上一篇介绍了系统架构:各任务均有独立的状态机,添加MQTT任务时只要新增状态机和其他任务互斥即可;
MQTT任务状态机包含:查询连接状态->是否需要断开之前连接->配置mqtt接入平台->配置mqtt客户端参数->打开客户端->创建连接->订阅主题1->订阅主题2->发布主题->异常处理等
任务间互斥:由于每次发送AT指令前清空接收缓冲区,所以初始化任务、周期性查询NB状态任务、MQTT/Socket任务之间要互斥,否则可能导致NB回复给任务A的指令被任务B清除。
void NB_MQTT_Aliyun_ReportProcess(void)
//static U8 status = 0;
U8 res = 0;
static char ack[200] = {0};
static char cmd [100] = {0};
if((NB.CycleCheckStatus > 1) || (NB.GpsReportStatus > 1))
return;
if(NB.mqtt.err_code != 0)
//return;
switch(NB.ReportStatus)
case 0:
if((NB.CON == 0xFF)
&& (NB.RegStatus == 1)
&& (NB.attach == 1)
&& (NB.csq != 99)
&& (NB.csq != 0)
&& (NB.CGACT_state == 1))
if(NB.isConnect > 0)//已经建立连接,延长处理间隔
NB.ReportTime = (200*100);
else
NB.ReportTime = (200*10);
NB.ReportStatus = 1;
uprintf("\r\n NB.ReportTime %d", NB.ReportTime);
break;
case 1:
if(NB.ReportTime == 0)
NB.ReportStatus = 2;
memset(ack, 0, 200);
memset(cmd, 0, 100);
uprintf("\r\n NB.ReportTimeout");
break;
case 2:
NB.t = 23.0f;//(float)DS18B20_Get_Temp();
if(NB.t != 85.0f)
uprintf("\r\n NB.isConnect %d", NB.isConnect);
if(NB.isConnect <= 0)
NB.ReportStatus = 31;//creat connect
NB.net.socket = 0;
NB.mqtt.tcpconnectID = 0;
NB.ReportStatus = 28;//config keep_alive_time
NB.mqtt.keep_alive_time = 120;
else
NB.ReportStatus = 36;
break;
case 28://config keep_alive_time
sprintf(cmd, "AT+ECMTCFG=\"keepalive\",%d,%d\r\n",NB.mqtt.tcpconnectID, NB.mqtt.keep_alive_time);
res = NB_AT_CMD((U8 *)cmd, 1000, "OK", 2);
if(res == ATCMD_REVOK)
uprintf("\r\n ECMTCFG OK");
NB.ReportStatus = 29;//Disable Sleep Mode
else if(res == ATCMD_TIMEOUT)
uprintf("\r\n ECMTCFG_TIMEOUT");
break;
case 29://查询连接状态
res = NB_AT_CMD("AT+ECMTCONN?\r\n", 1000, "+ECMTCONN:", 2);
uprintf("\r\n ECMTCONN1 OK");
if(!NB_parseMqttConStatus(&EC01RxCache[0], EC01_handle.rcv_size))
if(NB.mqtt.state == 3)//3 MQTT 已经连接成功
NB.ReportStatus = 100;//跳转到断开连接
else
uprintf("\r\n ECMTCONN1_TIMEOUT");
break;
case 100://断开客户端和服务器连接
//+ECMTDISC: 0,0
sprintf(cmd, "AT+ECMTDISC=%d\r\n",NB.mqtt.tcpconnectID);
sprintf(ack, "+ECMTDISC: %d,0",NB.mqtt.tcpconnectID);
res = NB_AT_CMD((U8 *)cmd, 1000, ack, 2);//Close Socket
uprintf("\r\n ECMTDISC OK");
//NB.ReportStatus = 31;
uprintf("\r\n ECMTDISC_TIMEOUT");
break;
#if 1
case 30://关闭客户端
//+ECMTCLOSE: 0,0
sprintf(cmd, "AT+ECMTCLOSE=%d\r\n",NB.mqtt.tcpconnectID);
sprintf(ack, "+ECMTCLOSE: %d,0",NB.mqtt.tcpconnectID);
uprintf("\r\n ECMTCLOSE OK");
uprintf("\r\n ECMTCLOSE_TIMEOUT");
