2128|1
感谢一辈子求:我想在下面的代码中 加入 改变窗体大小,和显示图片和滚动文字,该加在什么位置,怎么加 [复制链接]
#include "stdafx.h"
#include
#include
#include
#include "resource.h"
#define                PLUG_HEIGHT                20
#define                MAX_ITEMS                1
// global variables define
HICON                                g_hIcon                        = NULL;
HINSTANCE                        g_hInst                        = NULL;
HWND                                g_hWnd                        = NULL;
HWND                                g_hWndParent        = NULL;
BOOL                                g_bSelected                = FALSE;
//int                                        g_nSelectedItem = 0;
HWND APIENTRY                InitializeCustomItem(TODAYLISTITEM *ptli, HWND hwndParent);
LRESULT CALLBACK        WndProc (HWND hwnd, UINT uimessage, WPARAM wParam, LPARAM lParam) ;
// forward function declarations
static INT InitilizeClasses();
BOOL APIENTRY DllMain( HANDLE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
    switch (ul_reason_for_call)
        case DLL_PROCESS_ATTACH:
                g_hInst = (HINSTANCE)hModule;
                //load the icon
                g_hIcon = (HICON)LoadIcon(g_hInst, MAKEINTRESOURCE(IDI_DISPLAYICON));
                //initilize the application class, and set the global window handle
                UnregisterClass(_T("无线城市"), g_hInst);
                InitilizeClasses();
                g_hWnd = NULL;
                break;
        case DLL_PROCESS_DETACH:
                // The DLL is being unloaded by a given process.  Do any
                // per-process clean up here, such as undoing what was done in
                // DLL_PROCESS_ATTACH.        The return value is ignored.
                DestroyIcon(g_hIcon);
                g_hInst = NULL;
                break;
    return TRUE;
VOID PaintAll(HWND hWnd, HDC hdc)
        TODAYDRAWWATERMARKINFO        dwi;
        dwi.hwnd        = hWnd;
        dwi.hdc                = hdc;
        COLORREF bkcr;
    RECT rect;
        //画当前条目系统背景
        ::GetClientRect(hWnd, &(dwi.rc));
        ::GetClientRect(hWnd, &rect);
        ::SendMessage(g_hWndParent, TODAYM_DRAWWATERMARK, 0, (LPARAM)&dwi);//系统背景
        if(g_bSelected)        //当前条目为选中状态,设置高亮
                //获取高亮背景色
                bkcr = SendMessage(g_hWndParent,TODAYM_GETCOLOR,(WPARAM)TODAYCOLOR_HIGHLIGHT,NULL);
                //设置背景为高亮色
                HBRUSH hbrush = CreateSolidBrush(bkcr);
                FillRect(hdc,&rect,hbrush);
                DeleteObject(hbrush);
                //设置文本高亮
                SetTextColor(hdc, SendMessage(g_hWndParent, TODAYM_GETCOLOR, TODAYCOLOR_HIGHLIGHTEDTEXT,0));
        else        //当前条目为非选中状态
                SetTextColor(hdc, SendMessage(g_hWndParent, TODAYM_GETCOLOR, TODAYCOLOR_TEXT,0));
        //设备透明背景
        SetBkMode(hdc,TRANSPARENT);
        RECT rc(dwi.rc);
        rc.left += 2;
        rc.top += 2;
        // first draw icon
        DrawIcon(hdc, rc.left, rc.top, g_hIcon);
        // second draw text
        rc.top -= 2;
        rc.left += 26;
        DrawText(hdc, _T("无线城市"), -1, &rc, DT_SINGLELINE | DT_LEFT | DT_VCENTER);
LRESULT CALLBACK WndProc (HWND hWnd, UINT uimessage, WPARAM wParam, LPARAM lParam)
        char debText[128] = {0};
        wchar_t debTextTemp[128] = {0};
        switch (uimessage)
        case WM_TODAYCUSTOM_QUERYREFRESHCACHE:
                        TODAYLISTITEM *ptli = (TODAYLISTITEM *)wParam;
                        if (NULL == ptli)
                                break;
                        if (0 == ptli->cyp)
                                ptli->cyp = PLUG_HEIGHT;
                                return TRUE;
                break;
        case WM_CREATE:
                        break;
        case WM_LBUTTONUP:
                        g_bSelected = TRUE;
                        //g_nSelectedItem = 1;
                        PostMessage(GetParent(hWnd), TODAYM_TOOKSELECTION, (WPARAM)hWnd, 0);
                        // 1 判断是否在 有效区域,2 查询注册表, 得到程序路径, 3 启动程序
                        RECT rect;
                        POINT point;
                        //MessageBox(NULL, _T("WM_LBUTTONUP DllMain"), _T("DllMain"), MB_OK);
                        point.x = LOWORD(lParam);
                        point.y = HIWORD(lParam);
                        if(PtInRect(&rect, point))
                                HKEY hOpenKey;
                                long lResult  = 0;
                                DWORD iValueType = 0;
                                DWORD iLen  = 0;
                                PROCESS_INFORMATION  procInfo;
                                TCHAR szPath[MAX_PATH] = {'\0'};
                                LPCTSTR keyName  = _T("Software\\Microsoft\\Today\\Items\\\"无线城市\"");  //此注册表存放你应用程序的执行路径
