3386
21
 【花雕动手做】有趣好玩的音乐可视化系列小项目(10)---WS2812硬板屏
  项目之四:256位全彩闪动音乐频谱灯(8x32位WS2812硬屏)
  实验视频剪辑
https://v.youku.com/v_show/id_XNTgyNzE0MTM3Mg==.html?spm=a2hcb.playlsit.page.1
3386
22
  实验场景动态图
3386
23
  项目之五:快速哈特利变换FHT音乐反应灯板(8X8位WS2812硬屏)
  实验开源代码
#define qsubd(x, b) ((x>b)?wavebright:0)                     // A digital unsigned subtraction macro. if result <0, then => 0. Otherwise, take on fixed value.
#define qsuba(x, b) ((x>b)?x-b:0)                            // Unsigned subtraction macro. if result <0, then => 0.
#define wavebright 128                                        // qsubd result will be this value if subtraction is >0.
#include "FastLED.h"                                          // FastLED library. Preferably the latest copy of FastLED 2.1.
#if FASTLED_VERSION < 3001000
#error "Requires FastLED 3.1 or later; check github for latest code."
#endif
// Fixed definitions cannot change on the fly.
#define LED_DT 6                                             // Data pin to connect to the strip.
//#define LED_CK 11                                             // Clock pin for APA102 or WS2801
#define COLOR_ORDER GRB                                       // It's GRB for WS2812
#define LED_TYPE WS2812B                                       // What kind of strip are you using (APA102, WS2801 or WS2812B)
#define NUM_LEDS 64                                       // Number of LED's.
// Initialize changeable global variables.
uint8_t max_bright = 255;                                     // Overall brightness definition. It can be changed on the fly.
struct CRGB leds[NUM_LEDS];                                   // Initialize our LED array.
#define LOG_OUT 1
#define FHT_N 256                                             // Set to 256 point fht.
#define inputPin A0
//#define potPin A4
#include <FHT.h>                                              // FHT library
uint8_t hueinc = 0;                                               // A hue increment value to make it rotate a bit.
uint8_t micmult = 25;
uint8_t fadetime = 900;
uint8_t noiseval = 25;                                        // Increase this to reduce sensitivity. 30 seems best for quiet
void setup() {
  analogReference(EXTERNAL);                                  // Connect 3.3V to AREF pin for any microphones using 3.3V
  Serial.begin(9600);                                        // use the serial port
  LEDS.addLeds<LED_TYPE, LED_DT, COLOR_ORDER>(leds, NUM_LEDS);
  //  LEDS.addLeds<LED_TYPE, LED_DT, LED_CK, COLOR_ORDER>(leds, NUM_LEDS);
  FastLED.setBrightness(max_bright);
  set_max_power_in_volts_and_milliamps(5, 300);               // FastLED Power management set at 5V, 500mA.
void loop() {
  //    noiseval = map(analogRead(potPin), 0, 1023, 16, 48);          // Adjust sensitivity of cutoff.
  EVERY_N_MILLISECONDS(13) {
    fhtsound();
  show_at_max_brightness_for_power();
  Serial.println(LEDS.getFPS(), DEC);         // Display frames per second on the serial monitor.
  Serial.println(" ");          // Display frames per second on the serial monitor.
  Serial.println(analogRead(inputPin));       // print as an ASCII-encoded decimal         */
void fhtsound() {
  // hueinc++;                                                   // A cute little hue incrementer.
  GetFHT();                                                   // Let's take FHT_N samples and crunch 'em.
  for (int i = 0; i < NUM_LEDS; i++) {                        // Run through the LED array.
    int tmp = qsuba(fht_log_out[2 * i + 2], noiseval);       // Get the sample and subtract the 'quiet' normalized values, but don't go < 0.
    if (tmp > (leds[i].r + leds[i].g + leds[i].b) / 2)          // Refresh an LED only when the intensity is low
      leds[i] = CHSV((i * 4) + tmp * micmult, 255, tmp * micmult); // Note how we really cranked up the tmp value to get BRIGHT LED's. Also increment the hue for fun.
    leds[i].nscale8(fadetime);                                     // Let's fade the whole thing over time as well.
} // fhtsound()
void GetFHT() {
  cli();
  for (int i = 0 ; i < FHT_N ; i++) fht_input[i] = analogRead(inputPin);
  sei();
  fht_window();                                               // Window the data for better frequency response.
  fht_reorder();                                              // Reorder the data before doing the fht.
  fht_run();                                                  // Process the data in the fht.
  fht_mag_log();
} // GetFHT()
3386
24
  实验视频剪辑
https://v.youku.com/v_show/id_XNTgwODY2NzkzMg==.html?spm=a2hcb.playlsit.page.1
3386
  实验场景动态图
3386
26
  项目之六:快速哈特利变换FHT音乐反应灯板(8X32位WS2812硬屏)
  实验开源代码
  项目之六:快速哈特利变换FHT音乐反应灯板(8X32位 WS2812硬屏)
#endif
#define NUM_LEDS 256                                       // Number of LED's.
