4532|9
75
download imge之后不能正常启动WM [复制链接]
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Aug 25 2009 11:32:52
Microsoft Windows WM600 Bootloader HISI K3B831 USB1.1 NDIS Built Aug 25 2009
System ready!
Preparing for download...
INFO: *** Device Name  ' s'.
INFO: OEMLaunch: Jumping to Physical Address 0xA7F60000h (Virtual Address 0x87F60000h)...
Microsoft Windows WM611 IPL HISI K3B831 USB1.1 NDIS Built Aug 21 2009
GetPmuRtc: 0x6D18475A
pAdcArgs->m_LtkFlg 0xFFFFFFFF.
pAdcArgs->m_UsbFlg 0xFFFFFFFB.
ReadSpi PMU_VERSION is 0x11.
ReadSpi HREST_REG_ADDR is 0x8.
ReadSpi USB Status 0x88.
ReadSpi  IRQ_REG1_ADDR 0x8.
NORMAL_RESET.
++UsbInit.
++InitUsbCharger.
Read 0x0e,Value:0x88!
Read 0x0f,Value:0xF2!
Read 0x63,Value:0x98!
Read 0x65,Value:0x40!
Please connect USB port again!
insert PC!
--InitUsbCharger.0x1.
--UsbInit.0x1
GetLoGoPos:BootStoreRead read head is size 3820.
GetLoGoPos:image pos (left: 0,top:0,right:240,bottom:320).
totalLength is :0x25800
Waring: Decompression is complete!
Display buf length is 153600.
INFO: Loading image ...
INFO: Jumping to image...
Jumping to VA 0x81700000 PA 0xA1700000...
Windows CE Kernel for ARM (Thumb Enabled) Built on Sep 16 2008 at 18:27:13
ProcessorType=0926  Revision=5
sp_abt=ffff1000 sp_irq=ffff0800 sp_undef=ffffc800 OEMAddressTable = 81701000
DCache: 128 sets, 4 ways, 32 line size, 16384 size
ICache: 128 sets, 4 ways, 32 line size, 16384 size
Sp=ffffc7cc
--g_CuBat.1212
--g_CuBat.1293
--g_CuBat.1374
--g_CuBat.1455
--g_CuBat.1536
--g_CuBat.1617
--g_CuBat.1698
--g_CuBat.1778
--g_CuBat.1859
--g_CuBat.1940
--g_CuBat.2021
--g_CuBat.2102
--g_CuBat.2183
--g_CuBat.2264
--g_CuBat.2344
--g_CuBat.2425
--g_CuBat.2506
--g_CuBat.2587
--g_CuBat.2668
IplChargeStatus: ReBatVol is (5175).
Sp=ffffc7cc
Data Abort: Thread=87fcc8a4 Proc=81a86d10 'filesys.exe'
AKY=00000003 PC=8172e180(NK.EXE+0x0002e180) RA=81a85c00(???+0x81a85c00) BVA=0fe95f84 FSR=00000005
AKY=00000003 PC=03f8c1bc(coredll.dll+0x000421bc) RA=03f8ce5c(coredll.dll+0x00042e5c) BVA=0fe95f84 FSR=00000005
!!Initialized function of OEM Certification Module failed. Trust Model disabled!!
System ready!
GetPmuRtc: 0x6D186E56
ReadSpi USB Status 0x8A.
get keypad key is ok.
GetLoGoPos:BootStoreRead read head is size 9372.
USB Generic Serial Version is 1.02!
USB1.1:: Create virtual Base addr
please connect USB2.0 port for Generic serial .
USB port was connected!
USB Device Enum OK!
Has Get the system startup mode
Ipl Download begin.....
Ipl Download end.....
Ipl Download Has Been Done
Reset Sys?
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Aug 25 20099 11:32:52
System ready!
GetPmuRtc: 0x6D186F00
NORMAL_RESET.
++UsbInit.
++InitUsbCharger.
insert PC!
--UsbInit.0x1
Sp=ffffc7cc
RaiseException: Thread=87fcc8a4 Proc=81a86d10 'filesys.exe'
AKY=00000003 PC=03f683bc(coredll.dll+0x0001e3bc) RA=81707378(NK.EXE+0x00007378) BVA=00000000 FSR=0
System ready!
GetPmuRtc: 0x6D186F08
NORMAL_RESET.
++UsbInit.
++InitUsbCharger.
insert PC!
--UsbInit.0x1
Sp=ffffc7cc
AKY=00000003 PC=03e9e514(fsdmgr.dll+0x0000a514) RA=03e9924c(fsdmgr.dll+0x0000524c) BVA=04000008 FSR=00000007
To eagle1597 暂且不谈K3做得怎样,确实碰到了这样的问题。看eagle1597这么积极,不知道有高见或者说有解决的思路不?  详情 回复 发表于 2009-9-10 00:36
96
各位指教指教!
这种问题,只有自己一点点去调试,别人没有你的硬件和代码,很难帮到你。
LZ,你对image做了什么修改呢?
77
download一个之前在另外一个机子上能用的image,download完毕之后重新启动就卡死在logo那里了。这时的电流只有7MA,一般正常运行时是在100多~200多MA左右。
但是有时卡在logo那里一段时间之后偶尔能正常进入OS中。
碰到这种情况,也不知道究竟是硬件的问题还是软件的问题。
请教碰到这样的情况,通过什么办法测试能逐步确定问题的所在????
望指教。
串口打印信息如下:
Reset Sys?
System ready!
GetPmuRtc: 0x6D182563
NORMAL_RESET.
++UsbInit.
++InitUsbCharger.
insert PC!
--UsbInit.0x1
Sp=ffffc7cc
57
K3的东西, 居然被你们做出问题...
66
引用 5 楼 eagle1597 的回复:
K3的东西, 居然被你们做出问题...
听语气。。。。。。
难道 eagle1597是海思的?
引用 6 楼 yongshi128 的回复:
K3的东西, 居然被你们做出问题...
听语气。。。。。。
难道 eagle1597是海思的?
海思不能上网的 嗯
K3方案太到位了,的确很难出问题
77
不好意思, 我发现我少打了两个字.
本来要想说的是 "K3的东西, 居然被你们做出这种问题..", 本是想表示一种惊呀的语气. 因为看你的错误提示:
"Data Abort: Thread=87fcc8a4 Proc=81a86d10 'filesys.exe"
对这个感到有点奇怪, K3的东西你照着来应该没有这种问题吧.
To eagle1597
