3386
41
实验的视频记录
优酷:https://v.youku.com/v_show/id_XNTkyMTAwNDQwOA==.html?spm=a2hcb.playlsit.page.1
B站:https://www.bilibili.com/video/BV1gP4y117Xx/?vd_source=98c6b1fc23b2787403d97f8d3cc0b7e5
3386
42
  【Arduino】168种传感器模块系列实验(资料代码+仿真编程+图形编程)
  实验一百七十七:Wemos D1 R32 ESP32开发板
  项目之四十七:快速傅里叶变换256位频谱仪
#include  "arduinoFFT.h"
#include <FastLED.h>
#define NUM_LEDS 256
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
arduinoFFT FFT = arduinoFFT();
CRGB leds[NUM_LEDS];
#define CHANNEL 39
#define DATA_PIN 23
const uint8_t max_bright = 2;
const uint16_t samples = NUM_LEDS / 4;
const byte halfsamples = samples / 2;
uint8_t gHue;
int value;
double vReal[samples];
double vImag[samples];
char toData[halfsamples];
int pointJump[halfsamples];
int uJump[halfsamples];
int dJump[halfsamples];
int uValue;
int dValue;
int tValue;
int toDown = 0;
uint8_t toDownSpeed = 3;
int pointDown = 0;
uint8_t pointDownSpeed = 9;
void setup(){
  delay(100);
  Serial.println("Ready");
  FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  FastLED.setBrightness(max_bright);
void loop(){
  FastLED.clear();
  EVERY_N_MILLISECONDS(10) {
    gHue += 10;
  for (int i = 0; i < samples; i++)
    value = analogRead(CHANNEL);
    vReal[i] = value;
    vImag[i] = 0.0;
  FFT.Windowing(vReal, samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
  FFT.Compute(vReal, vImag, samples, FFT_FORWARD);
  FFT.ComplexToMagnitude(vReal, vImag, samples);
  for (int i = 0; i < halfsamples; i++)
    toData[i] = vReal[i + halfsamples / 2];
    toData[i] = constrain(toData[i], 0, 100);
    toData[i] = map(toData[i], 0, 100, 1, 7);
    uValue = toData[i];
    uJump[i]++;
    if (uValue > uJump[i])
      uValue = uJump[i];
    else
      uJump[i] = uValue;
    dValue = uValue;
    toDown++;
    if (toDown % toDownSpeed == 0)
      dJump[i]--;
      toDown = 0;
    if (dValue > pointJump[i])
      dJump[i] = dValue;
    else
      dValue = dJump[i];
    tValue = uValue;
    pointDown++;
    if (pointDown % pointDownSpeed == 0)
      pointJump[i]--;
      pointDown = 0;
    if (tValue > pointJump[i])
      pointJump[i] = tValue;
    else
      tValue = pointJump[i];
    fill_rainbow(leds + 8 * i, uValue, gHue, 30);
    fill_rainbow(leds + 8 * i, dValue, gHue, 30);
    fill_solid(leds + 8 * i + tValue, 1, CRGB::White);
  FastLED.show();
  delay(2);
3386
43
实验场景图
3386
44
实验的视频记录
优酷:https://v.youku.com/v_show/id_XNTkxOTQxODA2OA==.html?spm=a2hcb.playlsit.page.3
B站:https://www.bilibili.com/video/BV1ye4y1s7n1/?vd_source=98c6b1fc23b2787403d97f8d3cc0b7e5
3386
45
实验场景图  动态图
3386
46
实验的视频记录
优酷:https://v.youku.com/v_show/id_XNTkxOTQxODEzNg==.html?spm=a2hcb.playlsit.page.1
B站:https://www.bilibili.com/video/BV1hg411q7yo/?vd_source=98c6b1fc23b2787403d97f8d3cc0b7e5
3386
47
  项目之四十八:Arduino 和 FastLED多彩音乐灯
#define SAMPLEPERIODUS 200
#define MIC_PIN 39
#define LED_DT 23
uint8_t max_bright = 33;
struct CRGB leds[NUM_LEDS];
CRGBPalette16 currentPalette = RainbowColors_p;
CRGBPalette16 targetPalette;
void setup() {
  pinMode(LED_BUILTIN, OUTPUT);
  LEDS.addLeds<LED_TYPE, LED_DT, COLOR_ORDER>(leds, NUM_LEDS);
float bassFilter(float sample) {
  static float xv[3] = {0, 0, 0}, yv[3] = {0, 0, 0};
  xv[0] = xv[1]; xv[1] = xv[2];
  xv[2] = sample / 9.1f;
  yv[0] = yv[1]; yv[1] = yv[2];
  yv[2] = (xv[2] - xv[0]) + (-0.7960060012f * yv[0]) + (1.7903124146f * yv[1]);
  return yv[2];
float envelopeFilter(float sample) {
  static float xv[2] = {0, 0}, yv[2] = {0, 0};
  xv[0] = xv[1];
  xv[1] = sample / 160.f;
  yv[0] = yv[1];
  yv[1] = (xv[0] + xv[1]) + (0.9875119299f * yv[0]);
  return yv[1];
float beatFilter(float sample) {
  xv[2] = sample / 7.015f;
  yv[2] = (xv[2] - xv[0]) + (-0.7169861741f * yv[0]) + (1.4453653501f * yv[1]);
  return yv[2];
void loop() {
  unsigned long time = micros();
  float sample, value, envelope, beat, thresh, micLev;
  for (uint8_t i = 0; ; ++i) {
    sample = (float)analogRead(MIC_PIN);
    micLev = ((micLev * 67) + sample) / 68;
    sample -= micLev;
    value = bassFilter(sample);
    value = abs(value);
    envelope = envelopeFilter(value);
    if (i == 200) {
      beat = beatFilter(envelope);
      thresh = 0.02f * 75.;
      if (beat > thresh) {
        digitalWrite(LED_BUILTIN, LOW);
        int strt = random8(NUM_LEDS / 2);
        int ende = strt + random8(NUM_LEDS / 2);
        for (int i = strt; i < ende; i++) {
          uint8_t index = inoise8(i * 30, millis() + i * 30);
          leds[i] = ColorFromPalette(currentPalette, index, 255, LINEARBLEND);
      } else {
        digitalWrite(LED_BUILTIN, HIGH);
      i = 0;
    EVERY_N_SECONDS(5) {
      uint8_t baseC = random8();
      targetPalette = CRGBPalette16(CHSV(baseC + random8(32), 255, random8(128, 255)),
                                    CHSV(baseC + random8(64), 255, random8(128, 255)),
                                    CHSV(baseC + random8(64), 192, random8(128, 255)),
                                    CHSV(baseC + random8(),   255, random8(128, 255)));
    EVERY_N_MILLISECONDS(50) {
      uint8_t maxChanges = 24;
      nblendPaletteTowardPalette(currentPalette, targetPalette, maxChanges);
    EVERY_N_MILLIS(50) {
      fadeToBlackBy(leds, NUM_LEDS, 64);
      FastLED.show();
    for (unsigned long up = time + SAMPLEPERIODUS; time > 20 && time < up; time = micros()) {  }
  } // for i
} // loop()
3386
48
实验场景图
3386
49
实验的视频记录
优酷:
B站:https://www.bilibili.com/video/BV14K411d7y2/?vd_source=98c6b1fc23b2787403d97f8d3cc0b7e5
3386
实验场景图  动态图
3386
51
实验的视频记录
优酷:
B站:https://www.bilibili.com/video/BV1nK411d78Z/?vd_source=98c6b1fc23b2787403d97f8d3cc0b7e5
