5532|14
81
请教pxa270+WIFI8686!!! [复制链接]
用的PXA270和USI的无线网卡 8686芯片组
接口用的SPI
通过打印信息看总是在读取芯片ID时候出错:
Chip(exp, val)= (000bh), ffffh)   //期望是000B ,实际FFFF
pxa_gspi_Init is fault !!!!!!!!!!!!!
If_Initialize is fault !!!!!!!!!!!!!xxxxxxxxxxxxxxx
看代码发现似乎是SPI初始化问题:
        ssp_init_hw(pHC);
        intr_init(pHC);
        dma_init(pHC);   //没有用到DMA
         #if defined (GSPI8385)
                const WORD        chipid = 0x0004;
         #elif defined (GSPI8686)
                const WORD        chipid = 0x000b;
         #else
                const WORD        chipid = 0x000;
         #endif
                ssp_read_register((DWORD)pHC, ®val, 0x02);   //在这读寄存器,读出的值regval出错
         if (chipid != regval)
                        GSPIMSG(1, (TEXT("Chip(exp, val)= (%04xh), %04xh)\n"), chipid, regval));
                            //上面的信息在这里打印出来
                           pxa_gspi_Deinit((DWORD)pHC);
                        pHC = NULL;
                        goto funcFinal;
     其中pxa_gspi_Init函数中对SPI的引脚做了初始化:我用的引脚是
#define                SSP_SCLK                        23
#define                SSP_SFRM                        24
#define                SSP_TX                        25
#define                SSP_RX                        26
#define                SSP_INTR                        22
ssp_init_hw函数中对其初始化:
         pHC->pGPIORegs->GPDR0 |= ((0x1U << 23) | (0x1U << 24) | (0x1U << 25));
        pHC->pGPIORegs->GPDR0 &= ~(0x1U << 26);
        //Set gpio24 to high
        pHC->pGPIORegs->GPSR0 |= (0x1U << 24);  // 输出1
        //Set the gpio 23 as function 2   sspsclk
        //25 as function 2                 ssptxd
        //26 as function 1                  ssprxd
        pHC->pGPIORegs->GAFR0_U &= 0xFFC03FFF;
        pHC->pGPIORegs->GAFR0_U |= ((0x2U << 14) | (0x0U << 16) | (0x2U << 18) | (0x1U << 20));
        //wx_end change
        pHC->pSSPRegs->base.sscr0 = 0;
        pHC->pSSPRegs->base.sscr1 = 0;
        //        Sleep(0);        //JKU
        /// Configure the SSP CLK
#if (SSPCTRLER == 1)                                        ///Using SSP controller1
        pHC->pCLKRegs->cken |= (1<<23);
#elif (SSPCTRLER == 2)                                        ///Using SSP controller2
        pHC->pCLKRegs->cken |= (1<<3);
#elif (SSPCTRLER == 3)                                        ///Using SSP controller3
        pHC->pCLKRegs->cken |= (1<<4);
#endif ///SSPCTRLER
        pHC->pSSPRegs->base.sscr0 = SSCR0_SCR(clkdiv) | SSCR0_DSS(0x000f) | SSCR0_FRF(3);
        pHC->pSSPRegs->base.sscr1 = SSCR1_TTELP | SSCR1_TTE | SSCR1_TSRE | SSCR1_RSRE |
        SSCR1_RFT(0x1) | SSCR1_TFT(0x1) | SSCR1_TRAIL;
        pHC->pSSPRegs->sspsp = SSPSP_SCMODE(0);
        pHC->pSSPRegs->ssto = 1;
        pHC->pSSPRegs->base.sscr0 |= SSCR0_SSE;
        set_GPIO_signal(pHC->pGPIORegs, SSP_RST, SIG_UP);
        udelay(pHC->pOSTRegs, 500);
        set_GPIO_signal(pHC->pGPIORegs, SSP_RST, SIG_DOWN);  //JKU: pin 11 to reset
        udelay(pHC->pOSTRegs, 5000);
请教:现在的现象大概是哪里出了错误?是否是SPI初始化的问题!!!
ding ding ding ding   详情 回复 发表于 2009-11-2 22:12
83
spi读取错误,用spi读的时候多读几个字节数据出来,可能冗余数据的原因。
比如一个寄存器的值是0xabcd,用spi读出来可能是0xff 0xff 0xcd 0xab,前两个字节冗余
关注WIFI
周末不想看CODE  ! 支持一下
81
引用 1 楼 csdeny 的回复:
貌似不是这个问题!
请问:
   我对GPIO  22~26进行如下初始化,是否正确
#define SSP_SCLK 23
#define SSP_SFRM 24
#define SSP_TX 25
#define SSP_RX 26
#define SSP_INTR 22
        //Set the gpio 23,24,25 as output
        //Set the gpio 26 as input
                                   (0x2U << 16)  |
                                   (0x2U << 18)  |
                                   (0x1U << 20));
ding !
84
关注,顶一下。
75
我再顶!
高手们...
62
请问:
#define SSP_SCLK 23
#define SSP_SFRM 24
#define SSP_TX 25
#define SSP_RX 26
#define SSP_INTR 22
pHC->pGPIORegs->GPDR0 |= ((0x1U < < 23) | (0x1U < < 24) | (0x1U < < 25));
pHC->pGPIORegs->GPDR0 &= ~(0x1U < < 26);
        pHC->pGPIORegs->GAFR0_U |= ((0x2U < < 14) |
                                  (0x2U < < 16)  |
                                  (0x2U < < 18)  |
                                  (0x1U < < 20));
58
ding!!!!!!!!!!!!
以解决
59
恭喜
Paul, Chao @ Techware
81
ding ding ding ding
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