#define LOG_OUT 1
#define inputPin A0
//#define potPin A4
void setup() {
  FastLED.setBrightness (22);
void loop() {
    fhtsound();
void fhtsound() {
} // fhtsound()
void GetFHT() {
  cli();
  sei();
  fht_mag_log();
} // GetFHT()
3386
27
  实验视频剪辑
https://v.youku.com/v_show/id_XNTgyNzY0NTc5Mg==.html?spm=a2hcb.playlsit.page.1
3386
28
  实验场景动态图
3386
29
  项目之七:基于虚拟轮生成颜色的音乐可视化(8X32位 WS2812硬屏)
#include <FastLED.h>
// LED LIGHTING SETUP
#define LED_PIN     6
#define NUM_LEDS    480
#define BRIGHTNESS  30
#define LED_TYPE    WS2811
#define UPDATES_PER_SECOND 100
// AUDIO INPUT SETUP
int audio = A0;
// STANDARD VISUALIZER VARIABLES
int loop_max = 0;
int k = 255; // COLOR WHEEL POSITION
int decay = 0; // HOW MANY MS BEFORE ONE LIGHT DECAY
int decay_check = 0;
long pre_react = 0; // NEW SPIKE CONVERSION
long react = 0; // NUMBER OF LEDs BEING LIT
long post_react = 0; // OLD SPIKE CONVERSION
// RAINBOW WAVE SETTINGS
int wheel_speed = 4;
void setup()
  delay( 3000 ); // power-up safety delay
  FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.setBrightness(  BRIGHTNESS );
  // CLEAR LEDS
    leds[i] = CRGB(0, 0, 0);
  FastLED.show();
  // SERIAL AND INPUT SETUP
  Serial.begin(115200);
  pinMode(audio, INPUT);
  Serial.println("\nListening...");
CRGB Scroll(int pos) {
  CRGB color (0,0,0);
  if(pos < 85) {
    color.g = 0;
    color.r = ((float)pos / 85.0f) * 255.0f;
    color.b = 255 - color.r;
  } else if(pos < 170) {
    color.g = ((float)(pos - 85) / 85.0f) * 255.0f;
    color.r = 255 - color.g;
    color.b = 0;
  } else if(pos < 256) {
    color.b = ((float)(pos - 170) / 85.0f) * 255.0f;
    color.g = 255 - color.b;
    color.r = 1;
  return color;
void rainbow(){
  for(int i = NUM_LEDS - 1; i >= 0; i--) {
    if (i < react)
      leds[i] = Scroll((i * 256 / 50 + k) % 256);
    else
  FastLED.show();
void loop()
  int audio_input = analogRead(audio); // ADD x2 HERE FOR MORE SENSITIVITY
  if (audio_input > 0)
    pre_react = ((long)NUM_LEDS * (long)audio_input) / 1023L; // TRANSLATE AUDIO LEVEL TO NUMBER OF LEDs
    if (pre_react > react) // ONLY ADJUST LEVEL OF LED IF LEVEL HIGHER THAN CURRENT LEVEL
      react = pre_react;
    Serial.print(audio_input);
    Serial.print(" -> ");
    Serial.println(pre_react);
  rainbow(); // APPLY COLOR
  k = k - wheel_speed; // SPEED OF COLOR WHEEL
  if (k < 0) // RESET COLOR WHEEL
    k = 255;
  // REMOVE LEDs
  decay_check++;
  if (decay_check > decay)
    decay_check = 0;
    if (react > 0)
      react--;
  //delay(1);
3386
实验场景图  动态图
3386
31
  项目之八:通过快速傅里叶变换在ws2812b8*8灯板上显示频谱
#include  "arduinoFFT.h"
#define NUM_LEDS 64
arduinoFFT FFT = arduinoFFT();
#define CHANNEL A0
#define DATA_PIN 6
const uint8_t max_bright = 2;
const uint16_t samples = NUM_LEDS / 4;
const byte halfsamples = samples / 2;
uint8_t gHue;
int value;
double vReal[samples];
double vImag[samples];
char toData[halfsamples];
int pointJump[halfsamples];
int uJump[halfsamples];
int dJump[halfsamples];
int uValue;
int dValue;
int tValue;
int toDown = 0;
uint8_t toDownSpeed = 3;
int pointDown = 0;
uint8_t pointDownSpeed = 9;
void setup(){
  delay(100);
  Serial.println("Ready");
  FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
void loop(){
  FastLED.clear();
  EVERY_N_MILLISECONDS(10) {
    gHue += 10;
