2197|2
【平头哥Sipeed LicheeRV 86 Panel测评】测评之一:开箱demo体验 [复制链接]
   平头哥Sipeed LicheeRV 86开发板,为什么叫86呢:
    86面板通常指家用开关、插座、信息插座等面板,因长和宽均为86毫米,因此通称为86面板,有明装和暗装两种。 86 盒,是一种接线盒的规格,也是在电力装修方面的一个行业标准。比如家里灯的开关,在墙里的一个盒就是接线盒,分为底盒和面板。底盒基本上都是一样的,面板因不同品牌和不同的型号各有不同,但都可以装在同一规格的 86 盒里。
开发板靓照:
  配件丰富,平头哥大气
开机是个链接WIFI天气预报
启动过程:
  1.418836] [ADDR_MGT] addr_mgt_probe: success.
[    1.425282] libphy: Fixed MDIO Bus: probed
[    1.429886] CAN device driver interface
[    1.435036] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[    1.446415] sunxi gmac driver's version: 1.0.0
[    1.451554] gmac-power0: NULL
[    1.454939] gmac-power1: NULL
[    1.458300] gmac-power2: NULL
[    1.462887] Failed to alloc md5
[    1.466430] eth0: Use random mac address
[    1.471167] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.478610] sunxi-ehci: EHCI SUNXI driver
[    1.483715] get ehci0-controller wakeup-source is fail.
[    1.489685] sunxi ehci0-controller don't init wakeup source
[    1.496069] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000923398, 0x:ffffffd004077000, irq_no:2e
[    1.509718] [sunxi-ehci0]: Not init ehci0
[    1.514627] get ehci1-controller wakeup-source is fail.
[    1.520584] sunxi ehci1-controller don't init wakeup source
[    1.526949] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe000923758, 0x:ffffffd00407b000, irq_no:31
[    1.540558] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
[    1.553173] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[    1.560456] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.570348] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
[    1.602495] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[    1.611255] hub 1-0:1.0: USB hub found
[    1.615593] hub 1-0:1.0: 1 port detected
[    1.620779] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.627847] sunxi-ohci: OHCI SUNXI driver
[    1.632954] get ohci0-controller wakeup-source is fail.
[    1.638922] sunxi ohci0-controller don't init wakeup source
[    1.645261] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000923ed8
[    1.655732] [sunxi-ohci0]: Not init ohci0
[    1.660612] get ohci1-controller wakeup-source is fail.
[    1.666627] sunxi ohci1-controller don't init wakeup source
[    1.672915] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe000924298
[    1.683452] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
[    1.696097] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[    1.703409] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.713313] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
[    1.787377] hub 2-0:1.0: USB hub found
[    1.791656] hub 2-0:1.0: 1 port detected
[    1.797196] usbcore: registered new interface driver uas
[    1.803393] usbcore: registered new interface driver usb-storage
[    1.810193] usbcore: registered new interface driver ums-alauda
[    1.817030] usbcore: registered new interface driver ums-cypress
[    1.823882] usbcore: registered new interface driver ums-datafab
[    1.830712] usbcore: registered new interface driver ums_eneub6250
[    1.837748] usbcore: registered new interface driver ums-freecom
[    1.844587] usbcore: registered new interface driver ums-isd200
[    1.851318] usbcore: registered new interface driver ums-jumpshot
[    1.858263] usbcore: registered new interface driver ums-karma
[    1.864957] usbcore: registered new interface driver ums-onetouch
[    1.871885] usbcore: registered new interface driver ums-realtek
[    1.878733] usbcore: registered new interface driver ums-sddr09
[    1.885526] usbcore: registered new interface driver ums-sddr55
[    1.892233] usbcore: registered new interface driver ums-usbat
[    1.899906] sunxi_gpadc_init,1968, success
[    1.905430] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[    1.917780] sunxi-rtc 7090000.rtc: registered as rtc0
[    1.923625] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:02 UTC (2)
[    1.932620] sunxi-rtc 7090000.rtc: sunxi rtc probed
[    1.938467] i2c /dev entries driver
[    1.942531] IR NEC protocol handler initialized
[    1.948324] sunxi cedar version 1.1
[    1.952557] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[    1.958834] VE: install start!!!
