2822|0
7122
【国民技术N32G457评测】UART—DMA不定长丢包测试 [复制链接]
目的:测试开发板串口在各个波特率的接收与发送稳定性
评测环境:1、开发板:国民技术N32G457XVL-STB V1.1
                   2、USB—TTL :CP2102
                   3、串口助手:SSCM V5.13.1
                   4、开发软件:RT-Thread studio 2.1.5
串口接收与发送程序:
 * Copyright (c) 2006-2021, RT-Thread Development Team
 * SPDX-License-Identifier: Apache-2.0
 * Change Logs:
 * Date           Author       Notes
 * 2022-01-23     Administrator       the first version
#include <rtthread.h>
#include "uartdma.h"
#include <rtdevice.h>
#define UART2_NAME "uart2" /* 串口设备名称 */
/* 串口接收消息结构体 */
struct rx_msg
    rt_device_t dev;
    rt_size_t size;
struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT;
/* 串口设备句柄 */
static rt_device_t serial2;
/* 消息队伍控制块 */
static struct rt_messagequeue rx_mq;
/*接收数据回调函数 */
static rt_err_t uart2_input(rt_device_t dev, rt_size_t size)
    struct rx_msg msg;
    rt_err_t result;
    msg.dev = dev;
    msg.size = size;
    result = rt_mq_send(&rx_mq, &msg, sizeof(msg));
    if(result == -RT_EFULL)
        /* 消息队伍满 */
        rt_kprintf("message queue full!\r\n");
    return result;
static void serial2_thread_entry(void *parameter)
    struct rx_msg msg;
    rt_err_t result;
    rt_uint32_t rx_length;
    static char rx_buffer[RT_SERIAL_RB_BUFSZ +1];
    while(1)
        rt_memset(&msg, 0, sizeof(msg));
        /* 从消息队列中读取消息 */
        result = rt_mq_recv(&rx_mq, &msg, sizeof(msg), RT_WAITING_FOREVER);
        if(result == RT_EOK)
            /* 从串口读取数据 */
            rx_length = rt_device_read(msg.dev, 0, rx_buffer, msg.size);
            rx_buffer[rx_length] = '\0';
            /* 通过串品设备输出读取到的消息息 */
            rt_device_write(msg.dev, 0, rx_buffer, rx_length);
            /*打印数据 */
            rt_kprintf("%s\n", rx_buffer);
int uart2_dma_sample(void)
    rt_err_t ret = RT_EOK;
    char uart_name[RT_NAME_MAX];
    static char msg_pool[256];
    char str[] = "Hello RT-Thread!\r\n";
    config.baud_rate = BAUD_RATE_921600;
    rt_strncpy(uart_name, UART2_NAME, RT_NAME_MAX);
    /* 查找串口设备 */
    serial2 = rt_device_find(uart_name);
    if(!serial2)
        rt_kprintf("Find %s failed!\r\n", uart_name);
        return RT_ERROR;
    /* 初始化消息队列 */
    rt_mq_init(&rx_mq,
            "rx_mq",
            msg_pool,
            sizeof(struct rx_msg),
            sizeof(msg_pool),
            RT_IPC_FLAG_FIFO);
    /* 以DMA接收及轮询发送方式打开串口设备 */
    rt_device_control(serial2, RT_DEVICE_CTRL_CONFIG, &config);
    rt_device_open(serial2, RT_DEVICE_FLAG_DMA_RX);
    /* 设置接收回调函数 */
    rt_device_set_rx_indicate(serial2, uart2_input);
    /* 发送字符串 */
    rt_device_write(serial2, 0, str, (sizeof(str) - 1));
    /* 创建serial2 线程 */
    rt_thread_t thread_uart2 = rt_thread_create("serial2", serial2_thread_entry, RT_NULL, 1024, 25, 10);
    if(thread_uart2 != RT_NULL)
        rt_thread_startup(thread_uart2);
    else {
        ret = RT_ERROR;
    return ret;
测试方法为:用串口助手的定时发送64个字符,记录下发送与接收的差值,测试时间为30秒钟左右。
测试结果如下表:
波特率 发送间隔时间 发送数据 接收数据 差值
921600 1ms 123200 123200 0
115200 1ms 122624 122624 0
9600 1ms 28864 24128 4376
9600 50ms 30848 25792 5056
9600 100ms 17216 17216 0
在高波特率的情况下,串口处理数据及时未发生丢包现象,9600的波特率因为发送是阻塞发送所以处理不过来而引起的丢包。从测试结果来看这个芯片的串口处理数据还是可以称赞的,特别是DMA的接收处理能力。
921600:
  115200
  9600
  9600间隔50ms:
  9600 间隔100ms
点赞(1) 关注
