4393|8
基于AVRmega16d单片机的简易频率测量仪 [复制链接]
这是学校给的课题 搞很久了还是有错误 谁能帮帮忙修改一下啊
  1. #include
  2. #include
  3. #define uchar unsigned char
  4. #define uint unsigned int
  5. #define CON 1000
  6. uchar Flag=0;
  7. //uchar Table[20]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,
  8. //               0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
  9. uchar Table[20]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
  10.                  0x80,0x90    };
  11. uchar Data[4]={0,0,0,0};
  12. uint CNT1;
  13. uint CNT2;
  14. uint CNT=100;
  15. void DelayMs(uint i)
  16. {
  17.    uint j;
  18.    for(;i!=0;i--)
  19.        {
  20.           for(j=2000;j!=0;j--){;}
  21.        }
  22. }
  23. void Pre_Display()
  24. {
  25.    uchar i;
  26.    for(i=0;i<16;i++)
  27.    {
  28.       PORTB=0x00;
  29.       PORTA=Table[i];
  30.       DelayMs(100);
  31.    }
  32. }
  33. void Display(uchar *p)
  34. {
  35.    uchar i,sel=0x08;
  36.    for(i=0;i<4;i++)
  37.    {
  38.       PORTC=~sel;
  39.       PORTA=Table[p[i]];
  40.       DelayMs(2);
  41.       sel=sel>>1;
  42.    }
  43.
  44. }
  45. void HZ(uint i,uchar *p)
  46. {
  47.       uint TEM;
  48.       p[0]=CON/i;
  49.       TEM=CON%i;
  50.       TEM=TEM*10;
  51.
  52.       p[1]=TEM/i;
  53.       TEM=TEM%i;
  54.       TEM=TEM*10;
  55.
  56.       p[2]=TEM/i;
  57.       TEM=TEM%i;
  58.       TEM=TEM*10;
  59.
  60.       p[3]=TEM/i;
  61.
  62. }
  63. void Init_IO()
  64. {
  65.       DDRA=0xFF;
  66.       PORTA=0xFF;
  67.       DDRC=0xFF;
  68.       PORTC=0xFF;
  69.       DDRD=0x00;
  70.       PORTD=0x00;
  71. }
  72. void Init_Timer1()
  73. {
  74.     TIMSK=TIMSK|0x20;
  75.     TCCR1B=0x82;
  76.     TIFR=0x20;
  77.     SREG=SREG&0x7f;
  78. }
  79. void main()
  80. {
  81.    uchar i;
  82.    uint TEMP;
  83.    Init_IO();
  84.    PORTA=0xff;
  85.    PORTC=0xf0;
  86.    DelayMs(300);
  87.    PORTC=0xff;
  88.    Pre_Display();
  89.
  90.    PORTC=0xff;
  91.    Init_Timer1();
  92.    while(1){
  93.             while(TIFR&0x20)//说明发生了下降沿跳变
  94.               {
  95.                   //TIFR=TIFR&0xDF;  //标志位清零
  96.                   //TEMP=ICR1L;
  97.                   //CNT2=(ICR1H<<8)+TEMP;
  98.                   TIFR|=0x20;
  99.                   CNT=ICR1L;
  100.                   CNT2=(ICR1H<<8)+ICR1L;
  101.                   CNT=CNT2-CNT1;
  102.                   Flag++;
  103.               }
  104.               if(Flag==2)
  105.                   {
  106.                      Flag=0;
  107.                      HZ(CNT,Data);
  108.                      for(i=0;i<100;i++)
  109.                               Display(Data);
  110.
  111.               CNT=0;CNT1=0;CNT2=0;
  112.                  }
  113.             }
  114.
  115.
  116.
  117.
  118.
  119. }
复制代码
问一下楼主,那个CON是做什么用的,测出频率直接传送就可以了啊    详情 回复 发表于 2012-3-13 18:07
77
      uint TEM;
      p[0]=CON/i;
      TEM=CON%i;
      TEM=TEM*10;
      p[1]=TEM/i;
      TEM=TEM%i;
      TEM=TEM*10;
      p[2]=TEM/i;
      TEM=TEM%i;
      TEM=TEM*10;
      p[3]=TEM/i;
这里为什么要这么写?
99
说出具体的错误,到底是程序编译不过还是?结果不对?
引用 1 楼 c_rabbit 的回复:
? ? ? uint TEM;
? ? ? p[0]=CON/i;
? ? ? TEM=CON%i;
? ? ? TEM=TEM*10;
? ? ? p[1]=TEM/i;
? ? ? TEM=TEM%i;
? ? ? TEM=TEM*10;
? ? ? p[2]=TEM/i;
? ? ? TEM=TEM%i;
? ? ? TEM=TEM*10;
? ? ? p[3]=TEM/i;
这里为什么要这么写?
因为  将周期转换成频率后在显示出来  i/CON还要取倒数
测量的频率范围是多大的?
63
错误是什么?
你写的程序没有注释,这是一个非常不好的习惯,不然别人很难理解你的意思,不信你自己过了一段时间后再来看,同样会对代码非常陌生。
2.
没将自己的问题说清楚,起码应该说清楚是什么问题?现象是什么?在什么情况下会发生?
现在你就贴了一段代码,然后说我有问题,神仙也回答不了你这样的问题.