[    1.958834]
[    1.964396] VE: cedar-ve the get irq is 6
[    1.964396]
[    1.970784] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
[    1.970784]
[    1.982513] VE: install end!!!
[    1.982513]
[    1.988939] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.998141] Bluetooth: HCI UART driver ver 2.3
[    2.003218] Bluetooth: HCI UART protocol H4 registered
[    2.008978] Bluetooth: HCI UART protocol BCSP registered
[    2.014961] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[    2.024958] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
[    2.035022] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[    2.041239] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[    2.047624] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[    2.054136] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[    2.060578] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[    2.067199] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[    2.073772] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[    2.080309] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[    2.087335] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[    2.092862] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[    2.099540] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.110785] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[    2.131031] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.155518] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[    2.161252] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.173593] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
[    2.183723] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[    2.190022] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[    2.196448] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[    2.202987] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.214642] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[    2.221106] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[    2.227784] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[    2.234388] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[    2.240982] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[    2.247615] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    2.256403] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.269079] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.280360] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[    2.289365] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.301024] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.325423] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[    2.333120] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[    2.340444] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[    2.351497] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[    2.358466] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.370355] sunxi_led_probe()1715 - start
[    2.375136] sunxi_get_str_of_property()1560 - failed to get the string of propname led_regulator!
[    2.385216] sunxi_register_led_classdev()1448 - led_classdev start
[    2.393525] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.406992] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.417529] sunxi_led_probe()1820 - finish
[    2.422793] usbcore: registered new interface driver usbhid
[    2.429118] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    2.440826] usbhid: USB HID core driver
[    2.446011] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    2.452912] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    2.464629] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    2.472261] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    2.479285] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[    2.491002] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    2.497868] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.509265] usbcore: registered new interface driver snd-usb-audio
[    2.519759] sunxi-daudio 2034000.daudio: regulator missing or invalid
[    2.527248] mmc0: new high speed SDHC card at address 1234
[    2.534461] [AUDIOCODEC][sunxi_codec_parse_params][2094]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
[    2.534461]
[    2.552874] mmcblk0: mmc0:1234 SA32G 28.9 GiB
[    2.559941] [AUDIOCODEC][sunxi_codec_parse_params][2130]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[    2.571610] [AUDIOCODEC][sunxi_internal_codec_probe][2266]:codec probe finished
[    2.571789]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[    2.586207] sid_rd_ver_reg()254 - ver >= 4, soc ver:5
[    2.591919] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[    2.604498] [SNDCODEC][sunxi_card_init][583]:card init finished
[    2.613385] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[    2.624663] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
[    2.636821] [SNDCODEC][sunxi_card_dev_probe][832]:register card finished
[    2.645132] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
[    2.653706] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
[    2.662848] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
[    2.674468] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
[    2.686445] NET: Registered protocol family 10
[    2.692929] Segment Routing with IPv6
[    2.697249] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.704726] NET: Registered protocol family 17
[    2.709779] can: controller area network core (rev 20170425 abi 9)
[    2.716922] NET: Registered protocol family 29
[    2.721923] can: raw protocol (rev 20170425)
[    2.726750] can: broadcast manager protocol (rev 20170425 t)
[    2.733174] can: netlink gateway (rev 20190810) max_hops=1
[    2.739633] Bluetooth: RFCOMM TTY layer initialized
[    2.745232] Bluetooth: RFCOMM socket layer initialized
[    2.751048] Bluetooth: RFCOMM ver 1.11
[    2.756294] Loading compiled-in X.509 certificates
[    2.763976] HDMI 2.0 driver init start!
