2622|5
66
问个白痴问题。。希望解决! [复制链接]
#include
#include
#include
#include
#include
#include "image_cfg.h"
#include "s3c2440x_lcd.h"
#include
//  Definition
#define MAXLOGONUM           18
const char   LOGOTag[8]={'A','M','O','I','L','O','G','O'};
static DWORD  PowonLogoNum=0;
DWORD ChgLogoNum;
DWORD UpdateLogoNum;
static HANDLE g_hSTORE = NULL;
//  Frame buffer
//static USHORT s_frameBuffer[320 * 240];
static LOGOINFO  LogoInfo[MAXLOGONUM];//   the max num of the logo is 10
//Function: InitOrCloseBootstore
//IsInit == True,will init the bootstore
//ISInit == False,will Deinit the bootstore
BOOL InitOrCloseBootstore(BOOL IsInit)
    //#ifdef SHIP_BUILD
    if(IsInit)
     g_hSTORE = BootStoreInit(&g_bootStoreInit);
      if (g_hSTORE == NULL)
        RETAILMSG(OAL_INFO, (L"INFO: "
            L"Failed Init store!\r\n"));
        return FALSE;
    else if(!IsInit)
       //BootStoreDeinit(g_hSTORE);
        BootStoreClose(g_hSTORE);
  // #endif
    return TRUE;
//  Function:  ShowLogo
BOOL
ShowPowonLogo(
    BOOL rc=TRUE;
    InitOrCloseBootstore(TRUE);
    if(ReadLogoHead() ==FALSE)//读取LOGO头文件失败
       OALMSG(OAL_INFO, (L"INFO: "
            L"  POWON logo read ReadLogoHead fail!\r\n"));
       return rc = FALSE;
    if( ReadLogoAndDisplay(0,POWONLOGO)==FALSE)//读取和显示LOGO失败
            L"POWON logo  ReadLogoAndDisplay fail!\r\n"));
     rc = FALSE;
    InitOrCloseBootstore(FALSE);//初始化失败
    return rc;
BOOL ReadLogoHead()
   // #ifdef SHIP_BUILD
    UINT16 *pHBuffer,*pInfoBuffer;
    DWORD   TotalLogo;
    UINT16 LogoIndex;
    UINT16 PowonLogoIndex=0,ChgLogIndex=0,UpdateLogoIndex=0;
    LogoRegionHeader  LogoHeader;
    int i;
   /* UINT16 *P1,*p2,*p3;
    UINT32 Pa1,pc3;
    UINT16 a[10]={1,1,2,3,1,3},b[10],c[10];
    p2=b;
    P1=a;
    memcpy(p2,P1,sizeof(a));
    for(i=0;i<10;i++)
    RETAILMSG(1, (L"memory cache to cache %x\r\n",p2));
    Pa1=OALVAtoPA(&a[0]);
    P1 =OALPAtoUA(Pa1);
    pc3=OALVAtoPA(&c[0]);
    p3 =OALPAtoUA(pc3);
    for(i=0;i<10;i++)
    RETAILMSG(1, (L"uncache to cache %x\r\n",p2));
    memcpy(p3,p2,sizeof(a));
    for(i=0;i<10;i++)
    RETAILMSG(1, (L"cache to uncache %x\r\n",p3));*/
    pHBuffer = (UINT16 *)&LogoHeader;
    pInfoBuffer = (UINT16 *)LogoInfo;
    if (!BootStoreOpenReservedRegion(g_hSTORE, BOOT_STORE_ACCESS_READ, "LOGO"))
        RETAILMSG(1, (L"INFO: "
            L"Failed open reserved region LOGO!\r\n"));
        return FALSE;
    if(BootStoreRead(g_hSTORE, pHBuffer, sizeof(LogoHeader)) != sizeof(LogoHeader))
            L"Failed read logo header from reserved region!\r\n"));
        return FALSE;
   if(memcmp(LogoHeader.LogoTag,LOGOTag,8)==0)
        TotalLogo = LogoHeader.TotalNumber;
        if(TotalLogo > MAXLOGONUM)
            TotalLogo = MAXLOGONUM;
        if(!BootStoreSeek(g_hSTORE,(sizeof(LogoHeader)-sizeof(LOGOINFO))))