我没用过你说的MCU,就猜测一下你的代码含义。
void HZ(uint i,uchar *p)//如果i等于0是什么后果?
      uint TEM;
      p[0]=CON/i;
      TEM=CON%i;
      TEM=TEM*10;
      p[1]=TEM/i;
      TEM=TEM%i;
      TEM=TEM*10;
      p[2]=TEM/i;
      TEM=TEM%i;
      TEM=TEM*10;
      p[3]=TEM/i;
void Init_Timer1()//具体是什么工作模式?内部计时?外部捕获?外部比较?
    TIMSK=TIMSK|0x20;
    TCCR1B=0x82;
    TIFR=0x20;
    SREG=SREG&0x7f;
void main()
   uchar i;
   uint TEMP;
   Init_IO();//初始化IO
   PORTA=0xff;//PORTA输出11111111
   PORTC=0xf0;//PORTC输出11110000,应该是低四位为0表示所对应的数码管工作
   DelayMs(300);//延时约300毫秒,这个时间是循环延时实现,可能不准
   PORTC=0xff;//PORTC输出11111111
   Pre_Display();//四个数码管同时依次显示一段开机信息
   Init_Timer1();//初始化TIMER1,好像你打开了中断,但你没有用中断来测试,是循环查询方式,中断服务函数都没有挂到TIMER1上去,编译平台挂中断有特定的方式,可以参考其样例代码,如果MCU有中断总使能global enable的控制位应一并设好
   while(1){
                  //TEMP=ICR1L;
                  TIFR|=0x20;
                  CNT=ICR1L;
                  CNT=CNT2-CNT1;//你本意是想第二次跳变时TIMER里面的计时器值减去第一次时的值吗?如果是这样现在你的表达式永远都是近似ICR1H中的内容CNT=CNT2-CNT1=((ICR1H<<8)+ICR1)-LICR1L
                  Flag++;
              if(Flag==2)//你是想计算两个低跳变脉冲之间的时间间隔?
                     Flag=0;
                     HZ(CNT,Data);
                     for(i=0;i<100;i++)
                              Display(Data);
//建议改为(下面的代码并不可靠,只是供你做参考)
//if(Flag@1)//取一次TIMER值
//  CNT1==(ICR1H<<8)+ICR1L;//这样取到的值并不可靠,比如当前ICR1H_ICR1L为0x00_0xFF,就在读取ICR1H之后TIMER加一,变成了0x01_0x00,但程序读到的值是0x00_0x00,出错
//else//取下一次TIMER值
//  CNT2==(ICR1H<<8)+ICR1L;
//  CNT=CNT2-CNT1;//两次相减得到时间差,这么没考虑溢出等问题
//HZ(CNT,Data);
//Display(Data);
问题还需要你自己解决,思维一定要周全。
91
  1. #include
  2. #include
  5. #define CON 1000
  6. uchar Flag=0;
  10.                  0x80,0x90    };
  12. uint CNT1;
  13. uint CNT2;
  14. uint CNT=100;
  16. {
  17.    uint j;
  18.    for(;i!=0;i--)
  19.        {
  21.        }
  22. }
  24. {
  25.    uchar i;
  27.    {
  28.       PORTB=0x00;
  29.       PORTA=Table[i];
  30.       DelayMs(100);
  31.    }
  32. }
  34. {
  37.    {
  38.       PORTC=~sel;
  40.       DelayMs(2);
  41.       sel=sel>>1;
  42.    }
  43.
  44. }
  46. {
  47.       uint TEM;
  48.       p[0]=CON/i;
  49.       TEM=CON%i;
  50.       TEM=TEM*10;
  51.
  52.       p[1]=TEM/i;
  53.       TEM=TEM%i;
  54.       TEM=TEM*10;
  55.
  56.       p[2]=TEM/i;
  57.       TEM=TEM%i;
  58.       TEM=TEM*10;
  59.
  60.       p[3]=TEM/i;
  61.
  62. }
  63. void Init_IO()
  64. {
  65.       DDRA=0xFF;
  66.       PORTA=0xFF;
  67.       DDRC=0xFF;
  68.       PORTC=0xFF;
  69.       DDRD=0x00;
  70.       PORTD=0x00;
  71. }
  73. {
  75.     TCCR1B=0x82;
  76.     TIFR=0x20;
  77.     SREG=SREG&0x7f;
  78. }
  79. void main()
  80. {
  81.    uchar i;
  82.    //uint TEMP;
  83.    Init_IO();
  84.    PORTA=0xff;
  85.    PORTC=0xf0;
  86.    DelayMs(300);
  87.    PORTC=0xff;
  88.    Pre_Display();
  89.
  90.    PORTC=0xff;
  91.    Init_Timer1();
  92.    while(1){
  94.               {
  96.                   //TEMP=ICR1L;
  98.
  99.                   TIFR|=0x20;
  100.                   CNT=ICR1L;
  101.                   CNT2=(ICR1H<<8)+CNT;
  102.                   CNT=CNT2-CNT1;
  103.                   Flag++;
  104.               }
  105.               if(Flag==2)
  106.                   {
  107.                      Flag=0;
  108.                      HZ(CNT,Data);
  109.                      for(i=0;i<100;i++)
  110.                               Display(Data);
  111.
  112.               CNT=0;CNT1=0;CNT2=0;
  113.                  }
  114.             }
  115.
  116.
  117.
  118.
  119.
  120. }
复制代码
感谢 楼上的 指教 啊  你的理解是对的 以后是应该加注释
频率应该是一个固定不变的数 但是我这里怎总是不停的变化啊 仿真软件
上溢出怎么解决啊  溢出为0了
频率计设计
