5084|8
Wince6.0 R3系统定制的问题 [复制链接]
为什么Run-time image can be larger than 32MB(IMGRAM64=1)选中后还会出现如下信息,nk.bin生成不了
Pass 1...
Warning: Unable to do imports from ppp.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from schannel.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from k.schannel.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from eapol.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from eapchap.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from crypt32.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from k.crypt32.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from cryptdll.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from k.cryptdll.dll to RSAENH.dll - will late bind
Pass 2...
RAM AutoSize: RAM Start=84a90000 RAM Size=ff45f000
Reserve area conflict, moving start 83eb6424 len 54000h to 83f00000h
Reserve area conflict, moving start 83f00000 len 54000h to 84000000h
Error: Image is too large for current RAM and RAMIMAGE settings
The default end address of RAM was exceeded.
Fatal error hit, exiting...
makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec).
Mekalo_R3 - 4 error(s), 10 warning(s)
请问这个要怎么解决
RAM AutoSize: RAM Start=84a90000 RAM Size=ff45f000 Reserve area conflict, moving start 83eb6424 len 54000h to 83f00000h Reserve area conflict, moving start 83f00000 len 54000h to 84000000h Error: Image is too large for current RAM and RAMIMAGE settings The default end address of RAM was exceeded. Fatal error hit, exiting...   详情 回复 发表于 2010-3-26 14:07
[url=http://download.eeworld.net/source/2157967][/url]
你下载这个试试看,针对模拟器BSP的R3工程,经过测试,支持Flash显示的。
78
帮顶下。
MARK,学习下。
67
错误很明显啊,楼主检查一下config.bib文件里面对于NK和RAM的配置吧。
81
友情帮顶。。。
引用 3 楼 ricky_hu 的回复:
dui
65
  前辈说的对,呵呵 内存分配不对
64
  前辈说的对,呵呵 内存分配不对
77
