3772|2
87
修改128M NAND boot 在WriteMBR 中出现error [复制链接]
typedef enum  _FLASH_TYPE { NAND, NOR } FLASH_TYPE;
typedef struct _FlashInfo
    FLASH_TYPE  flashType;
    DWORD       dwNumBlocks;
    DWORD       dwBytesPerBlock;
    WORD        wSectorsPerBlock;
    WORD        wDataBytesPerSector;
}FlashInfo, *PFlashInfo;
DWORD g_dwMBRSectorNum = INVALID_ADDR;
FlashInfo g_FlashInfo;
static BOOL WriteMBR()
    RETAILMSG(1, (TEXT("test\r\n")));
    DWORD dwMBRBlockNum = g_dwMBRSectorNum / g_FlashInfo.wSectorsPerBlock;
    RETAILMSG(1, (TEXT("WriteMBR: MBR block = 0x%x.\r\n"), dwMBRBlockNum));
    memset (g_pbBlock, 0xff, g_dwDataBytesPerBlock);
    memset (g_pSectorInfoBuf, 0xff, sizeof(SectorInfo) * g_FlashInfo.wSectorsPerBlock);
    // No need to check return, since a failed read means data hasn't been written yet.
    ReadBlock (dwMBRBlockNum, g_pbBlock, g_pSectorInfoBuf);
    if (!FMD_EraseBlock (dwMBRBlockNum)) {
        RETAILMSG (1, (TEXT("CreatePartition: error erasing block 0x%x\r\n"), dwMBRBlockNum));
        return FALSE;
    memcpy (g_pbBlock + (g_dwMBRSectorNum % g_FlashInfo.wSectorsPerBlock) * g_FlashInfo.wDataBytesPerSector, g_pbMBRSector, g_FlashInfo.wDataBytesPerSector);
    g_pSectorInfoBuf->bOEMReserved &= ~OEM_BLOCK_READONLY;
    g_pSectorInfoBuf->wReserved2 &= ~SECTOR_WRITE_COMPLETED;
    g_pSectorInfoBuf->dwReserved1 = 0;
    if (!WriteBlock (dwMBRBlockNum, g_pbBlock, g_pSectorInfoBuf)) {
        RETAILMSG (1, (TEXT("CreatePartition: could not write to block 0x%x\r\n"), dwMBRBlockNum));
        return FALSE;
    return TRUE;
EBOOT运行后,停在了那条除法指令上了(RETAILMSG(1, (TEXT("test\r\n")));能显示然后再也没有调试信息出来,)。g_FlashInfo.wSectorsPerBlock(全局变量)为0X100。我想应该是语法或者是编译等地方配置出错了,差不出,请指点。
帮顶下。 MARK,学习下、  详情 回复 发表于 2010-1-9 15:11
在 BOOL WriteMBR() 中事先赋值 g_FlashInfo.wSectorsPerBlock=0x100;
就能通过了!
帮顶下。
MARK,学习下、
