2855|5
关于用DriverStudio如何开发一个USB摄象头驱动 [复制链接]
我有一部Windows Mobile手机,我想把上面的USB 摄象头变成电脑上的摄象头,自己写驱动,现在手机侧的驱动和程序已经做好,可以通过USB,端点0和1与PC机批传输通信,我在调试的时候使用的PC上的标准USBIO驱动,在PC上写了个应用可以直接预览到手机上的视频,但是我想做个PC上驱动程序的形式,这样就可以在QQ等聊天工具里调用,我看了DriverStudio相关教程,写了一个USB驱动也可以获取手机传来的USB视频流,另外我还看了DriverStudio里面的关于Stream的虚拟摄象头的例子,还有一个CAM1394的例子,但是还是不知如何把Stream和USB驱动整合在一起变成一个USB摄象头驱动,高手帮帮忙啊
我尝试在Stream例子的KStreamMinidriver类的OnCreateAdapter方法中创建一个PNP的USB传输类,但是一插入手机电脑就蓝屏了,我觉得这样开发的思路是不是有问题,请高手指点一下!
NTSTATUS VideoCaptureDriver::OnCreateAdapter(
    PORT_CONFIGURATION_INFORMATION* pConfigInfo,
    PVOID AdapterStorage,
    PHW_STREAM_REQUEST_BLOCK pSrb
    NTSTATUS ReturnValue = STATUS_SUCCESS;
    T << TraceInfo << "VideoCaptureDriver::OnCreateAdapter -- Start\n";
    // -- since our test driver DOESN'T have hardware, this BETTER be 0! --
    if (pConfigInfo->NumberOfAccessRanges != 0)
        T << TraceError << "VideoCaptureDriver::OnCreateAdapter -- Illegal port configuration info\n";
        return (pSrb->Status = STATUS_NO_SUCH_DEVICE);
    // -- construct the adapter using the AdapterStorage memory allocated
    //        by the Class Driver --
    m_pAdapter = new (AdapterStorage) VideoCaptureAdapter(this, pConfigInfo);
    // -- initialize the adapter object and its member streams! --
    if (NULL != m_pAdapter)
        m_pAdapter->Initialize();
    else
        T << TraceError << "VideoCaptureDriver::OnCreateAdapter -- Adapter constructor failed!\n";
        ReturnValue = STATUS_IO_DEVICE_ERROR;
    T << TraceInfo << TraceHex << "VideoCaptureDriver::OnCreateAdapter -- End. Status is " << (ULONG)ReturnValue << "\n";
    if (ReturnValue!=STATUS_SUCCESS) return ReturnValue;
    UsbTransferDevice * pDevice = new (
            NULL,
            FILE_DEVICE_UNKNOWN,
            NULL,
            0,
            DO_DIRECT_IO
        UsbTransferDevice(Pdo, m_Unit);
    if (pDevice == NULL)
        T << "Error creating device UsbTransferDevice" << (ULONG) m_Unit << EOL;
        return STATUS_INSUFFICIENT_RESOURCES;
    NTSTATUS status = pDevice->ConstructorStatus();
    if ( !NT_SUCCESS(status) )
        T << "Error constructing device UsbTransferDevice" << (ULONG) m_Unit << " status " << (ULONG) status << EOL;
        delete pDevice;
    else
        m_Unit++;
    return status;
这个得用RAPI吧?  详情 回复 发表于 2009-10-14 08:36
这个我也不知道,呵呵,我觉得你已经是高手了,真的。支持
学习......
up
施主努力
45
这个得用RAPI吧?
