请大家帮我看一下这个函数呀?我有点看不懂,别人写的?谢谢了呀!
请问:这里的地址: int NewSpareAddr = 2048 + 8*(startSectorAddr%8);
int NewDataAddr = 256*(startSectorAddr%8);
int NewSectorAddr = startSectorAddr/8;
为什么要这么算呀?算出的是是什么地址呢?
//ljm change :need to correct ecc
BOOL FMD_ReadSector(SECTOR_ADDR startSectorAddr, LPBYTE pSectorBuff,
PSectorInfo pSectorInfoBuff, DWORD dwNumSectors)
DWORD i;
BYTE eccBuf[8];
ECCRegVal eccRegVal;
EccInfo eccOrigVal;
// EccInfo eccNewVal;
DWORD EccData0,EccData1;
unsigned short *pU16Buf;
pU16Buf=(unsigned short *)pSectorBuff;
// RETAILMSG(1, (TEXT("FlashDrv!FMD!FMD_ReadSector: startSectorAddr = %x \r\n"), startSectorAddr));
// Sanity check
if (!pSectorBuff && !pSectorInfoBuff || dwNumSectors > 1) {
#ifdef BOOT_LOADER
EdbgOutputDebugString("Invalid parameters!\r\n");
#else
RETAILMSG(1, (TEXT("Invalid parameters!\n")));
#endif
#ifndef NOSYSCALL
SetLastError(ERROR_INVALID_PARAMETER);
#endif
return FALSE;
NF_Reset();
if(!pSectorBuff) {
// We are reading spare only
//RETAILMSG(1, (TEXT("FMD_ReadSectorInfo: startSectorAddr = %d \r\n"), startSectorAddr));
NAND_ReadSectorInfo(startSectorAddr, pSectorInfoBuff);
// There is no ECC for the sector info, so the read always succeed.
return TRUE;
GRABMUTEX();
// Initialize ECC register
NF_RSTECC();
NF_MECC_UnLock();
// Enable the chip
NF_CE_L();
NF_CLEAR_RB();
// Issue command
NF_CMD(CMD_READ);
// Set up address
NF_ADDR((NewDataAddr)&0xff);
NF_ADDR(((NewDataAddr)>>8)&0xff);
NF_ADDR((NewSectorAddr) & 0xff);
NF_ADDR((NewSectorAddr >> 8) & 0xff);
NF_ADDR((NewSectorAddr >> 16) & 0xff);
NF_CMD(0x30);
NF_DETECT_RB(); // Wait tR(max 12us)
// BUGBUG, because Media Player for Pocket PC sometimes pass us un-aligned buffer
// we have to waste cycle here to work around this problem
if( ((DWORD) pSectorBuff) & 0x3) {
for(i=0; i<(SECTOR_SIZE/2); i++) {
pU16Buf=NF_DATA_R2();
else {
// The right way.
#ifndef USENANDDMA
ReadPage512(pSectorBuff, pNFDATA);
#else // USENANDDMA
#ifdef USESETKMODE
SetKMode(TRUE);
v_pINTregs->rSRCPND=BIT_DMA3; // Init DMA src pending.
#endif // USESETKMODE
// Nand to memory dma setting
v_pDMAregs->rDISRC3 = (unsigned int)NFDATA; // Nand flash data register
v_pDMAregs->rDISRCC3 = (0<<1) | (1<<0); //arc=AHB,src_addr=fix
v_pDMAregs->rDIDST3 = (int)NAND_DMA_BUFFER_PHYS;
v_pDMAregs->rDIDSTC3 = (0<<1) | (0<<0); //dst=AHB,dst_addr=inc;
v_pDMAregs->rDCON3 = (1<<31)|(1<<30)|(1<<29)|(1<<28)|(1<<27)|(0<<23)|(1<<22)|(2<<20)|(512/4/4);
//Handshake,AHB,interrupt,(4-burst),whole,S/W,no_autoreload,word,count=128;
// DMA on and start.
v_pDMAregs->rDMASKTRIG3 = (1<<1)|(1<<0);
#ifndef USESETKMODE
WaitForSingleObject(gDMA3IntrEvent, INFINITE);
InterruptDone(SYSINTR_DMA3);
#else // USESETKMODE
while(!(v_pINTregs->rSRCPND & BIT_DMA3)); // Wait until Dma transfer is done.
SetKMode(FALSE);
memcpy(pSectorBuff, pDMABuffer, 512);
#endif // USENANDDMA
}帮我看看这个函数好吗?谢谢了呀!