[    2.768298] boot_hdmi=false
[    2.771482] ERROR: pinctrl_get for HDMI2.0 DDC fail
[    2.778563] HDMI2.0 module init end
[    2.806934] twi twi2: twi2 supply twi not found, using dummy regulator
[    2.821188] input: fts_ts as /devices/platform/soc@3000000/twi2/i2c-2/2-0048/input/input2
[    2.852749] fts_ts 2-0048: 2-0048 supply  not found, using dummy regulator
[    2.860716] fts_ts 2-0048: 2-0048 supply  not found, using dummy regulator
[    2.868579] debugfs: Directory '2-0048-' with parent 'reg-dummy-regulator-dummy' already present!
[    3.302509] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:3
[    3.390950] random: fast init done
[    3.732777] sunxi_i2c_probe()2262 - [i2c2] probe success
[    3.742267] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
[    3.752586] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
[    3.762813] debugfs: Directory '2034000.daudio' with parent 'sndhdmi' already present!
[    3.773526] sunxi-audio-card 20340a0.sounddaudio2: 20340a4.hdmiaudio <-> 2034000.daudio mapping ok
[    3.785371] get det_vbus is fail, -84
[    3.789488] get id is fail, -84
[    3.794336] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.805326] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.812956] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.822746] clk: Not disabling unused clocks
[    3.827551] ALSA device list:
[    3.830882]   #0: audiocodec
[    3.834243] cfg80211: failed to load regulatory.db
[    3.839693]   #1: snddmic
[    3.842731]   #2: sndhdmi
[    3.845692] alloc_fd: slot 0 not NULL!
[    3.860443] EXT4-fs (mmcblk0p7): mounted filesystem without journal. Opts: (null)
[    3.869051] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[    3.877972] devtmpfs: mounted
[    3.881483] Freeing unused kernel memory: 196K
[    3.886588] This architecture does not have kernel memory protection.
[    3.893876] Run /sbin/init as init process
[    3.997926] cgroup1: Need name or subsystem set
[    4.020921] init: Console is alive
[    4.025144] init: - watchdog -
[    4.028727] init: - preinit -
[    4.340013] mount_root: mounting /dev/root
[    4.345159] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[    4.351431] mount_root: loading kmods from internal overlay
[    4.449059] block: attempting to load /etc/config/fstab
[    4.457577] block: extroot: not configured
[    4.473754] procd: - early -
[    4.477248] procd: - watchdog -
[    4.490110] random: procd: uninitialized urandom read (4 bytes read)
[    4.784052] procd: - watchdog -
[    4.787876] procd: - ubus -
[    4.791655] procd (1): /proc/118/oom_adj is deprecated, please use /proc/118/oom_score_adj instead.
[    4.812811] random: ubusd: uninitialized urandom read (4 bytes read)
[    4.846963] random: ubusd: uninitialized urandom read (4 bytes read)
[    4.882535]
[    4.882535] insmod_device_driver
[    4.882535]
[    4.889655] device_chose finished 139!
[    4.906963] procd: - init -
Please press Enter to activate this console.
[    5.779373] fuse: init (API version 7.31)
[    5.906156] usbcore: registered new interface driver uvcvideo
[    5.932912] USB Video Class driver (1.1.1)
[    6.088040] file system registered
[    6.178939] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[    6.372526] hdmi_hpd_sys_config_release
[    6.422653] read descriptors
[    6.425908] read strings
[   10.702851] ======== XRADIO WIFI OPEN ========
[   10.725205] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
[   10.731992] [XRADIO] Allocated hw_priv @ (____ptrval____)
[   10.763232] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
[   10.798648] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[   11.077901] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   11.316582] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   11.342532] [XRADIO] Detect SDIO card 1
[   11.359682] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[   11.405048] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   11.442562] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   11.473572] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   11.513317] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[   11.552641] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[   11.589503] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   11.628287] mmc1: new high speed SDIO card at address 0001
[   11.642649] [SBUS] XRadio Device:sdio clk=50000000
[   11.661869] [XRADIO] XRADIO_HW_REV 1.0 detected.
