s3c6410的nandflash分区问题,格式化binfs,exfat破坏了
现在在ut的开发板上学习,想吧nandflash的分区方式改一下:
256MB flash
------ bootloader
------ TOC
------ eboot
------ MBR
------ nk.bin, //binfs
------ exfat //从80M后全部是exfat
原来有个函数是BP_LowLevelFormat,格式化从mbr后面的区域,现在分为2个函数:
/*格式化binfs*/
BOOL BP_LowLevelFormatBINFS(DWORD dwStartBlock, DWORD dwNumBlocks,DWORD dwFlags)
dwNumBlocks = min (dwNumBlocks, g_FlashInfo.dwNumBlocks);
RETAILMSG(1,(TEXT("Enter LowLevelFormat [0x%x, 0x%x].\r\n"), dwStartBlock, dwStartBlock + dwNumBlocks - 1));
// Erase all the flash blocks.
if (IsValidMBR())
RETAILMSG (1, (TEXT("is mbr.\r\n\r\n")));
//如有MBR的话,只格式化binfs
if (!EraseBlocks(dwStartBlock+1, dwNumBlocks -1, dwFlags))
return(FALSE);
else
//不存在MBR,格式化mbr和binfs
if (!EraseBlocks(dwStartBlock, dwNumBlocks, dwFlags))
return(FALSE);
// Determine first good starting block
while (IS_BLOCK_UNUSABLE (dwStartBlock) && dwStartBlock < g_FlashInfo.dwNumBlocks) {
dwStartBlock++;
if (dwStartBlock >= g_FlashInfo.dwNumBlocks)
RETAILMSG(1,(TEXT("BP_LowLevelFormat: no good blocks\r\n")));
return FALSE;
g_dwMBRSectorNum = dwStartBlock * g_FlashInfo.wSectorsPerBlock;
// Create an MBR.
CreateMBR();
RETAILMSG (1, (TEXT("Done.\r\n\r\n")));
return(TRUE);
/*格式化fat*/
BOOL BP_LowLevelFormatFAT(DWORD dwFATStartBlock, DWORD dwFlags)
DWORD dwNumBlocks = 0;
if(g_FlashInfo.dwNumBlocks < dwFATStartBlock)
return(FALSE);
dwNumBlocks = g_FlashInfo.dwNumBlocks - dwFATStartBlock;
RETAILMSG(1,(TEXT("Enter FAT Format [0x%x, 0x%x].\r\n"), dwFATStartBlock,g_FlashInfo.dwNumBlocks));
if (!EraseBlocks(dwFATStartBlock, dwNumBlocks, dwFlags))
return(FALSE);
while (IS_BLOCK_UNUSABLE (dwFATStartBlock) && dwFATStartBlock < g_FlashInfo.dwNumBlocks) {
dwFATStartBlock++;
if (dwFATStartBlock >= g_FlashInfo.dwNumBlocks)
RETAILMSG(1,(TEXT("FAT Format: no good blocks\r\n")));
return FALSE;
return(TRUE);
吧bootloader中的格式化改了下,
// Images start after OEM Reserved Blocks
#define IMAGE_START_BLOCK RESERVED_BOOT_BLOCKS
#define IMAGE_START_SECTOR BLOCK_TO_SECTOR(IMAGE_START_BLOCK)
//这个参数是定义预览 block 的数量,默认是NBOOT + TOC + EBOOT,屏蔽前面80M空间
//nk.bin不要超过64Mb
#define FAT_START_BLOCK SECTOR_TO_BLOCK(FILE_TO_SECTOR_SIZE(0x5000000))
#define FAT_START_SECTOR BLOCK_TO_SECTOR(FAT_START_BLOCK)
// 格式化FAT区域
if ( !BP_LowLevelFormatFAT(FAT_START_BLOCK,FORMAT_SKIP_BLOCK_CHECK) )
OALMSG(OAL_ERROR, (TEXT("ERROR: BootMonitor: Low-level boot media format failed.\r\n")));
continue;
//格式化Binfs区域
if ( !BP_LowLevelFormatBINFS(IMAGE_START_BLOCK,FAT_START_BLOCK - IMAGE_START_BLOCK ,FORMAT_SKIP_BLOCK_CHECK) )
continue;
现在发现格式化binfs后,启动后
[FMD] FMD_GetInfo() : NUMBLOCKS = 2048(0x800), SECTORSPERBLOCK = 64(0x40), BYTESPERSECTOR = 2048(0x800)
[FMD:ERR] FMD_OEMIoControl() : Unknown IOCTL (0x00071c24)
MECC Uncorrectable error(0x38d)
大家看看这个是哪个地方出现问题了?为什么单单格式化binfs区域,fat怎么会被破坏了
谢谢!
