3628|8
eboot中断 [复制链接]
#define pISR                (*(unsigned *)(0x30000000+0x18))
//#define pISR                (*(unsigned *)(0x00000000+0x18))        这里应该填什么?
// Virtual Address 0x0 is mapped to 0x30000000, ISR Address is VA 0x18
void Isr_Init(void)
    volatile S3C2440A_INTR_REG *s2440INT = (S3C2440A_INTR_REG *)OALPAtoVA(S3C2440A_BASE_REG_PA_INTR, FALSE);
        s2440INT->INTMOD=0x0;                   // All=IRQ mode
        s2440INT->INTMSK=BIT_ALLMSK;          // All interrupt is masked.
        EdbgOutputDebugString("INFO: (unsigned)IsrUsbd : 0x%x\r\n", (unsigned)IsrUsbd);
        EdbgOutputDebugString("INFO: (unsigned)IsrHandler : 0x%x\r\n", (unsigned)IsrHandler);
        // make value to assemble code "b IsrHandler"
        pISR =(unsigned)(0xEA000000)+(((unsigned)IsrHandler - (0x80000000 + 0x18 + 0x8) )>>2);
0x80000000 这个地方对了吗
我的中断总是跳不到IsrHandler函数里,为什么?
USB.S里
    LEAF_ENTRY IsrHandler
;        sub        sp,sp,#4        ;decrement sp(to store jump address)
        sub lr, lr, #4
        stmfd   sp!, {r0-r12,lr}
        mov        r0, lr
        bl        IsrUsbd
        ldmfd   sp!, {r0-r12,lr}
        movs pc, lr
    ENDP    ; |IsrHandler|
startup.s里的MMU开启,里面不知道啥意思, (VA == 0) to (PA == 0x30000000).不确定是不是这样映射
            ; Compute physical address of the OEMAddressTable.
20      add     r11, pc, #g_oalAddressTable - (. + 8)
        ldr     r10, =PTs                ; (r10) = 1st level page table
        ; Setup 1st level page table (using section descriptor)
        ; Fill in first level page table entries to create "un-mapped" regions
        ; from the contents of the MemoryMap array.
        ;   (r11) = ptr to MemoryMap array
        add     r10, r10, #0x2000       ; (r10) = ptr to 1st PTE for "unmapped space"
        mov     r0, #0x0E               ; (r0) = PTE for 0: 1MB cachable bufferable
        orr     r0, r0, #0x400          ; set kernel r/w permission
25      mov     r1, r11                 ; (r1) = ptr to MemoryMap array
30      ldr     r2, [r1], #4            ; (r2) = virtual address to map Bank at
        ldr     r3, [r1], #4            ; (r3) = physical address to map from
        ldr     r4, [r1], #4            ; (r4) = num MB to map
        cmp     r4, #0                  ; End of table?
        beq     %f40
        ldr     r5, =0x1FF00000
        and     r2, r2, r5              ; VA needs 512MB, 1MB aligned.
        ldr     r5, =0xFFF00000
        and     r3, r3, r5              ; PA needs 4GB, 1MB aligned.
        add     r2, r10, r2, LSR #18
        add     r0, r0, r3              ; (r0) = PTE for next physical page
35      str     r0, [r2], #4
        add     r0, r0, #0x00100000     ; (r0) = PTE for next physical page
        sub     r4, r4, #1              ; Decrement number of MB left
        cmp     r4, #0
        bne     %b35                    ; Map next MB
        bic     r0, r0, #0xF0000000     ; Clear Section Base Address Field
        bic     r0, r0, #0x0FF00000     ; Clear Section Base Address Field
        b       %b30                    ; Get next element
40      tst     r0, #8
        bic     r0, r0, #0x0C           ; clear cachable & bufferable bits in PTE
        add     r10, r10, #0x0800       ; (r10) = ptr to 1st PTE for "unmapped uncached space"
        bne     %b25                    ; go setup PTEs for uncached space
        sub     r10, r10, #0x3000       ; (r10) = restore address of 1st level page table
        ; Setup mmu to map (VA == 0) to (PA == 0x30000000).
        ldr     r0, =PTs                ; PTE entry for VA = 0
        ldr     r1, =0x3000040E         ; uncache/unbuffer/rw, PA base == 0x30000000
        str     r1, [r0]
        ; uncached area.
        add     r0, r0, #0x0800         ; PTE entry for VA = 0x0200.0000 , uncached
        ldr     r1, =0x30000402         ; uncache/unbuffer/rw, base == 0x30000000
        str     r1, [r0]
        ; Comment:
        ; The following loop is to direct map RAM VA == PA. i.e.
        ;   VA == 0x30XXXXXX => PA == 0x30XXXXXX for S3C2400
        ; Fill in 8 entries to have a direct mapping for DRAM
        ldr     r10, =PTs               ; restore address of 1st level page table
        ldr     r0,  =PHYBASE
        add     r10, r10, #(0x3000 / 4) ; (r10) = ptr to 1st PTE for 0x30000000
        add     r0, r0, #0x1E           ; 1MB cachable bufferable
        mov     r1, #0
        mov     r3, #64
45      mov     r2, r1                  ; (r2) = virtual address to map Bank at
        cmp     r2, #0x20000000:SHR:BANK_SHIFT
        add     r2, r10, r2, LSL #BANK_SHIFT-18
        strlo   r0, [r2]
        subs    r3, r3, #1
        add     r1, r1, #1
        bgt     %b45
        ldr     r10, =PTs               ; (r10) = restore address of 1st level page table
        ; The page tables and exception vectors are setup.
