2448|0
83
解释一下ov9650寄存器的设定 [复制链接]
              Common Control 3
                 Bit[7]:   Reserved
                 Bit[6]:   Output data MSB and LSB swap
                 Bit[5:4]: Reserved
                 Bit[3]:   Pin selection
0C COM3 00 RW              1: Change RESET pin to EXPST_B (frame exposure
                                mode timing) and change PWDN pin to FREX (frame
                                exposure enable)
                 Bit[2]:   VarioPixel for VGA, CIF, QVGA, QCIF, QQVGA, and
                           QQCIF
                 Bit[1]:   Reserved
                 Bit[0]:   Single frame output (used for Frame Exposure mode only)
              Common Control 4
                 Bit[7]:   VarioPixel for QVGA, QCIF, QQVGA, and QQCIF
                 Bit[6:3]: Reserved
                 Bit[2]:   Tri-state option for output clock at power-down period
                           0: Tri-state at this period
0D COM4 00 RW
                           1: No tri-state at this period
                 Bit[1]:   Tri-state option for output data at power-down period
                 Bit[0]:   Reserved