break;
#endif
case 31://配置mqtt客户端参数
//AT+QMTCFG="aliauth",0,"a1KApkvNNDZ","EVN_2021_4_17","cd9b161999b754c3613f1bc1baf78ea5"\r
sprintf(cmd, "AT+ECMTCFG=\"aliauth\",%d,"PRODUCT_KEY","DEVICE_NAME","DEVICE_SECRET"\r\n",
NB.ReportStatus = 32;
//NB.isConnect = 1;
NB.ReportStatus = 0;
break;
case 32://建立tcp连接mqtt服务器
//+ECMTOPEN: 0,0
sprintf(cmd, "AT+ECMTOPEN=%d,\"%s\",%d\r\n",
NB.mqtt.tcpconnectID, HOST_NAME,HOST_PORT);
sprintf(ack, "+ECMTOPEN: %d,",NB.mqtt.tcpconnectID);
res = NB_AT_CMD((U8 *)cmd, 5000, ack, 2);
uprintf("\r\n ECMTOPEN OK");
NB.ReportStatus = 33;
uprintf("\r\n ECMTOPEN_TIMEOUT");
NB.ReportStatus = 30;
break;
case 33://登陆mqtt服务器
//+ECMTCONN: 0,0,0
NB.mqtt.result = 0;//0 打开网络成功
NB.mqtt.ret_code = 0;//0 接受连接
sprintf(cmd, "AT+ECMTCONN=%d,\"12345_33\"\r\n",
sprintf(ack, "+ECMTCONN: %d,%d,%d",NB.mqtt.tcpconnectID, NB.mqtt.result, NB.mqtt.ret_code);
uprintf("\r\n ECMTCONN OK");
NB.ReportStatus = 34;
uprintf("\r\n ECMTCONN_TIMEOUT");
break;
case 34://订阅服务器设置
//+ECMTSUB: 0,1,0,1
NB.mqtt.msgID= 1;
NB.mqtt.qos = 0;
NB.mqtt.result = 0;//0 数据包发送成功且接收到服务器的 ACK
sprintf(cmd, "AT+ECMTSUB=%d,%d,%s,%d\r\n",
NB.mqtt.tcpconnectID, NB.mqtt.msgID, DEVICE_SUBSCRIBE_SET, NB.mqtt.qos);
sprintf(ack, "+ECMTSUB: %d,%d,%d,%d",NB.mqtt.tcpconnectID, NB.mqtt.msgID, NB.mqtt.result, 1);
uprintf("\r\n ECMTSUB1 OK");
NB.ReportStatus = 35;
NB.isConnect = 1;
uprintf("\r\n ECMTSUB1_TIMEOUT");
break;
case 35://订阅服务器应答
//+ECMTSUB: 0,2,0,1
NB.mqtt.msgID= 2;
NB.mqtt.qos = 1;
NB.mqtt.tcpconnectID, NB.mqtt.msgID, DEVICE_SUBSCRIBE_POST_RELAY, NB.mqtt.qos);
res = NB_AT_CMD((U8 *)cmd, 2000, ack, 2);
uprintf("\r\n ECMTSUB2 OK");
NB.isConnect = 1;
uprintf("\r\n ECMTSUB2_TIMEOUT");
break;
case 36://发布
//+ECMTPUB: 0,0,0
NB.mqtt.retain= 0;
NB.mqtt.msgID = 0;
NB.mqtt.qos = 0;
#ifdef USER_206
sprintf((char*)payload_out, PAYLOAD, Temp.temp, MQTT.Index);
#elif defined USER_174
sprintf((char*)payload_out, PAYLOAD, Temp.temp, CO2.co2,
Temp.low_threshold, Temp.high_threshold, CO2.low_threshold, CO2.high_threshold,
CO2.fanSwitch, Temp.CoolingSwitch,
GeoLocation.CoordinateSystem, GeoLocation.Latitude, GeoLocation.Longitude, GeoLocation.Altitude,
MQTT.Index);
#endif
sprintf(cmd, "AT+ECMTPUB=%d,%d,%d,%d,%s,%s\r\n",
NB.mqtt.tcpconnectID, NB.mqtt.msgID, NB.mqtt.qos, NB.mqtt.retain, DEVICE_PUBLISH, payload_out);
//uprintf("\r\n payload_out:%s", payload_out);
sprintf(ack, "+ECMTPUB: %d,%d,%d",NB.mqtt.tcpconnectID, NB.mqtt.msgID, NB.mqtt.result);
