经用习惯了python3,突然回到python2还有点不习惯,python中pip也不支持安装包,所以发挥不出来。希望官方出个如何添加包的教程。
感谢楼主的分享,谢谢................   详情 回复 发表于 2022-6-5 09:42
学习了
用什么命令可以控制led
好几种命令都可以,.sh操作文件,C也可以、Python也可以,N种  详情 回复 发表于 2022-5-25 15:23
7096
hahhk 发表于 2022-5-25 10:31 用什么命令可以控制led
