4700|9
78
wince5.0怎样才能进入IDLE模式 [复制链接]
哪位兄弟能告诉我WINCE5.0进入IDLE模式要实现哪些函数?我S3C2440的BSP里面有OEMIDLE()函数和OALCPUIDLE()函数,OEMIDLE()函数里还用了OALTimerUpdate(),但是没有OALTimerUpdate()的源码,不知道哪位兄弟有?
散分了。  详情 回复 发表于 2009-8-21 10:08
84
关屏,关背光,将不用的模块全部进入低功耗或断电。
90
关闭所有中断.....
引用 1 楼 shuiyan 的回复:
同意,中断还是要开的吧。。。。。。。。
82
谁有OALTimerUpdate()函数的源码?
  1. 我的2440是这样的
  2. OEMIDLE调用下面的
  3. VOID OALCPUIdle()
  4. {
  5.     volatile S3C2440A_CLKPWR_REG *s2440CLKPWR = (S3C2440A_CLKPWR_REG *)OALPAtoVA(S3C2440A_BASE_REG_PA_CLOCK_POWER, FALSE);
  6.     volatile S3C2440A_INTR_REG *s2440INTR = (S3C2440A_INTR_REG *)OALPAtoVA(S3C2440A_BASE_REG_PA_INTR, FALSE);
  7.
  8.     // Clear last SYSINTR global value
  9.     //g_oalLastSysIntr = SYSINTR_NOP;
  10.     g_oalLastSysIntr = FALSE;    //c ksk 20060404
  11.     INTERRUPTS_ON();
  12.         s2440CLKPWR->CLKCON |=  (1 << 2);
  13.     // Wait until interrupt handler set interrupt flag
  14.     //while (g_oalLastSysIntr == SYSINTR_NOP);
  15.     while (!g_oalLastSysIntr) {};    //c ksk 20060404
  16.         s2440CLKPWR->CLKCON &= ~(1 << 2);
  17.     INTERRUPTS_OFF();
  18. }
复制代码
谢谢gooogleman,我的OEMIdle函数实现是这样的:
void OEMIdle(DWORD idleParam)
    UINT32 baseMSec, idleMSec, idleSysTicks;
    INT32 usedCounts, idleCounts;
    ULARGE_INTEGER idle;
    // Get current system timer counter
    baseMSec = CurMSec;
    // Compute the remaining idle time
    idleMSec = dwReschedTime - baseMSec;
    // Idle time has expired - we need to return
    if ((INT32)idleMSec <= 0) return;
    // Limit the maximum idle time to what is supported.
    // Counter size is the limiting parameter.  When kernel
    // profiler or interrupt latency timing is active it is set
    // to one system tick.
    if (idleMSec > g_oalTimer.maxPeriodMSec) {
        idleMSec = g_oalTimer.maxPeriodMSec;
    // We can wait only full systick
    idleSysTicks = idleMSec/g_oalTimer.msecPerSysTick;
    // This is idle time in hi-res ticks
    idleCounts = idleSysTicks * g_oalTimer.countsPerSysTick;
    // Find how many hi-res ticks was already used
    usedCounts = OALTimerCountsSinceSysTick();
    // Prolong beat period to idle time -- don't do it idle time isn't
    // longer than one system tick. Even if OALTimerExtendSysTick function
    // should accept this value it can cause problems if kernel profiler
    // or interrupt latency timing is active.
    if (idleSysTicks > 1) {
        // Extend timer period
        OALTimerUpdate(idleCounts, g_oalTimer.countsMargin);
        // Update value for timer interrupt which wakeup from idle
        g_oalTimer.actualMSecPerSysTick = idleMSec;
        g_oalTimer.actualCountsPerSysTick = idleCounts;
    // Move SoC/CPU to idle mode
    OALCPUIdle();
    // Return system tick period back to original. Don't call when idle
    // time was one system tick. See comment above.
        // If there wasn't timer interrupt we have to update CurMSec&curCounts
        if (CurMSec == baseMSec) {
            idleSysTicks = OALTimerUpdate(
                g_oalTimer.countsPerSysTick, g_oalTimer.countsMargin
            // Restore original values
            g_oalTimer.actualMSecPerSysTick = g_oalTimer.msecPerSysTick;
            g_oalTimer.actualCountsPerSysTick = g_oalTimer.countsPerSysTick;
            // Fix system tick counters & idle counter
            CurMSec += idleSysTicks * g_oalTimer.actualMSecPerSysTick;
            idleCounts = idleSysTicks * g_oalTimer.actualCountsPerSysTick;
            g_oalTimer.curCounts += idleCounts;
            idleCounts += OALTimerCountsSinceSysTick();
    } else {
           // Update actual idle counts, if there wasn't timer interrupt
            idleCounts = OALTimerCountsSinceSysTick();
    // Get real idle value. If result is negative we didn't idle at all.
    idleCounts -= usedCounts;
    if (idleCounts < 0) idleCounts = 0;
    // Update idle counters
    idle.LowPart = curridlelow;
    idle.HighPart = curridlehigh;
    idle.QuadPart += idleCounts;
    curridlelow  = idle.LowPart;
    curridlehigh = idle.HighPart;
不知道你的OEMIdle函数是不是这样?里面OALTimerUpdate()函数我的BSP没有。
77
OALTimerUpdate 位於
%_WINCEROOT%\PLATFORM\COMMON\SRC\COMMON\TIMER\CNTCMP
%_WINCEROOT%\PLATFORM\COMMON\SRC\COMMON\TIMER\VARCNTCMP
端看 LZ kernel 的 sources 是 link 哪一个 library
Paul, Chao @ Techware
81
mark
87
散分了。