  for (int i = 0; i < samples; i++)
    value = analogRead(CHANNEL);
    vReal[i] = value;
    vImag[i] = 0.0;
  FFT.Windowing(vReal, samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
  FFT.Compute(vReal, vImag, samples, FFT_FORWARD);
  FFT.ComplexToMagnitude(vReal, vImag, samples);
  for (int i = 0; i < halfsamples; i++)
    toData[i] = vReal[i + halfsamples / 2];
    toData[i] = constrain(toData[i], 0, 100);
    toData[i] = map(toData[i], 0, 100, 1, 7);
    uValue = toData[i];
    uJump[i]++;
    if (uValue > uJump[i])
      uValue = uJump[i];
    else
      uJump[i] = uValue;
    dValue = uValue;
    toDown++;
    if (toDown % toDownSpeed == 0)
      dJump[i]--;
      toDown = 0;
    if (dValue > pointJump[i])
      dJump[i] = dValue;
    else
      dValue = dJump[i];
    tValue = uValue;
    pointDown++;
    if (pointDown % pointDownSpeed == 0)
      pointJump[i]--;
      pointDown = 0;
    if (tValue > pointJump[i])
      pointJump[i] = tValue;
    else
      tValue = pointJump[i];
    fill_rainbow(leds + 8 * i, uValue, gHue, 30);
    fill_rainbow(leds + 8 * i, dValue, gHue, 30);
    fill_solid(leds + 8 * i + tValue, 1, CRGB::White);
  FastLED.show();
  delay(10);
3386
32
实验场景图  动态图
3386
33
实验的视频记录
https://v.youku.com/v_show/id_XNTg4NTc5NDk1Mg==.html?spm=a2hcb.playlsit.page.1
3386
34
  项目之九:FastLED多彩音乐节奏屏灯
#include<FastLED.h>
#include<MegunoLink.h>
#include<Filter.h>
// define necessary parameters
#define N_PIXELS  64
#define MIC_PIN   A0
#define LED_PIN   6
// the following parameters can be tweaked according to your audio levels
#define NOISE 240
#define TOP   (N_PIXELS+2) // allow the max level to be slightly off scale
#define BRIGHTNESS  34     // a little dim for recording purposes
// declare the LED array
CRGB leds[N_PIXELS];
// define the variables needed for the audio levels
int lvl = 0, minLvl = 0, maxLvl = 300; // tweak the min and max as needed
// instantiate the filter class for smoothing the raw audio signal
ExponentialFilter<long> ADCFilter(5, 0);
void setup() {
  // put your setup code here, to run once:
  // Serial.begin(115200);
  // initialize the LED object
  FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, N_PIXELS).setCorrection(TypicalLEDStrip);
  FastLED.setBrightness(BRIGHTNESS);
void loop() {
  // put your main code here, to run repeatedly:
  // read the audio signal and filter it
  int n, height;
  n = analogRead(MIC_PIN);
  // remove the MX9614 bias of 1.25VDC
  n = abs(1023 - n);
  // hard limit noise/hum
  n = (n <= NOISE) ? 0 : abs(n - NOISE);
  // apply the exponential filter to smooth the raw signal
  ADCFilter.Filter(n);
  lvl = ADCFilter.Current();
  //  // plot the raw versus filtered signals
  //Serial.print(n);
  //Serial.print(" ");
  //Serial.println(lvl);
  // calculate the number of pixels as a percentage of the range
  // TO-DO: can be done dynamically by using a running average of min/max audio levels
  height = TOP * (lvl - minLvl) / (long)(maxLvl - minLvl);
  if (height < 0L) height = 0;
  else if (height > TOP) height = TOP;
  // turn the LEDs corresponding to the level on/off
  for (uint8_t i = 0; i < N_PIXELS; i++) {
    // turn off LEDs above the current level
    if (i >= height) leds[i] = CRGB(0, 0, 0);
    // otherwise, turn them on!
