3238|5
7065
【国民技术N32G457评测】6 GPIO + I2C 按键中断+SSD1306显示 [复制链接]
成功驱动SSD1306后,利用板上的两个按键做了一个按键输入中断的程序。按右边的KEY3 屏靠右显示RIGHT,按左边的KEY1 显示LEFT。
main.c
 * Copyright (c) 2006-2021, RT-Thread Development Team
 * SPDX-License-Identifier: Apache-2.0
 * Change Logs:
 * Date           Author       Notes
 * 2015-07-29     Arda.Fu      first implementation
#include <stdint.h>
#include <rtthread.h>
#include <rtdevice.h>
#include <board.h>
#include <string.h>
#include <stdio.h>
#include "ssd1306.h"
void ssd1306_TestRectangle1()
    uint32_t delta;
    for(delta = 0; delta < 5; delta ++)
        ssd1306_DrawRectangle(1 + (5*delta),1 + (5*delta) ,SSD1306_WIDTH-1 - (5*delta),SSD1306_HEIGHT-1 - (5*delta),White);
    ssd1306_UpdateScreen();
    return;
/* defined the LED1 pin: PB5 */
#define LED1_PIN    91
#define KEY1_PIN_NUM            29 /* PA4 */
#define KEY3_PIN_NUM            31 /* PA6 */
#define THREAD_PRIORITY         25
#define THREAD_STACK_SIZE       512
#define THREAD_TIMESLICE        5
int flag_key = 0; /* 用于存取按键状态的 */
static rt_thread_t tid1 = RT_NULL;
/* 左键中断回调函数 */
void disp_left(void *args)
    flag_key = 0;
/* 右键中断回调函数 */
void disp_right(void *args)
    flag_key = 1;
void disp_flag(void)
    if (flag_key == 0) {
        ssd1306_Fill(Black);
        ssd1306_SetCursor(2,16);
        ssd1306_WriteString("LEFT", Font_16x26, White);
        flag_key == 3;
    else if (flag_key == 1) {
        ssd1306_SetCursor(48,16);
        ssd1306_WriteString("RIGHT", Font_16x26, White);
        flag_key == 3;
/* 线程1的入口函数 */
static void thread1_entry(void *parameter)
    while (1)
        disp_flag();
        rt_thread_mdelay(10);
void init_Key(void)
    /* 按键1引脚为输入模式 */
    rt_pin_mode(KEY1_PIN_NUM, PIN_MODE_INPUT_PULLUP);
    /* 绑定中断,上升沿模式,回调函数名为beep_on */
    rt_pin_attach_irq(KEY1_PIN_NUM, PIN_IRQ_MODE_FALLING, disp_left, RT_NULL);
    /* 使能中断 */
    rt_pin_irq_enable(KEY1_PIN_NUM, PIN_IRQ_ENABLE);
    /* 按键1引脚为输入模式 */
    rt_pin_mode(KEY3_PIN_NUM, PIN_MODE_INPUT_PULLUP);
    rt_pin_attach_irq(KEY3_PIN_NUM, PIN_IRQ_MODE_FALLING, disp_right, RT_NULL);
    /* 使能中断 */
    rt_pin_irq_enable(KEY3_PIN_NUM, PIN_IRQ_ENABLE);
int main(void)
    uint32_t Speed = 200;
    /* set LED1 pin mode to output */
    rt_pin_mode(LED1_PIN, PIN_MODE_OUTPUT);
    rt_kprintf("start ssd1306\r\n");
    ssd1306_Init();
    init_Key();
    tid1 = rt_thread_create("thread1",
                                thread1_entry, RT_NULL,
                                THREAD_STACK_SIZE,
                                THREAD_PRIORITY, THREAD_TIMESLICE);
        /* 如果获得线程控制块,启动这个线程 */
        if (tid1 != RT_NULL)
            rt_thread_startup(tid1);
    while (1)
        disp_flag();
        rt_pin_write(LED1_PIN, PIN_LOW);
        rt_thread_mdelay(Speed);
        rt_pin_write(LED1_PIN, PIN_HIGH);
感沉这个flag 应该用操作系统的信号量,或者是邮箱来设置,可能更合理,还没有学到,学完后再来优化一下。
嗯,后续有时间可以做一个对比,让大家也了解了解   详情 回复 发表于 2022-1-27 08:32
点赞(1) 关注
1411
初见效果,很不错!
谢谢!还有很多要学习的地方!  详情 回复 发表于 2022-1-25 21:59
1411
感觉国民与其他品牌的MCU有哪些区别?
目前,还没有跟STM的对比,相比复旦微,要友好一些!  详情 回复 发表于 2022-1-25 21:58
没有什么不可以,我就是我,不一样的烟火!
7065
annysky2012 发表于 2022-1-25 16:50 感觉国民与其他品牌的MCU有哪些区别?
7065
annysky2012 发表于 2022-1-25 16:49 初见效果,很不错!
谢谢!还有很多要学习的地方!
1411
lugl4313820 发表于 2022-1-25 21:58 目前,还没有跟STM的对比,相比复旦微,要友好一些!
