2910|2
7095
【国民技术N32G457评测】RT_Thread ADC 之电压表 [复制链接]
今天用RT_Thread Studio 做一个电压表。工程是基于原来的SSD1306来建立的,这里主要讲一下ADC的工程如何建立,代码的书写。
1、打开RT_Thread Setttings 打开ADC选项:
打开:DS_N32G457系列数据手册V1.2.1.pdf,找到ADC1 通道2 即PA1。
在main.c中添加adc读取线程:
main.c如下:
#include <stdint.h>
#include <rtthread.h>
#include <rtdevice.h>
#include "ssd1306.h"
#include <stdio.h>
/* defined the LED1 pin: PB5 */
#define LED1_PIN    91
#define ADC_DEV_NAME     "adc1"
#define ADC_DEV_CHANNEL  2  //PA1
#define THREAD_PRIORITY         20
#define THREAD_STACK_SIZE       1025
#define THREAD_TIMESLICE        10
static rt_thread_t tid_ssd1306_display = RT_NULL;
void adc_temp_sample(void *parameter)
    rt_adc_device_t adc_temp_dev;
    rt_uint32_t value, vol;
    double temperate;
    rt_err_t ret = RT_EOK;
    char v[6] = {'0','.','0','0','0','V'};
    adc_temp_dev = (rt_adc_device_t)rt_device_find(ADC_DEV_NAME);
    if(adc_temp_dev == RT_NULL)
        rt_kprintf("adc_temp run failed ! can't find %s device!\n",ADC_DEV_NAME);
        //return RT_ERROR;
    /*使能设备 */
    ret = rt_adc_enable(adc_temp_dev, ADC_DEV_CHANNEL);
    if(ret == RT_EOK)
            rt_kprintf("adc sample run success!  find %s device!\n", ADC_DEV_NAME);
        while(1)
            /* 读取采样值 */
            value = rt_adc_read(adc_temp_dev, ADC_DEV_CHANNEL);
            /* 转换为对应温度值 */
            temperate = value *(3.30 / 4096.0)*1000;
            vol = (rt_uint32_t)temperate;
            ssd1306_Fill(Black);
            ssd1306_SetCursor(2, 26);
            v[0] = vol/1000 + '0';
            v[2] = vol/100%10 +'0';
            v[3] = vol/10%10 +'0';
            v[4] = vol%10 +'0';
            ssd1306_WriteString(v, Font_16x26, White);
            ssd1306_UpdateScreen();
            rt_kprintf("the value is :%s \n\r", v);
            rt_thread_mdelay(100);
int main(void)
    uint32_t Speed = 200;
    /* set LED1 pin mode to output */
    rt_pin_mode(LED1_PIN, PIN_MODE_OUTPUT);
    ssd1306_Init();
    rt_kprintf("start ssd1306\r\n");
    ssd1306_Fill(White);
    ssd1306_SetCursor(2,16);
    ssd1306_WriteString("START", Font_16x26, White);
    tid_ssd1306_display = rt_thread_create("th_ssd",
                                 adc_temp_sample, RT_NULL,
                                     THREAD_STACK_SIZE,
                                     THREAD_PRIORITY, THREAD_TIMESLICE);
             /* 如果获得线程控制块,启动这个线程 */
     if (tid_ssd1306_display != RT_NULL)
         rt_thread_startup(tid_ssd1306_display);
    while (1)
        rt_pin_write(LED1_PIN, PIN_LOW);
        rt_thread_mdelay(Speed);
        rt_pin_write(LED1_PIN, PIN_HIGH);
总的来说用RT—Thread Studio 生成ADC取值,还是很简单的。从视频的检测结果来看,与FLUK 18B+的相比,高了大约0.05V左右 (后面我量了一下参考电压只有3.24V左右,可能是这个原因造成的吧),当然也没有做平均,是单次采样的显示。结果还是令人满意的。
      今天本来是想先用ADC来测量片内的温度(ADC1 16通道),但是测出来的值是零,没有跑成功。用官方提供的KEIL的例程是可以测出来的。还没有找到具体原因,翻了一下STM32的资料,是讲要较对一下,看了rt_thread的n32g45x.adc,drv_adc.c,adc.c也没找到解决方法。如果官方技术上班,还请技术指导一下。
附上视频:
顶一下,整的不错 [attach]586539[/attach]     详情 回复 发表于 2022-1-30 08:32
点赞(1) 关注
6855
顶一下,整的不错
谢谢支持!还需要继续努力呀!生命不息,学习不断!  详情 回复 发表于 2022-1-30 10:01
7095
Jacktang 发表于 2022-1-30 08:32 顶一下,整的不错
