5994|5
89
uboot上使用flash_eraseall /dev/mtd3时出现大量坏块怎么解决 [复制链接]
之前做jffs2文件系统的时候还挺好的  现在不知道为什么出现这个情况
我开始使用nfs登陆,接着就用flash_eraseall这个命令,在擦除的时候出现下面的情况
Skipping bad block at 0x032b0000
Erasing 16 Kibyte @ 32b4000 -- 97 % complete.
Skipping bad block at 0x032b8000
Erasing 16 Kibyte @ 32d0000 -- 97 % complete.
Skipping bad block at 0x032d4000
Erasing 16 Kibyte @ 32d8000 -- 97 % complete.
Skipping bad block at 0x032dc000
Erasing 16 Kibyte @ 32e8000 -- 97 % complete.
Skipping bad block at 0x032ec000
Erasing 16 Kibyte @ 32f0000 -- 97 % complete.
Skipping bad block at 0x032f4000
Skipping bad block at 0x032f8000
Erasing 16 Kibyte @ 3300000 -- 98 % complete.
Skipping bad block at 0x03304000
Skipping bad block at 0x03308000
Erasing 16 Kibyte @ 330c000 -- 98 % complete.
Skipping bad block at 0x03310000
Erasing 16 Kibyte @ 3314000 -- 98 % complete.
Skipping bad block at 0x03318000
Erasing 16 Kibyte @ 3320000 -- 98 % complete.
Skipping bad block at 0x03324000
Erasing 16 Kibyte @ 332c000 -- 98 % complete.
Skipping bad block at 0x03330000
Erasing 16 Kibyte @ 3338000 -- 98 % complete.
Skipping bad block at 0x0333c000
Erasing 16 Kibyte @ 3344000 -- 98 % complete.
Skipping bad block at 0x03348000
Skipping bad block at 0x0334c000
Skipping bad block at 0x03350000
Skipping bad block at 0x03354000
Erasing 16 Kibyte @ 3358000 -- 98 % complete.
Skipping bad block at 0x0335c000
Erasing 16 Kibyte @ 337c000 -- 99 % complete.
Skipping bad block at 0x03380000
Erasing 16 Kibyte @ 3384000 -- 99 % complete.
Skipping bad block at 0x03388000
Erasing 16 Kibyte @ 3394000 -- 99 % complete.
Skipping bad block at 0x03398000
Skipping bad block at 0x0339c000
Erasing 16 Kibyte @ 33b4000 -- 99 % complete.
Skipping bad block at 0x033b8000
Skipping bad block at 0x033bc000
Skipping bad block at 0x033c0000
Erasing 16 Kibyte @ 33c8000 -- 99 % complete.
Skipping bad block at 0x033cc000
Skipping bad block at 0x033d0000
Erasing 16 Kibyte @ 33e8000 -- 99 % complete.
Skipping bad block at 0x033ec000
Skipping bad block at 0x033f0000
Erasing 16 Kibyte @ 33fc000 -- 99 % complete.
这是最后的一部分
然后我试着使用cp filesyst.jffs2 /dev/mtd3这个命令
结果出现
root@192.168.1.109:/# cp filesyst.jffs2 /dev/mtd3
cp: writing `/dev/mtd3': Input/output error
这是为什么啊?好郁闷   搞了一天还没结果
没有人回答啊。。  详情 回复 发表于 2010-1-6 10:57
63
sigh
78
帮顶下;
学习下!
82
少侠们啊
大侠们啊  求救
66
没有人回答啊。。
