2540|6
多线程问题 [复制链接]
由于电脑上没有安装linux,请问以下程序的运行结果是什么?谢谢
#include
#include
#include
#include
#include
pthread_mutex_t mutex = PTHREAD_MUTEX_INITIALIZER;
int lock_var;
time_t end_time;
int sum;
void pthread1(void *arg);
void pthread2(void *arg);
void pthread3(void *arg);
int main(int argc, char *argv[])
pthread_t id1,id2,id3;
pthread_t mon_th_id;
int ret;
sum=10;
end_time = time(NULL)+10;
pthread_mutex_init(&mutex,NULL);
ret=pthread_create(&id1,NULL,(void *)pthread1, NULL);
if(ret!=0)
perror("pthread cread1");
ret=pthread_create(&id2,NULL,(void *)pthread2, NULL);
if(ret!=0)
perror("pthread cread2");
ret=pthread_create(&id3,NULL,(void *)pthread3, NULL);
if(ret!=0)
perror("pthread cread3");
pthread_join(id1,NULL);
pthread_join(id2,NULL);
pthread_join(id3,NULL);
exit(0);
int i;
while(time(NULL) < end_time)
if(pthread_mutex_lock(&mutex)!=0) //lock
perror("pthread_mutex_lock");
else
printf("pthread1:pthread1 lock the variable\n");
for(i=0;i<2;i++)
sleep(2);
lock_var++;
if(pthread_mutex_unlock(&mutex)!=0) //unlock
perror("pthread_mutex_unlock");
else
printf("pthread1:pthread1 unlock the variable\n");
sleep(1);
int nolock=0;
int ret;
ret=pthread_mutex_trylock(&mutex);//try lock
if(ret==EBUSY)
printf("pthread2:the variable is locked by pthread1\n");
else{
if(ret!=0)
perror("pthread_mutex_trylock");
exit(1);
else
printf("pthread2:pthread2 got lock.The variable is %d\n",lock_var);
if(pthread_mutex_unlock(&mutex)!=0)//unlock
else
printf("pthread2:pthread2 unlock the variable\n");
sleep(1);
int nolock=0;
int ret;
if(ret==EBUSY)
printf("pthread3:the variable is locked by pthread1 or 2\n");
else
if(ret!=0)
exit(1);
else
printf("pthread3:pthread3 got lock.The variable is %d\n",lock_var);
else
printf("pthread3:pthread2 unlock the variable\n");
sleep(3);
友情up  详情 回复 发表于 2009-2-18 13:23
78
友情up
友情up
55
你的电脑会报错。
[user@localhost ~]$ gcc 1.c -o 1
/tmp/ccsWOzKr.o: In function `main':
1.c:(.text+0x63): undefined reference to `pthread_create'
1.c:(.text+0x9c): undefined reference to `pthread_create'
1.c:(.text+0xd5): undefined reference to `pthread_create'
1.c:(.text+0xfd): undefined reference to `pthread_join'
1.c:(.text+0x110): undefined reference to `pthread_join'
1.c:(.text+0x123): undefined reference to `pthread_join'
/tmp/ccsWOzKr.o: In function `pthread2':
1.c:(.text+0x201): undefined reference to `pthread_mutex_trylock'
collect2: ld 返回 1
[user@localhost ~]$
55
报错~~~~
75
友情up