[   11.723234] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x01400000.
[   11.824493] [XRADIO] Bootloader complete
[   12.072664] [XRADIO] Firmware completed.
[   12.084337] [WSM] Firmware Label:XR_C09.08.52.64_DBG_02.100 2GHZ HT40 Jan  3 2020 13:14:37
[   12.122636] [XRADIO] Firmware Startup Done.
[   12.135813] [XRADIO_WRN] enable Multi-Rx!
[   12.155350] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   12.212581] xt_time: kernel timezone is -0000
[   12.262908] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
[   13.610899] EXT4-fs (mmcblk0p7): warning: mounting unchecked fs, running e2fsck is recommended
[   13.672152] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[   13.678870] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=6c:63:96:6e:0f:41
[   13.699320] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=6c:63:96:6e:0f:41
[   13.731736] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
[   14.624776] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
[   17.262533] random: crng init done
[   17.266364] random: 7 urandom warning(s) missed due to ratelimiting
[   34.402521] usb1-vbus: disabling
[   34.406160] vdd_3v3: disabling
[   38.183145] [STA_WRN] Freq 2437 (wsm ch: 6) prev: 3.
[   38.192545] wlan0: authenticate with 34:f7:16:4c:fa:6a (try 1)
[   38.216199] [STA_WRN] [HT40][xradio_join_work][bss_ht_info]:
[   38.216199] [primary_chan  :0x00000006]
[   38.216199] [ht_param      :0x00000007]
[   38.216199] [operation_mode:0x00000004]
[   38.216199] [stbc_param    :0x00000000]
[   38.216199] [basic_set[0]  :0x00000000]
[   38.272535] [STA_WRN] [HT40][xradio_join_work][PhyModeCfg:0x0027]
[   38.272535] [ModemFlags    :0x00000007]
[   38.272535] [ChWidthCfg    :0x00000002]
[   38.272535] [PriChCfg      :0x00000000]
[   38.272535] [BandCfg       :0x00000000]
[   38.272535] [STBC_Enable   :0x00000000]
[   38.272535] [PreambleCfg   :0x00000000]
[   38.272535] [SGI_Enable    :0x00000000]
[   38.272535] GF_Enable      :0x00000000]
[   38.381687] wlan0: authenticated
[   38.393133] wlan0: associate with 34:f7:16:4c:fa:6a (try 1)
[   38.441624] wlan0: RX AssocResp from 34:f7:16:4c:fa:6a (capab=0x1411 status=0 aid=5)
[   38.461167] wlan0: associated
[   38.470639] [AP_WRN] [STA] ASSOC HTCAP 11N 58
[   38.482509] [AP_WRN] [HT40][xradio_bss_info_changed][ht_prot:0x00000002][HtProtMode:0x0000][Green:0x0004]
[   38.482965] [AP_WRN] [HT40][xradio_bss_info_changed][PhyModeCfg:0x4027]
[   38.482965] [ModemFlags    :0x00000007]
[   38.482965] [ChWidthCfg    :0x00000002]
[   38.482965] [PriChCfg      :0x00000000]
[   38.482965] [BandCfg       :0x00000000]
[   38.482965] [STBC_Enable   :0x00000000]
[   38.482965] [PreambleCfg   :0x00000000]
[   38.482965] [SGI_Enable    :0x00000001]
[   38.482965] [GF_Enable     :0x00000000]
[   38.803899] [TXRX_WRN] drop=1759, fctl=0x00d0.
[   38.813472] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
原来86是这里来的,学习了!   详情 回复 发表于 2022-3-7 22:27
6882
拆箱只是第一步,期待后续测评
7676
原来86是这里来的,学习了!
默认摸鱼,再摸鱼。2022、9、28
