[复旦微FM33LG0系列开发板测评] 驱动RGB TFT显示屏
今天冬至,看到朋友圈都在吃饺子。想写个祝福大家冬至的话题。手里有个中景园电子技术有限公司320RGB*480 dots matrix TFT LCD 模块,想用FM33LG0驱动一下:
PIN定义:
逻辑时序图:
普通口模拟:
- void LCD_GPIO_Init(void)
- FL_GPIO_InitTypeDef GPIO_InitStruct = {0};
- FL_GPIO_ResetOutputPin(GPIOA, FL_GPIO_PIN_0|FL_GPIO_PIN_1|FL_GPIO_PIN_2|FL_GPIO_PIN_3|FL_GPIO_PIN_4|FL_GPIO_PIN_5|FL_GPIO_PIN_6|FL_GPIO_PIN_7);
- GPIO_InitStruct.pin = FL_GPIO_PIN_0|FL_GPIO_PIN_1|FL_GPIO_PIN_2|FL_GPIO_PIN_3|FL_GPIO_PIN_4|FL_GPIO_PIN_6|FL_GPIO_PIN_7;
- GPIO_InitStruct.mode = FL_GPIO_MODE_OUTPUT;
- GPIO_InitStruct.outputType = FL_GPIO_OUTPUT_PUSHPULL;
- GPIO_InitStruct.pull = FL_DISABLE;
- FL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- FL_GPIO_ResetOutputPin(GPIOB, FL_GPIO_PIN_5);
- GPIO_InitStruct.pin = FL_GPIO_PIN_5;
- GPIO_InitStruct.mode = FL_GPIO_MODE_INPUT ;
- FL_GPIO_Init(GPIOB, &GPIO_InitStruct);
- // GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_6|GPIO_Pin_7);
- #define LCD_SCLK_Clr() FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_0)//SCL=SCLK
- #define LCD_SCLK_Set() FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_0)
- #define LCD_MOSI_Clr() FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_1)//SDA=MOSI
- #define LCD_MOSI_Set() FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_1)
- #define LCD_RES_Clr() FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_2)//RES
- #define LCD_RES_Set() FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_2)
- #define LCD_DC_Clr() FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_3)//DC
- #define LCD_DC_Set() FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_3)
- #define LCD_BLK_Clr() FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_4)//BLK
- #define LCD_BLK_Set() FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_4)
- #define ZK_MISO FL_GPIO_ReadInputPort(GPIOB)//MISO 读取字库数据引脚
- #define LCD_CS_Clr() FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_6)//CS
- #define LCD_CS_Set() FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_6)
- #define ZK_CS_Clr() FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_7)
- #define ZK_CS_Set() FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_7)
驱动代码:
- 函数说明:LCD串行数据写入函数
- 入口数据:dat 要写入的串行数据
- 返回值: 无
- void LCD_Writ_Bus(u8 dat)
- u8 i;
- LCD_CS_Clr();
- for(i=0;i<8;i++)
- LCD_SCLK_Clr();
- if(dat&0x80)
- LCD_MOSI_Set();
- else
- LCD_MOSI_Clr();
- LCD_SCLK_Set();
- dat<<=1;
- LCD_CS_Set();
- 函数说明:LCD写入数据
- 入口数据:dat 写入的数据
- 返回值: 无
- void LCD_WR_DATA8(u8 dat)
