3250|1
关于samba配置的问题 [复制链接]
目前移植samba到mips中,现在用smbclient已经可以看到windows中的共享的目录,但是用smbmount去将目录挂在到系统中时,提示没有目录,具体信息如下:
# smbclient -L //192.168.1.188
load_client_codepage: filename /usr/samba/lib/codepages/codepage.850 does not exist.
load_unicode_map: filename /usr/samba/lib/codepages/unicode_map.850 does not exist.
load_unicode_map: filename /usr/samba/lib/codepages/unicode_map.ISO8859-1 does not exist.
added interface ip=192.168.1.2 bcast=192.168.1.255 nmask=255.255.255.0
session request to 192.168.1.188 failed (Called name not present)
session request to 192 failed (Called name not present)
Password:
Domain=[WORKGROUP] OS=[Windows 5.1] Server=[Windows 2000 LAN Manager]
        Sharename      Type      Comment
        E$             Disk      ???????í
        IPC$           IPC       ???? IPC
        D$             Disk      ???????í
        cyy            Disk
        ADMIN$         Disk      ???????í
        C$             Disk      ???????í
        ?è?? (E)       Disk
        Server               Comment
        (NONE)               Samba 2.2.12
        A19                  tvrate
        LENOVO-PC
        PC-200903251249
        PC-200912081431
        PC-201004191616
        PC917-
        Workgroup            Master
        MSHOME               PC-200911180954
        MYGROUP              LIZHE
        WORKGROUP            PC-200903251249
# smbmount //192.168.1.188/cyy /net
201: session request to 192.168.1.188 failed (Called name not present)
201: session request to 192 failed (Called name not present)
Password:
execvp of smbmnt failed. Error was No such file or directory.smbmnt failed: 1
需要指定一个完整的目录例如 # smbclient -L //192.168.1.188/home/usr/dir/   详情 回复 发表于 2010-5-6 14:01
82
需要指定一个完整的目录例如
