4255|3
67
PB编译,帮我看一下,这是什么错误啊(Unknown memory type found 'XIPKERNEL') [复制链接]
帮我看一下,这是什么错误啊
Error: Unknown memory type found 'XIPKERNEL'
nk.exe D:\WINCE500\PBWorkspaces\JZ4750\RelDir\DRACO_MIPSII_Release\kern.exe XIPKERNEL
Windows CE ROM Image Builder v4.0.000 Copyright (c) Microsoft Corporation
Built: Jun 16 2004 15:09:27
SH
Error: failed setting line
makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec).
bib文件给粘贴一下呗  详情 回复 发表于 2009-10-13 20:35
59
使用multi bin的时候会有 xipkernel,要加入BINFS组件,
如果想使用single bin的话你看下你的环境变量里是否使用了multi bin
IF BSP_NONANDFS !
; File system drivers
   ; This is needed in the NK region because it is needed by BINFS
   ; to load other regions
;   smflash.dll                        $(_FLATRELEASEDIR)\smflash.dll                        NK SH
; block driver that binfs interfaces with
    BIBDrv.dll                $(_FLATRELEASEDIR)\BIBDrv.dll           XIPKERNEL  SH
ENDIF ; BSP_NONANDFS
有没有类似的这样一段?
在.bat文件中set BSP_NONANDFS=1就可以了
64
bib文件给粘贴一下呗