res = NB_AT_CMD((U8 *)cmd, 3000, ack, 2);
uprintf("\r\n ECMTPUB OK");
MQTT.Index++;
GeoLocation.Latitude += 0.00001f;
GeoLocation.Longitude += 0.00001f;
GeoLocation.Altitude++;
uprintf("\r\n Latitude %f Longitude %f", GeoLocation.Latitude, GeoLocation.Longitude );
uprintf("\r\n ECMTPUB_TIMEOUT");
NB.ReportStatus = 37;
break;
case 37://查询连接状态
+QMTCONN: 0,3
OK
res = NB_AT_CMD("AT+ECMTCONN?\r\n", 1000, "+ECMTCONN:", 2);//Close Socket
else
NB_ClearStatus();
NB.CON = 0;
break;
case 0xFE://关闭mqtt客户端
//+ECMTCLOSE: 0,0
NB.net.socket = -1;
NB_ClearStatus();
NB.ReportStatus = 0xFF;
break;
default:
break;
轮询消息添加解析MQTT服务器指令:
void NB_Polling_Msg(void)
EC01_handle.rcv_size = NB_CopyFIFOToParseBuf(EC01RxCache);
if((EC01_handle.rcv_size != 0)
&& (NB.CON == 0xFF))//初始化完成允许轮询消息,否则可能导致数据冲突
if(NB_parseDefaultMsg(&EC01RxCache[0], EC01_handle.rcv_size))
if(!NB_parseMqttRECV(&EC01RxCache[0], EC01_handle.rcv_size))//解析MQTT服务器指令
+QMTRECV: 0,0,"/sys/a1KApkvNND
Z/EVN_2021_4_17/thing/service/pr
u8 NB_parseMqttRECV(u8* cmd, u32 len)
char *ptr = NULL;
S16 uiResult;
char str[20];
U16 uiIndexStart = 0, uiAckIndexStart = 0, uiAckIndexEnd = 0;
S8 res = 0xFF;
if(cmd == NULL) return 1;
sprintf(str, "+ECMTRECV: %d,",NB.mqtt.tcpconnectID);
ptr = (char*)cmd;
if(!NB_strcmp(ptr,str,0,len))
if(!NB_GetHexFromStr((char*)ptr, str, ",", 0, len, &uiResult))
NB.mqtt.msgID = (S8)uiResult;
uprintf("\r\n NB.mqtt.msgID=%d", NB.mqtt.msgID);
res = 3;
sprintf(str, "+ECMTRECV: %d,%d,",NB.mqtt.tcpconnectID, NB.mqtt.msgID);
while(uiAckIndexEnd < (len - 2))
if(!NB_GetStrFromStr2((char*)ptr, str, "\r\n", uiIndexStart, len, (char *)NB.net.rxdata, &uiAckIndexStart, &uiAckIndexEnd))
if(!NB_strcmp(( char*)NB.net.rxdata, "\"fanSwitch\":1", 0, 200))
CO2.fanSwitch = 1;
GPIO_ResetBits(GPIOD, GPIO_Pin_2);
uprintf("\r\n fanSwitch=1");
if(!NB_strcmp(( char*)NB.net.rxdata, "\"fanSwitch\":0", 0, 200))
CO2.fanSwitch = 0;
GPIO_SetBits(GPIOD, GPIO_Pin_2);
uprintf("\r\n fanSwitch=0");
if(!NB_strcmp(( char*)NB.net.rxdata, "\"CoolingSwitch\":1", 0, 200))
Temp.CoolingSwitch = 1;
uprintf("\r\n CoolingSwitch=1");
if(!NB_strcmp(( char*)NB.net.rxdata, "\"CoolingSwitch\":0", 0, 200))
Temp.CoolingSwitch = 0;
uprintf("\r\n CoolingSwitch=0");
res = 0;
else
break;
uiIndexStart = uiAckIndexEnd;
return res;
运行效果手机APP远程控制LED:
至此,本次测评告一段落。
还有一些问题待解决。
https://bbs.eeworld.com.cn/thread-1189547-1-1.html#pid3111773
