大家好 最近调试内核时候遇到这样问题:
Start = 0x80104730, range = (0x80100000,0x80582584), format = SREC
Linux version 2.6.29.4-rmi-126-DB1300 (root@liuyang-desktop) (gcc version 4.2.4) #6 Mon Mar 22 19:47:14 PDT 2010
console [early0] enabled //早期时候打开是0,其实这个没有关系,最后打印是缓冲去的数据、
CPU revision is: 800c8001 (Au13xx)
(PRId 800c8001) @ 24.00 MHz
RMI DBAu1300 Development Board
Determined physical RAM map:
User-defined physical RAM map:
memory: 04000000 @ 00000000 (usable)
Zone PFN ranges:
Normal 0x00000000 -> 0x00004000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00004000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: root=/dev/nfs nfsroot=192.168.1.15:/nfsroot/db1300fs ip=192.168.1.136 console=ttyS2 mem=64M rw video=au1200fb:panel:bs//现在我设置console=ttyS2,估计下面硬挨是从ttyS2打印出现的信息。
Primary instruction cache 16kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes
PID hash table entries: 256 (order: 8, 1024 bytes)
Alchemy clocksource installed
Console: colour dummy device 80x25
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 58932k/65536k available (3569k kernel code, 6532k reserved, 855k data, 192k init, 0k highmem)
Calibrating delay loop... 791.34 BogoMIPS (lpj=3956736)
Mount-cache hash table entries: 512
net_namespace: 296 bytes
NET: Registered protocol family 16
Hooking cpu_wait
bio: create slab at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
turn off boot console early0 //控制台给关掉了、 后面index 是0, 难道上面不是ttyS2打印出来的吗?
跟踪代码 register_console() 也把ttyS2也传进去了啊。
现在找不到方向, 请大家指点一下。
