3303|2
66
Startup.a51在MedWin中的使用问题 [复制链接]
这个MedWin怎么老是不认识Startup.A51,网上有人说把文件名改成Startup.asm并且删掉有name的一行,可试了下还是不行啊,有碰到过这问题的没?
  ============================= 编 译 / 汇 编 =============================
  编译/汇编文件: "D:\Wang fan\MedWinProject\79e824\STARTUP.ASM"
   <汇编命令行> D:\Keil\C51\BIN\A51.EXE STARTUP.ASM DB SET(SMALL)
    编译/汇编过程中发现错误的编译/汇编器
mpf文件
[Project]
Driver=""
Format=0
Alias="79e824"
HeadPath=""
HoldFunc=FALSE
[Source/STARTUP.ASM]
FileType=1
BankNumb=0
FileTime="01C99C6D-BFCCAD00"
ObjTime="00000000-00000000"
ExcludeBuild=FALSE
Debug=TRUE
Mod51=TRUE
UseSet=TRUE
UseReSet=FALSE
Set=""
ReSet=""
HeadPath=""
Misc=""
[Source/W79E824.c]
FileType=2
BankNumb=0
FileTime="01C9899D-81F5A500"
ObjTime="01C99C6C-C9A1E080"
ExcludeBuild=FALSE
Debug=TRUE
WarnLayer=3
Optimize=2
OptimizeLayer=10
GenerateSrc=FALSE
UseSet=TRUE
UseReSet=FALSE
NoAregs=FALSE
Set=""
ReSet=""
HeadPath=""
Misc=""
[Source/EEPROM.c]
FileType=2
BankNumb=0
FileTime="01C9899D-A5B8EB00"
ObjTime="01C99C6C-C9C06500"
ExcludeBuild=FALSE
Debug=TRUE
WarnLayer=3
Optimize=2
OptimizeLayer=10
GenerateSrc=FALSE
UseSet=TRUE
UseReSet=FALSE
NoAregs=FALSE
Set=""
ReSet=""
HeadPath=""
Misc=""
[Output/Debug\79e824.m51]
FileType=4
[Output/Output\79e824.hex]
FileType=4
[Target]
RamSize=128
RamModal=0
ProgramModal=2
Rtos=0
CodeBase1=""
CodeBase2=""
CodeBase3=""
CodeLen1=""
CodeLen2=""
CodeLen3=""
XdataBase1=""
XdataBase2=""
XdataBase3=""
XdataLen1=""
XdataLen2=""
XdataLen3=""
UseBank=FALSE
BankNumbles=2
BankBase=0
BankEnd=0
UseMX=FALSE
[Link]
Code=""
Xdata=""
Pdata=""
Precede=""
Bit=""
BitBase=""
DataBase=""
Data=""
IdataBase=""
Idata=""
Stack=""
CodeRange=""
XdataRange=""
UseTargetLayout=TRUE
Misc=""
UseOutsizeLinkFile=FALSE
OutsizeLinkFile=""
UserClass=""
UserSegment=""
[OutPut]
OutPutCustom=FALSE
HexFile=TRUE
BinFile=FALSE
LibFile=FALSE
OutPutName="79e824"
OutPutPath="D:\Wang fan\MedWinProject\79e824\Output"
BinFileFill="0xFF"
OutPutAfterExeCheck=FALSE
OutPutAfterExe=""
OutPutBeforExeCheck=FALSE
OutPutBeforExe=""
[ProjectAsmCtrl]
Mod51=TRUE
UseSet=TRUE
UseReSet=FALSE
Set=""
ReSet=""
HeadPath=""
Misc=""
[ProjectC51Ctrl]
WarnLayer=3
Optimize=1
OptimizeLayer=8
GenerateSrc=FALSE
UseSet=TRUE
UseReSet=FALSE
NoAregs=FALSE
Set=""
ReSet=""
HeadPath=""
Misc=""
就楼上一个回答.真悲哀啊  详情 回复 发表于 2009-3-25 14:18
不了解你的什么MedWin, 不过我想你总可以找个例子程序参考一下吧。
就楼上一个回答.真悲哀啊
