2611|3
47
串口空闲中断不能清理问题-已解决 [复制链接]
USART_ClearITPendingBit( UART4, USART_IT_IDLE);
这个用法是错误的!
  • * [url=home.php?mod=space&uid=159083]@brief[/url] Clears the USARTx's interrupt pending bits.
  • * @param USARTx: Select the USART or the UART peripheral.
  • * This parameter can be one of the following values:
  • * USART1, USART2, USART3, UART4 or UART5.
  • * @param USART_IT: specifies the interrupt pending bit to clear.
  • * [url=home.php?mod=space&uid=1238002]@arg[/url] USART_IT_CTS: CTS change interrupt (not available for UART4 and UART5)
  • * @arg USART_IT_LBD: LIN Break detection interrupt
  • * @arg USART_IT_TC: Transmission complete interrupt.
  • * @arg USART_IT_RXNE: Receive Data register not empty interrupt.
  • * @note
  • * - PE (Parity error), FE (Framing error), NE (Noise error), ORE (OverRun
  • * error) and IDLE (Idle line detected) pending bits are cleared by
  • * software sequence: a read operation to USART_SR register
  • * (USART_GetITStatus()) followed by a read operation to USART_DR register
  • * (USART_ReceiveData()).
  • * - RXNE pending bit can be also cleared by a read to the USART_DR register
  • * - TC pending bit can be also cleared by software sequence: a read
  • * operation to USART_SR register (USART_GetITStatus()) followed by a write
  • * operation to USART_DR register (USART_SendData()).
  • * - TXE pending bit is cleared only by a write to the USART_DR register
  • * (USART_SendData()).
  • * @retval None
  • void USART_ClearITPendingBit(USART_TypeDef* USARTx, uint16_t USART_IT)
从一下的库函数注释来开,这个函数可供清除的中断源 只有
而清除PE、FE、NE、ORE、IDLE需要读取 SR 与 DR寄存器
以下为正确的串口中断处理
  • void UART4_IRQHandler(void)
  • u8 res;
  • if(USART_GetITStatus(UART4,USART_IT_RXNE))
  • res = USART_ReceiveData(UART4);
  • uart4Buff[uart4rs++] = res;
  • if(uart4rs >= sizeof(uart4Buff))
  • uart4rs = 0;
  • else if(USART_GetITStatus(UART4, USART_IT_IDLE))
  • res = UART4->SR;
  • res = UART4->DR;
积累错误...
此帖出自stm32/stm8论坛
谢谢分享。   详情 回复 发表于 2021-6-25 11:42
赞赏
查看全部赞赏
点赞(1) 关注
1930
感谢分享经验!
此帖出自stm32/stm8论坛
管理员
谢谢分享。
此帖出自stm32/stm8论坛
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
加油!在电子行业默默贡献自己的力量!:)
谢谢分享。
此帖出自stm32/stm8论坛
【直播时间】5月28日(周三)上午10:00
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 11
