顶起
打印信息后,比较休眠前和唤醒后:CLKCON CLKDIVN CLKSLOW LOCKTIME MPLLCON UPLLCON 寄存器值都是一致的。
在NANDInit()中增加了NANDReset部分,效果还是一样的。
怀疑是唤醒后SDRAM配置不正确。
哪位大侠指点指点,休眠和唤醒时对SDRAM的配置要注意什么
startup.s文件
LEAF_ENTRY OALCPUPowerOff
; 1. Push SVC state onto our stack
stmdb sp!, {r4-r12}
stmdb sp!, {lr}
; 2. Save MMU & CPU Register to RAM
ldr r3, =SLEEPDATA_BASE_VIRTUAL ; base of Sleep mode storage
ldr r2, =Awake_address ; store Virtual return address
str r2, [r3], #4
mrc p15, 0, r2, c1, c0, 0 ; load r2 with MMU Control
ldr r0, =MMU_CTL_MASK ; mask off the undefined bits
bic r2, r2, r0
str r2, [r3], #4 ; store MMU Control data
mrc p15, 0, r2, c2, c0, 0 ; load r2 with TTB address.
ldr r0, =MMU_TTB_MASK ; mask off the undefined bits
bic r2, r2, r0
str r2, [r3], #4 ; store TTB address
mrc p15, 0, r2, c3, c0, 0 ; load r2 with domain access control.
str r2, [r3], #4 ; store domain access control
str sp, [r3], #4 ; store SVC stack pointer
mrs r2, spsr
str r2, [r3], #4 ; store SVC status register
mov r1, #Mode_FIQ:OR:I_Bit:OR:F_Bit ; Enter FIQ mode, no interrupts
msr cpsr, r1
mrs r2, spsr
stmia r3!, {r2, r8-r12, sp, lr} ; store the FIQ mode registers
mov r1, #Mode_ABT:OR:I_Bit:OR:F_Bit ; Enter ABT mode, no interrupts
msr cpsr, r1
mrs r0, spsr
stmia r3!, {r0, sp, lr} ; store the ABT mode Registers
mov r1, #Mode_IRQ:OR:I_Bit:OR:F_Bit ; Enter IRQ mode, no interrupts
msr cpsr, r1
mrs r0, spsr
stmia r3!, {r0, sp, lr} ; store the IRQ Mode Registers
mov r1, #Mode_UND:OR:I_Bit:OR:F_Bit ; Enter UND mode, no interrupts
msr cpsr, r1
mrs r0, spsr
stmia r3!, {r0, sp, lr} ; store the UND mode Registers
mov r1, #Mode_SYS:OR:I_Bit:OR:F_Bit ; Enter SYS mode, no interrupts
msr cpsr, r1
stmia r3!, {sp, lr} ; store the SYS mode Registers
mov r1, #Mode_SVC:OR:I_Bit:OR:F_Bit ; Back to SVC mode, no interrupts
msr cpsr, r1
; 3. do Checksum on the Sleepdata
ldr r3, =SLEEPDATA_BASE_VIRTUAL ; get pointer to SLEEPDATA
ldr r2, =0x0
ldr r0, =(SLEEPDATA_SIZE-1) ; get size of data structure (in words)
ldr r1, [r3], #4
and r1, r1, #0x1
mov r1, r1, ROR #31
add r2, r2, r1
subs r0, r0, #1
bne %b30
ldr r0, =vGPIOBASE
;;;add r2, r2, #1 ; test checksum of the Sleep data error
str r2, [r0, #oGSTATUS3] ; Store in Power Manager Scratch pad register
ldr r0, =vGPIOBASE
ldr r1, =0x550a
str r1, [r0, #oGPFCON]
ldr r1, =0x30
str r1, [r0, #oGPFDAT]
; 4. Interrupt Disable
ldr r0, =vINTBASE
mvn r2, #0
str r2, [r0, #oINTMSK]
str r2, [r0, #oSRCPND]
str r2, [r0, #oINTPND]
;; 5. Cache Flush
bl OALClearUTLB
bl OALFlushICache
ldr r0, = (DCACHE_LINES_PER_SET - 1)
ldr r1, = (DCACHE_NUM_SETS - 1)
ldr r2, = DCACHE_SET_INDEX_BIT
ldr r3, = DCACHE_LINE_SIZE
bl OALFlushDCache
; 6. Setting Wakeup External Interrupt(EINT0,1,2) Mode
ldr r0, =vGPIOBASE
ldr r1, =0x550a
;ldr r1, =0x0180FCBA
;str r1, [r0, #oGPGCON]
; 7. Go to Power-Off Mode
ldr r0, =vMISCCR ; hit the TLB
ldr r0, [r0]
ldr r0, =vCLKCON
ldr r0, [r0]
ldr r0, =vREFRESH
ldr r1, [r0] ; r1=rREFRESH
orr r1, r1, #(1 << 22)
ldr r2, =vMISCCR
ldr r3, [r2]
orr r3, r3, #(3<<17) ; Make sure that SCLK0:SCLK->0, SCLK1:SCLK->0, SCKE=L during boot-up
bic r3, r3, #(7<<20)
orr r3, r3, #(6<<20)
ldr r4, =vCLKCON
ldr r5, =0x1ffff8 ; Power Off Mode
; Sometimes it is not working in cache mode. So I modify to jump to ROM area.
;;; ldr r6, =0x92000000 ; make address to 0x9200 0020
;;; add r6, r6, #0x20 ;
;;; mov pc, r6 ; jump to Power off code in ROM
b SelfRefreshAndPowerOff
ALIGN 32 ; for I-Cache Line(32Byte, 8 Word)
SelfRefreshAndPowerOff ; run with Instruction Cache's code
str r1, [r0] ; Enable SDRAM self-refresh
str r3, [r2] ; MISCCR Setting
str r5, [r4] ; Power Off !!
b .
复制代码
