5201|3
6069
【测评SGP40】+用arduino测试传感器 I2C通信 [复制链接]
本来用arduino测试SVM40 I2C通讯是一个容易的事。但折腾了一下。花了些时间。
1,下载arduino-snippets-main包 解压。
2,使用里面的\arduino-snippets-main\arduino-snippets-main\SVM40_I2C_minimal_example例子。
3,准备接好电路,传感器板 VCC GND接stm32F767板子 VCC  地, 3腿 SDA 接 PB8,  4腿SCL PB9,5腿 接地
4,PB8,PB9接4.7K上拉电阻。记得 否则是数据不变哦
5,打开\arduino-snippets-main\arduino-snippets-main\SVM40_I2C_minimal_example
6,用arduino1.8.13 打开SVM40_I2C_minimal_example.ino
注意这里已经是安装好stm32duino包了得。具体可以看我的帖子 让arduino 把你的无用的stm32板子玩起来 之一
7,修改I2C时钟为100K具体如下
#include <Wire.h>
// SVM40
const int16_t SVM40_ADDRESS = 0x6A;
void setup() {
  Serial.begin(115200);
  // wait for serial connection from PC
  // comment the following line if you'd like the output
  // without waiting for the interface being ready
  while(!Serial);
  // output format
  Serial.println("VOC_Index\tRH\tT");
  // init I2C
  Wire.setClock(100000L);//修改I2C时钟 据说模块最多100K
  Wire.begin();
  // wait until sensors startup, > 1 ms according to datasheet
  delay(1);
  // start up sensor, sensor will go to continous measurement mode
  // each second there will be new measurement values
  Wire.beginTransmission(SVM40_ADDRESS);
  Wire.write(0x00);
  Wire.write(0x10);
  Wire.endTransmission();
  // wait until sensors is ready, fan is initialized
  delay(1000);
void loop() {
  uint16_t voc, humidity, temperature;
  uint8_t data[9], counter;
  // read measurement data
  Wire.write(0x03);
  Wire.write(0xA6);
  // wait 5 ms to allow the sensor to fill the internal buffer
  delay(5);
  // read measurement data svm40, after two bytes a CRC follows
  Wire.requestFrom(SVM40_ADDRESS, 9);
  counter = 0;
  while (Wire.available()) {
    data[counter++] = Wire.read();
  // VOC level is a signed int and scaled by a factor of 10 and needs to be divided by 10
  // humidity is a signed int and scaled by 100 and need to be divided by 100
  // temperature is a signed int and scaled by 200 and need to be divided by 200
  voc = (uint16_t)data[0] << 8 | data[1];
  humidity = (uint16_t)data[3] << 8 | data[4];
  temperature = (uint16_t)data[6] << 8 | data[7];
  Serial.print(String(float(voc) / 10));
  Serial.print("\t");
  Serial.print(String(float(humidity) / 100));
  Serial.print("\t");
  Serial.print(String(float(temperature) / 200));
  Serial.println();
  delay(1000);
8,编译下载。 运行。
结果出来了,今晚24.8度
此帖出自传感器论坛
这个空中飞电阻的操作哈哈,有那么点意思,以前也用过这样的方式!   详情 回复 发表于 2021-3-3 19:40
赞赏
查看全部赞赏
点赞(1) 关注(2)
6587
 还可以这样玩,用stm32duino安装包
谢谢分享
此帖出自传感器论坛
6069
Jacktang 发表于 2021-3-2 14:04  还可以这样玩,用stm32duino安装包 谢谢分享
是啊挺方便的。手上的板子可以玩起来。
此帖出自传感器论坛
1942
此帖出自传感器论坛