- LCD_Writ_Bus(dat);
- 函数说明:LCD写入数据
- 入口数据:dat 写入的数据
- 返回值: 无
- void LCD_WR_DATA(u32 dat)
- LCD_Writ_Bus(dat>>16);
- LCD_Writ_Bus(dat>>8);
- 函数说明:LCD写入命令
- 入口数据:dat 写入的命令
- 返回值: 无
- void LCD_WR_REG(u8 dat)
- LCD_DC_Clr();//写命令
- LCD_DC_Set();//写数据
- 函数说明:设置起始和结束地址
- 入口数据:x1,x2 设置列的起始和结束地址
- y1,y2 设置行的起始和结束地址
- 返回值: 无
- void LCD_Address_Set(u16 x1,u16 y1,u16 x2,u16 y2)
- LCD_WR_REG(0x2a);//列地址设置
- LCD_WR_DATA8(x1>>8);
- LCD_WR_DATA8(x1);
- LCD_WR_DATA8(x2>>8);
- LCD_WR_DATA8(x2);
- LCD_WR_REG(0x2b);//行地址设置
- LCD_WR_DATA8(y1>>8);
- LCD_WR_DATA8(y1);
- LCD_WR_DATA8(y2>>8);
- LCD_WR_DATA8(y2);
- LCD_WR_REG(0x2c);//储存器写
- void LCD_Init(void)
- LCD_GPIO_Init();//初始化GPIO
- LCD_RES_Clr();//复位
- FL_DelayMs(100);
- LCD_RES_Set();
- FL_DelayMs(100);
- LCD_BLK_Set();//打开背光
- FL_DelayMs(100);
- //************* Start Initial Sequence **********//
- LCD_WR_REG(0x11); //Sleep out
- FL_DelayMs(120); //Delay 120ms
- LCD_WR_REG(0XF2);
- LCD_WR_DATA8(0x18);
- LCD_WR_DATA8(0xA3);
- LCD_WR_DATA8(0x12);
- LCD_WR_DATA8(0x02);
- LCD_WR_DATA8(0XB2);
- LCD_WR_DATA8(0xFF);
- LCD_WR_DATA8(0x10);
- LCD_WR_DATA8(0x00);
- LCD_WR_REG(0XF8);
- LCD_WR_DATA8(0x21);
- LCD_WR_DATA8(0x04);
- LCD_WR_REG(0X13);
- LCD_WR_REG(0x36); // Memory Access Control
- if(USE_HORIZONTAL==0)LCD_WR_DATA8(0x08);
- else if(USE_HORIZONTAL==1)LCD_WR_DATA8(0xC8);
- else if(USE_HORIZONTAL==2)LCD_WR_DATA8(0x78);
- else LCD_WR_DATA8(0xA8);
- LCD_WR_REG(0xB4);
- LCD_WR_REG(0xB6);
- LCD_WR_DATA8(0x22);
- LCD_WR_REG(0xC1);
- LCD_WR_DATA8(0x41);
- LCD_WR_REG(0xC5);
- LCD_WR_REG(0x3a);
- LCD_WR_DATA8(0x66);
- FL_DelayMs(50);
- LCD_WR_REG(0xE0);
- LCD_WR_DATA8(0x0F);
- LCD_WR_DATA8(0x1F);
- LCD_WR_DATA8(0x1C);
- LCD_WR_DATA8(0x0C);
- LCD_WR_DATA8(0x08);
- LCD_WR_DATA8(0x48);
- LCD_WR_DATA8(0x98);
- LCD_WR_DATA8(0x37);
- LCD_WR_DATA8(0x0A);
- LCD_WR_DATA8(0x13);
- LCD_WR_DATA8(0x11);
- LCD_WR_DATA8(0x0D);
- LCD_WR_REG(0xE1);
- LCD_WR_DATA8(0x32);
- LCD_WR_DATA8(0x2E);
- LCD_WR_DATA8(0x0B);
- LCD_WR_DATA8(0x05);
- LCD_WR_DATA8(0x47);
- LCD_WR_DATA8(0x75);
- LCD_WR_DATA8(0x06);
- LCD_WR_DATA8(0x03);
- LCD_WR_DATA8(0x24);
- LCD_WR_DATA8(0x20);
- LCD_WR_REG(0x11);
- FL_DelayMs(120);
- LCD_WR_REG(0x29);
- LCD_WR_REG(0x2C);
main
- Display_GB2312_String(10,50,32, "祝大家冬至吃水饺",WHITE,BLACK);
- Display_GB2312_String(10,100,32, "祝大家冬至吃水饺",RED,BLACK);
- Display_GB2312_String(10,150,32, "祝大家冬至吃水饺",BLUE,BLACK);
- Display_GB2312_String(10,200,32, "祝大家冬至吃水饺",GREEN,BLACK);
效果如下:
测试视频:
总结:库函数跟STM32命名和其他底层驱动略有不同,需要耐心细致。