                                LPCTSTR csAppPath = _T("AppPath");
                                //MessageBox(hWnd, _T("1"), _T("提示"), MB_OK);
                                lResult = ::RegOpenKeyEx(HKEY_LOCAL_MACHINE, keyName, 0, 0, &hOpenKey);
                                ASSERT(lResult == ERROR_SUCCESS);
                                if(lResult != ERROR_SUCCESS)
                                        //MessageBox(hWnd, _T("读注册表失败"), _T("提示"), MB_OK);
                                        break;
                                //MessageBox(hWnd, keyName, _T("提示"), MB_OK);
                                iLen = MAX_PATH * sizeof(TCHAR);
                                lResult = ::RegQueryValueEx(hOpenKey, csAppPath, 0, &iValueType, (BYTE*)szPath, &iLen);
                                        ::RegCloseKey(hOpenKey);
                                        break;
                                //MessageBox(hWnd, csAppPath, _T("提示"), MB_OK);
                                //MessageBox(hWnd, szPath, _T("提示"), MB_OK);
                                BOOL bSuc  = ::CreateProcess(szPath, NULL, NULL, NULL, FALSE, 0, NULL, NULL, NULL, &procInfo);
                                if(bSuc)
                                        ::CloseHandle(procInfo.hThread);
                                        ::CloseHandle(procInfo.hProcess);
                                else
                                        //MessageBox(hWnd, _T("启动程序失败"), _T("提示"), MB_OK);
                break;
        case WM_PAINT:
                        HDC hdc;
                        PAINTSTRUCT ps;
                        hdc = BeginPaint(hWnd, &ps);
                        PaintAll(hWnd, hdc);
                        EndPaint(hWnd, &ps);
                break;
        case WM_ERASEBKGND:
                return TRUE;
        case WM_TODAYCUSTOM_RECEIVEDSELECTION:
                g_bSelected = TRUE;
                return TRUE;
        case WM_TODAYCUSTOM_USERNAVIGATION:
                //InvalidateRect(hWnd, NULL, FALSE);
                //if (wParam == VK_UP)
                //        g_nSelectedItem--;
                //if (wParam == VK_DOWN)
                //        g_nSelectedItem++;
                //if (g_nSelectedItem < 0 || g_nSelectedItem >= MAX_ITEMS)
                //        return FALSE; // go to the next plug-in
                //else
                //        return FALSE;  // stay in this plug-in
                break;
        case WM_TODAYCUSTOM_ACTION:
                RECT rect;
                POINT point;
                        HKEY hOpenKey;
                        long lResult  = 0;
                        DWORD iLen  = 0;
                                break;
                                break;
                        if(bSuc)
                        else
                break;
        case WM_TODAYCUSTOM_LOSTSELECTION:
                break;
#if 0
        default:
                memset(debText,0,128);
                memset(debTextTemp,0,128*sizeof(wchar_t));
                sprintf(debText,"uimessage,wParam,lParam:%d,%d,%d\r\n",uimessage,wParam,lParam);
                MultiByteToWideChar(CP_ACP,MB_PRECOMPOSED,debText,-1,debTextTemp,128/2);
                //MessageBox(hWnd, debTextTemp, _T("提示"), MB_OK);
#endif
        return DefWindowProc (hWnd, uimessage, wParam, lParam) ;
// export function
HWND APIENTRY InitializeCustomItem(TODAYLISTITEM *ptli,HWND hwndParent)
   if (ptli->fEnabled==0)
                return NULL;    //Return NULL if we are not enabled.
   //g_hInst = ptli->hinstDLL;
   //load the icon
        //g_hIcon = (HICON)LoadIcon(g_hInst, MAKEINTRESOURCE(IDI_ICON1));
   g_hWnd = CreateWindow(TEXT("无线城市"), TEXT("无线城市"), WS_VISIBLE | WS_CHILD,
                0, 0, ::GetSystemMetrics(SM_CXSCREEN), PLUG_HEIGHT, hwndParent, NULL, g_hInst, NULL);
        g_hWndParent = hwndParent;
        // attach our winproc to the newly created window
        SetWindowLong(g_hWnd, GWL_WNDPROC, (LONG) WndProc);
        //display the window
        ShowWindow (g_hWnd, SW_SHOWNORMAL);
        UpdateWindow (g_hWnd) ;
    return g_hWnd;
/* Create and register our window class for the today item                                 */
        WNDCLASS                 wc;
        memset(&wc, 0, sizeof(wc));
        wc.style                 = 0;
        wc.lpfnWndProc         = (WNDPROC) WndProc;
        wc.hInstance         = g_hInst;
        wc.hIcon                 = 0;
        wc.hCursor                 = 0;
        wc.hbrBackground = (HBRUSH) COLOR_BACKGROUND;
        wc.lpszClassName = _T("无线城市");
        //register our window
        if(!RegisterClass(&wc))
                return 0 ;
        return 1;
去看windows程序设计,那里有说的。  详情 回复 发表于 2010-3-5 11:43
55
