3909|2
88
求助makefile 中的include 引用变量,之前并没有定义,怎么回事啊? [复制链接]
makefile include $(NXPMCU_SOFTWARE)/makerule/$(CSP)/make.$(CSP).$(TOOL)后面两个变量引用是什么意思?
附:所有的makefile文件内容
我是初学makefile
麻烦哪位能否帮我把下面这段解释一下?
ifeq ($(TOOL), keil)
MEXT        =.map
MAPFILE     =$(EXECNAME)
C_ENTRY     =
ENTRY       =
CFLAGS      +=-g
AFLAGS      +=-g
LDSCRIPT    =linker/ldscript_rom_rvw.ld
endif
# $Id:: makefile 1031 2008-08-06 22:28:49Z wellsk                      $
# Project: Bootable/FLASHable example makefile
# Description:
#  Makefile
# Software that is described herein is for illustrative purposes only
# which provides customers with programming information regarding the
# products. This software is supplied "AS IS" without any warranties.
# NXP Semiconductors assumes no responsibility or liability for the
# use of the software, conveys no license or title under any patent,
# copyright, or mask work right to the product. NXP Semiconductors
# reserves the right to make changes in the software without
# notification. NXP Semiconductors also make no representation or
# warranty that such application will be suitable for the specified
# use without further testing or modification.
EXECNAME    =kickstart
# Pick up the default build rules
# Arm compiler/linker specific stuff
# ARM examples enter via __main and are linked at address 0x0000
ifeq ($(TOOL), ads)
MEXT        =.map
C_ENTRY     =
ENTRY       =
CFLAGS      +=-g
AFLAGS      +=-g
LDSCRIPT    =linker/ldscript_rom_$(TOOL).ld
endif
ifeq ($(TOOL), rvw)
MEXT        =.map
C_ENTRY     =
ENTRY       =
CFLAGS      +=-g
AFLAGS      +=-g
endif
MEXT        =.map
C_ENTRY     =
ENTRY       =
CFLAGS      +=-g
AFLAGS      +=-g
endif
# Gcc compiler/linker specific stuff
ifeq ($(TOOL), gnu)
MEXT        =.map
C_ENTRY     =
ENTRY       =
CFLAGS      +=-gdwarf-2
AFLAGS      +=
endif
# Pick up the assembler and C source files in the directory
include $(NXPMCU_SOFTWARE)\makerule\common\make.rules.ftypes
# Rules to build the executable
default: release
release:
        @$(MAKE) TOOL=$(TOOL) debug
        @$(MAKE) TOOL=$(TOOL) bin
        @$(MAKE) TOOL=$(TOOL) hex
debug: $(OBJS) lpc_libs
        $(LD) $(OBJS) $(LDFLAGS) $(LK) $(SCAN) $(MAP) $(MAPFILE)$(MEXT) \
        $(LDESC) $(LDSCRIPT) $(ENTRY) $(C_ENTRY) -o $(EXECNAME)$(EXT)
bin:
        $(ELFTOBIN) $(EXECNAME)$(EXT) $(EXECNAME).bin
hex:
ifeq ($(TOOL), ads)
        $(ELFTOREC) $(EXECNAME)$(EXT) -o $(EXECNAME).$(REC)
endif
ifeq ($(TOOL), rvw)
endif
ifeq ($(TOOL), ghs)
endif
ifeq ($(TOOL), gnu)
        $(ELFTOREC) $(EXECNAME)$(EXT) $(EXECNAME).$(REC)
endif
ifeq ($(TOOL), iar)
endif
# Pick up the compiler and assembler rules
include $(NXPMCU_SOFTWARE)/makerule/common/make.rules.build
.PHONY: default release debug bin
也可能来自命令行啊 比如你这样编译 make clean all NXPMCU_SOFTWARE=nxp  详情 回复 发表于 2009-4-14 15:28
67
变量可以来自于shell里面的环境变量。
如果这个makefile不是顶层的makefile,他们还可能来自于其他的makefile定义。
78
也可能来自命令行啊
比如你这样编译