            L"seek to the headInfo fail in reserved region!\r\n"
          return FALSE;
        if(BootStoreRead(g_hSTORE, pInfoBuffer, TotalLogo*sizeof(LOGOINFO)) != TotalLogo*sizeof(LOGOINFO))
            L"Failed read logo info from reserved region!\r\n"));
            return FALSE;
        for(LogoIndex =0;LogoIndex < TotalLogo;LogoIndex++)
            //POWON logo
            if(LogoInfo[LogoIndex].LogoID == 1)
                PowonLogoIndex++;
            //CHARGE LOGO
           else if(LogoInfo[LogoIndex].LogoID == 2)
               ChgLogIndex++;
           else if(LogoInfo[LogoIndex].LogoID == 3)
              UpdateLogoIndex++;
        PowonLogoNum = PowonLogoIndex;
        ChgLogoNum = ChgLogIndex;
        UpdateLogoNum = UpdateLogoIndex;
        return TRUE;
    else
  //  #endif
        //for debug
        for(i=0;i         {
            RETAILMSG(1, (L"LogoHeader.LogoTag %x\r\n",LogoHeader.LogoTag));
        RETAILMSG(1, (L"INFO: "L"logo not exist!\r\n"));
        return FALSE;
//function: ReadLogoAndDisplay;
//argument:
// LogoIndex:  the LogoIndex is begin at 0 to the max logonum -1.
// logo: indicate the  chargelogo or powon logo that should be showed.
BOOL ReadLogoAndDisplay(WORD LogoIndex,LOGO Logo)
    //#ifdef SHIP_BUILD
    UINT16 *pBuffer;
    DWORD logosize;
    DWORD  index;
    pBuffer = (UINT16*)IMAGE_FRAMEBUFFER_UA_BASE;
            L"g_hSTORE is not initted!\r\n"));
        return FALSE;
    if(Logo == POWONLOGO)
        if(LogoIndex >= PowonLogoNum)
           return FALSE;
        index = LogoIndex;
        if(!BootStoreSeek(g_hSTORE,LogoInfo[index].LocationOffSet))
            L"seek to the PowonLogo fail in reserved region!\r\n"));
          return FALSE;
    else if(Logo == CHGLOGO)
        if(LogoIndex >= ChgLogoNum)
            return FALSE;
        index = PowonLogoNum + LogoIndex;
                L"seek to the chargelog fail in reserved region!\r\n" ));
            return FALSE;
    else if(Logo == UPDATELOGO)
      if(LogoIndex >= UpdateLogoNum)
        return FALSE;
      index = PowonLogoNum + ChgLogoNum + LogoIndex;
            return FALSE;
    if(LogoInfo[index].Pos.x != 0)
            L"pos.x should be zero!!\r\n"));
       return FALSE;
    pBuffer = pBuffer+ (LogoInfo[index].Pos.y *  LogoInfo[index].Pos.width);
    logosize = (LogoInfo[index].size)* 2;
    if(BootStoreRead(g_hSTORE,pBuffer,LogoInfo[index].size *2) != LogoInfo[index].size * 2)
         return FALSE;
    // Start display
    //BootStartDisplay(pBuffer,LCD_ARRAY_SIZE_TFT_16BIT);
//   #endif
    return TRUE;
在这段LOGO代码里面,哪一段是换图片需要修改的代码
s_frameBuffer[320 * 240]  详情 回复 发表于 2009-3-27 16:28
好长的代码
62
你去找找使用了这个变量的代码。
63
引用 1 楼 xqhrs232 的回复:
好长的代码
同意
78
把那个数组换成你的图片数据应该就可以了。
无论您是个人用户,还是企业用户;无论您是初学者,还是高手,飞凌嵌入式总有一款开发板适合您。飞凌嵌入式技术有限公司愿做您通往成功,成为高手的桥梁。飞凌值得信赖!!
飞凌嵌入式技术有限公司    http://www.witech.com.cn
咨询热线: 0312-3113161
75
