wallys Qualcomm-IPQ4019-2T2R-Dual-Band-2-4GHz-5GHz OpenWRT-802.11ac-Wave 2
Featuring withindustrial-grade IPQ4019 chipset
Integrated with 2x 2 5G high power
Radio module and 2x2 2.4G high power Radio module
Support 5.180GHz to5.825GHz Frequency Range;
Support 2.412GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/802.11AC
RoHS compliance ensure a high level
protection of human health and the environment from risks that can be posed by
Rating
Supply Voltage
24V~48
Operating Temperature Range
-40 to +70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
CPU
IPQ4019(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector
2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps
Gigabit Ethernet
2xRJ45
DC Jack
12 power supply
ROHS Compliance
YES
Dimension
65mmx35mm x 16mm
Max Power
12V x 0.8A= 9.6W
Nor Flash
32MB
DDR
256MB
Radio TX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
802.11a
6 Mbps
26dBm
29dbm
±2dB
54 Mbps
22dBm
25dbm
±2dB
802.11n HT20
MCS0, MCS8
26dBm
29dbm
±2dB
MCS7, MCS15
22dBm
25dbm
±2dB
802.11n HT40
MCS0, MCS8
25dBm
28dbm
±2dB
MCS7, MCS15
21dBm
24dbm
±2dB
802.11ac
MCS0, MCS10,MCS20
25dBm
28dbm
±2dB
MCS9,MCS19,MCS29
19dBm
22dbm
±2dB
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, mainly for export market, welcome to consult.
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
