COMMANDS:
To see detailed help type the command followed by /?
Extension Information and Control:
help - display this list
version - display version information for this extension
refresh - refresh cached info (must call after any run/break cycle).
xml - capture debug info in an xml file and display formatted data.
save - prompts the user for a location in which to save all files generated
in the session.
getworkingpath - display the path to the debugger extension's current working folder.
setworkingpath - specify a path to use as a new destination for saved files (working
folder)
General Information:
exception - exception info and current call stack
kinfo - prints the UserKInfo table
toc - prints ROM table of contents
oat - prints OEM Address Table
disasm - retrieve disassembly for a given address
getsym - list nearest symbol at addr
checksymbols - validate that correct symbols are in use.
dd - dump data at given address
ll - prints linked lists generically
expr - evaluate an expression
getsizeof - get the size, in bytes, of a type or expression
d2x - convert a decimal integer to a hex value.
x2i - convert a hex value to a singed integer.
x2u - convert a hex value to an unsigned integer.
ms2t - display a value in milliseconds as hours, minutes, and seconds.
Diagnostics:
diagnose - provide detailed information about hangs or crashes
Threads:
thread - prints thread information from thread ptr
threadh - prints thread information from thread handle
threadlist - enumerate all threads (basic info). use "threadlist ?" for more
options
allthreads - enumerate all threads (extended info)
runlist - enumerate threads on the scheduler's run list.
sleeplist - enumerate threads on the scheduler's sleep list.
context - print context information for a given thread.
stackeval - prints all values on a thread's stack, looking for potential symbols
and known objects
stacktrace - prints stack ptr and frame ptrs with PC and ret addr for a given
thread
Processes and Modules:
proc - prints process information
proclist - lists all processes
module - prints module information
modlist - lists all loaded modules
Handles:
handlelist - prints active handle list
handle - evaluates a handle to determine type
h2p - get kernel object ptr from a handle
p2h - get a handle from a kernel object ptr
Blocked Threads:
proxy - prints detailed information about a particular proxy (i.e. blocking
object)
proxylist - lists all of the proxies in the system or owned by a particualr
process
blocked - prints list of blocking objects (proxies) and the threads they are
blocking
cslist - prints a list of critical sections that are currently blocking
threads
eventlist - prints a list of events that are currently blocking threads
sending - prints a list of threads blocked in SendMessage calls
Memory:
heaplist - prints summary information about all heaps in the system
heapwalk - print extended heap information
walkthisheap - print heap information for specific heap
meminfo - prints system memory information
heapitem - finds a heap item spanning an address and dumps item contents
dumpitem - prints contents of a heap item
valist - prints virtual allocations associated with a process
fsmaplist - prints summary information about all memory-mapped files
fsmap - prints information about a memory-mapped file
fsviewlist - prints summary information about all memory-mapped views
fsview - prints information about a memory-mapped view
pgpool - prints information about the page pools
GWES:
win - enumerate all windows (use it without arguments for more options)
winh - prints the window information for a handle (can use p|c|n|d|a) for
navigation
gditable - enumerate all GDI entries
gdih - prints the information of the GDI entity related to the provided
handle
gdiobj - prints the information of the GDI entity related to the provided gdi
object
screenshot - creates and shows a screenshot of the current UI state of the device
msgqueues - lists active message queues
注意如果你release目录下的文件和你的设备中的文件(包括pdb文件)不匹配的话,会报以下错误:
Error resolving expression <{,,kernel.dll}g_pprcNK->dwId>
ERROR in ReadStruct, can't read {,,kernel.dll}g_pprcNK->dwId
Symbols for NK.EXE are incorrect. Attempting to reload symbols ...
Unable to resolve NK.EXE symbols.
这是说你的NK.exe和你的NK.pdb不匹配,这种情况下上述命令是用不了的,所以你要至少保证您的设备上的
汗,刚才查到了,cedebugx必须在和device处于kitl连接状态而且具有当时的pdb文件才可以
Debugging Requirements
CeDebugX requires an active debugging session and all of the following conditions:
Platform Builder is connected to the target device through the Kernel Independent Transport Layer (KITL).
The debugger is loaded on the device.
The device is at a debug break state.
Platform Builder has access to valid symbols for the modules on the device.
详细参考http://msdn.microsoft.com/en-us/bb509784.aspx