    else leds[i] = Wheel( map( i, 0, N_PIXELS - 1, 30, 150 ) );
  FastLED.show();
CRGB Wheel(byte WheelPos) {
  // return a color value based on an input value between 0 and 255
  if (WheelPos < 85)
    return CRGB(WheelPos * 3, 255 - WheelPos * 3, 0);
  else if (WheelPos < 170) {
    WheelPos -= 85;
    return CRGB(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
    WheelPos -= 170;
    return CRGB(0, WheelPos * 3, 255 - WheelPos * 3);
3386
实验场景图  动态图
3386
36
实验的视频记录
https://v.youku.com/v_show/id_XNTg4ODE1MTMyMA==.html?spm=a2hcb.playlsit.page.1
3386
37
  项目之十:Arduino 和 FastLED多彩音乐灯
#define SAMPLEPERIODUS 200
#define MIC_PIN A0
#define LED_DT 6
uint8_t max_bright = 33;
CRGBPalette16 currentPalette = RainbowColors_p;
CRGBPalette16 targetPalette;
void setup() {
  pinMode(LED_BUILTIN, OUTPUT);
float bassFilter(float sample) {
  static float xv[3] = {0, 0, 0}, yv[3] = {0, 0, 0};
  xv[0] = xv[1]; xv[1] = xv[2];
  xv[2] = sample / 9.1f;
  yv[0] = yv[1]; yv[1] = yv[2];
  yv[2] = (xv[2] - xv[0]) + (-0.7960060012f * yv[0]) + (1.7903124146f * yv[1]);
  return yv[2];
float envelopeFilter(float sample) {
  static float xv[2] = {0, 0}, yv[2] = {0, 0};
  xv[0] = xv[1];
  xv[1] = sample / 160.f;
  yv[0] = yv[1];
  yv[1] = (xv[0] + xv[1]) + (0.9875119299f * yv[0]);
  return yv[1];
float beatFilter(float sample) {
  xv[2] = sample / 7.015f;
  yv[2] = (xv[2] - xv[0]) + (-0.7169861741f * yv[0]) + (1.4453653501f * yv[1]);
  return yv[2];
void loop() {
  unsigned long time = micros();
  float sample, value, envelope, beat, thresh, micLev;
  for (uint8_t i = 0; ; ++i) {
    sample = (float)analogRead(MIC_PIN);
    micLev = ((micLev * 67) + sample) / 68;
    sample -= micLev;
    value = bassFilter(sample);
    value = abs(value);
    envelope = envelopeFilter(value);
    if (i == 200) {
      beat = beatFilter(envelope);
      thresh = 0.02f * 75.;
      if (beat > thresh) {
        digitalWrite(LED_BUILTIN, LOW);
        int strt = random8(NUM_LEDS / 2);
        int ende = strt + random8(NUM_LEDS / 2);
        for (int i = strt; i < ende; i++) {
          uint8_t index = inoise8(i * 30, millis() + i * 30);
          leds[i] = ColorFromPalette(currentPalette, index, 255, LINEARBLEND);
      } else {
        digitalWrite(LED_BUILTIN, HIGH);
      i = 0;
    EVERY_N_SECONDS(5) {
      uint8_t baseC = random8();
      targetPalette = CRGBPalette16(CHSV(baseC + random8(32), 255, random8(128, 255)),
                                    CHSV(baseC + random8(64), 255, random8(128, 255)),
                                    CHSV(baseC + random8(64), 192, random8(128, 255)),
                                    CHSV(baseC + random8(),   255, random8(128, 255)));
    EVERY_N_MILLISECONDS(50) {
      uint8_t maxChanges = 24;
      nblendPaletteTowardPalette(currentPalette, targetPalette, maxChanges);
    EVERY_N_MILLIS(50) {
      fadeToBlackBy(leds, NUM_LEDS, 64);
      FastLED.show();
    for (unsigned long up = time + SAMPLEPERIODUS; time > 20 && time < up; time = micros()) {  }
  } // for i
} // loop()
3386
38
实验的视频记录
优酷:
B站:https://www.bilibili.com/video/BV1L14y157PU/?vd_source=98c6b1fc23b2787403d97f8d3cc0b7e5
3386
39
  【Arduino】168种传感器模块系列实验(资料代码+仿真编程+图形编程)
 实验一百七十七:Wemos D1 R32 ESP32开发板
 项目之四十六:基于虚拟轮生成颜色的256位音乐可视化
#define LED_PIN     23
int audio = 38;
int loop_max = 0;
void setup()
  // CLEAR LEDS
  FastLED.show();
  CRGB color (0,0,0);
  if(pos < 85) {
    color.g = 0;
    color.b = 0;
    color.r = 1;
  return color;
void rainbow(){
    if (i < react)
    else
  FastLED.show();
void loop(){
  int audio_input = analogRead(audio)*5.5; // 在此处调整,以获得更多敏感性
      react = pre_react;
    k = 255;
  // REMOVE LEDs
  decay_check++;
    decay_check = 0;
    if (react > 0)
      react--;
  delay(1);
3386
实验场景图  动态图
