3604|5
3401
美国NB频段 [复制链接]
美国NB频段
全球运营商的频段分布图 [attach]527179[/attach][attach]527180[/attach][attach]527181[/attach]     详情 回复 发表于 2021-3-8 21:33
9792
24
The NB-IoT Bands selected for North America are B4 (1700 MHz), B12 (700 MHz), B26 (850 MHz), B66 (1700 MHz) and B71 (600 MHz). Narrow Band IoT is a low power wide area (LPWA) technology developed specifically for IoT devices and services.
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
9792
24
 3GPP has assigned different frequency bands in different regions for this cellular IoT standard.
NB-IoT Band
Uplink Band
Downlink Band
Bandwidth
Duplex Mode
B4 1710 -1755 MHz
2110 -2155 MHz
45 MHz
HD-FDD
B12
699 - 716 MHz
729 - 746 MHz
17 MHz
HD-FDD
B26
814 - 849 MHz
859 - 894 MHz
35 MHz
HD-FDD
B66 1710 - 1780 MHz 2110 - 2200 MHz 70/90 MHz
HD-FDD
B71 633 - 698 MHz 617 - 783 MHz 65 MHz
HD-FDD
This is based on input received by the NB-IoT Forum members and this document  NB-IoT_Deployment_Guide_v2_5Apr2018.pdf (2.49 MB, 下载次数: 6)
 from GSMA.
假如B12  每个国家的频段是不一样的吧    详情 回复 发表于 2021-3-11 16:13
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
343
全球运营商的频段分布图
这个是发送上行 下行   接收上行下行的意思吗     详情 回复 发表于 2021-3-11 15:54
3401
qwqwqw2088 发表于 2021-3-8 21:33 全球运营商的频段分布图
3401
littleshrimp 发表于 2021-3-8 20:03  3GPP has assigned different frequency bands in different regions for this cellular IoT standar ...
假如B12  每个国家的频段是不一样的吧
