6846|4
65
s3c2416 sd interface [复制链接]
This register is used to store responses from SD cards.
Register Address R/W Description Reset Value
RSPREG0_0 0X4AC00010 ROC Response Register 0 (Channel 0) 0x0
RSPREG1_0 0X4AC00014 ROC Response Register 1 (Channel 0) 0x0
RSPREG2_0 0X4AC00018 ROC Response Register 2 (Channel 0) 0x0
RSPREG3_0 0X4AC0001C ROC Response Register 3 (Channel 0) 0x0
RSPREG0_1 0X4A800010 ROC Response Register 0 (Channel 1) 0x0
RSPREG1_1 0X4A800014 ROC Response Register 1 (Channel 1) 0x0
RSPREG2_1 0X4A800018 ROC Response Register 2 (Channel 1) 0x0
RSPREG3_1 0X4A80001C ROC Response Register 3 (Channel 1) 0x0
Name Bit Description Initial Value
CMDRSP [127:0] Command Response
The Table below describes the mapping of command responses from
the SD Bus to this register for each response type. In the table, R[]
refers to a bit range within the response data as transmitted on the SD
Bus, REP[] refers to a bit range within the Response register.
128-bit Response bit order : {RSPREG3, RSPREG2, RSPREG1,
RSPREG0}
Table 20-3. Response Bit Definition for Each Response Type.
Kind of Response Meaning of Response Response Field Response Register
R1, R1b (normal response)  Card Status                    R [39:8] REP [31:0]
R1b (Auto CMD12 response)  Card Status for Auto CMD12     R [39:8] REP [127:96]
R2 (CID, CSD register)     CID or CSD reg. incl.          R [127:8] REP [119:0]
R3 (OCR register)          OCR register for memory        R [39:8] REP [31:0]
R4 (OCR register)          OCR register for I/O etc       R [39:8] REP [31:0]
R5,R5b SDIO response                                      R [39:8] REP [31:0]
R6 (Published RCA response) New published RCA[31:16] etc  R [39:8] REP [31:0]
R7 ?                                                      R [39:8] REP [31:0]
我对reponse的内容 也就是这32bit的值很不清楚,请知道的人提醒下,谢谢
看看我们的上S3C2416模块吧: ◆ 全面替代S3C2440,且性价比更优 ◆ 模块背面无任何器件,方便直接贴焊或通过插针与底板相连 ◆ 商业级(0°~70°)、工业级(-40°~85°) ◆ 微尺寸(40x40x4mm)、低价格(千片价  详情 回复 发表于 2009-8-14 14:43
看来这部分了解的人比较少,先留着
以后探讨!
81
什么意思?
引用 2 楼 goodlinux 的回复:
什么意思?
就是我看这帖子没人搭理
goodlinux帮忙说说吧
看看我们的上S3C2416模块吧:
◆ 微尺寸(40x40x4mm)、低价格(千片价<150元)
◆ 高性能(400MHz ARM9)、接口丰富(见上图接口框图)
◆ 可接多种尺寸屏,最大分辨率800x600,带2D加速动画显示更流畅
◆ 提供WINCE5.0、LINUX2.6系统,用户只需专注应用无需关心底层及驱动
◆ 接受定制服务,可快速定制WIFI、GPRS/3G、GPS、Zigbee、CAN、蓝牙、多串口、矩阵键盘等接口
◆ 适用于工控、电力、通讯、医疗、媒体、安防、车载、金融、消费电子、手持设备、教学等领域用作控制板、终端、POS、快递终端、人机交互界面嵌入式模块