        ; Initialize the MMU and turn it on.
        mov     r1, #1
        mcr     p15, 0, r1, c3, c0, 0   ; setup access to domain 0
        mcr     p15, 0, r10, c2, c0, 0
        mcr     p15, 0, r0, c8, c7, 0   ; flush I+D TLBs
        mov     r1, #0x0071             ; Enable: MMU
        orr     r1, r1, #0x0004         ; Enable the cache
        ldr     r0, =VirtualStart
        cmp     r0, #0                  ; make sure no stall on "mov pc,r0" below
        mcr     p15, 0, r1, c1, c0, 0
        mov     pc, r0                  ;  & jump to new virtual address
        nop
        ; MMU & caches now enabled.
        ;   (r10) = physcial address of 1st level page table
VirtualStart
        mov     sp, #0x80000000
        add     sp, sp, #0x30000        ; arbitrary initial super-page stack pointer
        b       main
        ENTRY_END
        LTORG
恭喜楼主~~  详情 回复 发表于 2010-1-6 17:30
66
g_oalAddressTable
;        DCD     0x80000000, 0x30000000, 128      ; 128 MB SDRAM-1 BANK 6
        DCD     0x80000000, 0x30000000, 64      ; 64 MB SDRAM-1 BANK 6
        DCD     0x88000000, 0x18000000, 32      ; 32 MB SROM(SRAM/ROM) BANK 3
        DCD     0x8A000000, 0x20000000, 32      ; 32 MB SROM(SRAM/ROM) BANK 4
        DCD     0x8C000000, 0x08000000, 32      ; 32 MB SROM(SRAM/ROM) BANK 1
        DCD     0x90000000, 0x10000000,  8      ; nGCS2: PCMCIA/PCCARD
        DCD     0x90800000, 0x48000000,  1      ; Memory control register
        DCD     0x90900000, 0x49000000,  1      ; USB Host register
        DCD     0x90A00000, 0x4A000000,  1      ; Interrupt Control register
        DCD     0x90B00000, 0x4B000000,  1      ; DMA control register
        DCD     0x90C00000, 0x4C000000,  1      ; Clock & Power register
        DCD     0x90D00000, 0x4D000000,  1      ; LCD control register
        DCD     0x90E00000, 0x4E000000,  1      ; NAND flash control register
        DCD     0x90F00000, 0x4F000000,  1      ; Camera control register
        DCD     0x91000000, 0x50000000,  1      ; UART control register
        DCD     0x91100000, 0x51000000,  1      ; PWM timer register
        DCD     0x91200000, 0x52000000,  1      ; USB device register
        DCD     0x91300000, 0x53000000,  1      ; Watchdog Timer register
        DCD     0x91400000, 0x54000000,  1      ; IIC control register
        DCD     0x91500000, 0x55000000,  1      ; IIS control register
        DCD     0x91600000, 0x56000000,  1      ; I/O Port register
        DCD     0x91700000, 0x57000000,  1      ; RTC control register
        DCD     0x91800000, 0x58000000,  1      ; A/D convert register
        DCD     0x91900000, 0x59000000,  1      ; SPI register
        DCD     0x91A00000, 0x5A000000,  1      ; SD Interface register
;       DCD     0x92000000, 0x00000000, 32      ; 32 MB SROM(SRAM/ROM) BANK 0
        DCD     0x00000000, 0x00000000,  0      ; end of table
        END
这段中断的初始化没错,但是这个中断只能处理USB DEVICE中断,
你的中断没成功吗?是不是中断的MASK位设置问题?或者是USB模块初始化不对?
86
MARK,学习下。
引用 2 楼 veabol 的回复:
没有成功哦,就是不进那个中断,跳不到IsrHandler函数里
void Isr_Init(void)
        pISR =(unsigned)(0xEA000000)+(((unsigned)IsrHandler - (0x80038000 + 0x18 + 0x8) )>>2);
//        pISR = (unsigned)IsrHandler;
//        pISRUSBD = (unsigned)IsrUsbd;
        EdbgOutputDebugString("INFO: (unsigned)pISR : 0x%x\r\n", (unsigned)pISR);
        s2440INT->SRCPND  = BIT_USBD;
        if (s2440INT->INTPND & BIT_USBD)
                s2440INT->INTPND = BIT_USBD;
        s2440INT->INTMSK &= ~BIT_USBD;                // USB Interrupt enable.
        s2440INT->SRCPND  = BIT_DMA2;
        if (s2440INT->INTPND & BIT_DMA2)
                s2440INT->INTPND = BIT_DMA2;
        s2440INT->INTMSK &= ~BIT_DMA2;                // DMA Interrupt enable.
63
如果没有办法USB初始化是否正确就先设置一个外部中断,然后触发那个外部中断
66
去我的博客 搜索 “eboot” 有我写的关于eboot中断相关的东西。
77
换个BOOTLoader解决了,莫名其妙,散分,谢谢各位
67
恭喜楼主~~
