2463|2
77
各位高手啊,帮帮忙啊 [复制链接]
最近在学嵌入式,学习USB的代码中有些问题不知道什么意思?
其中“*paddr = (unsigned char *)(addr - 4);”
原文void Usb_Get_Data(unsigned int addr)
        unsigned short i_st;
        unsigned char *paddr = (unsigned char *)(addr - 4);
        int            length = 0x100000;
        int            bGetlen = 0;
        rNCACHBE0=0x80002000;//设置非CACHE的开始地址0x2000000,结束地址0x8000000
        Uart_Printf("Download file from usb......\n");
        reconnect_USB();
        while(1)
                i_st = D12_ReadInterruptRegister();//D12_ReadInterruptRegister();
                if(i_st != 0)
                        if(i_st & D12_INT_BUSRESET)
                                bus_reset();
                                bEPPflags.bits.bus_reset = 1;
                                i_st &= ~D12_INT_BUSRESET;
                        else
                                if(i_st & D12_INT_EOT)
                                        dma_eot();
                                        i_st &= ~D12_INT_EOT;
                                if(i_st & D12_INT_SUSPENDCHANGE)
                                        bEPPflags.bits.suspend = 1;
                                        i_st &= ~D12_INT_SUSPENDCHANGE;
                                if(i_st & D12_INT_ENDP0IN)
                                        ep0_txdone();
                                        i_st &= ~D12_INT_ENDP0IN;
                                if(i_st & D12_INT_ENDP0OUT)
                                        ep0_rxdone();
                                        i_st = ~D12_INT_ENDP0OUT;
                                if(i_st & D12_INT_ENDP1IN)
                                        ep1_txdone();
                                        i_st &= ~D12_INT_ENDP1IN;
                                if(i_st & D12_INT_ENDP1OUT)
                                                unsigned char i;
                                                unsigned char len;
                                                D12_ReadLastTransactionStatus(2);                /* Clear interrupt flag */
                                                len = D12_ReadEndpoint(2, GenEpBuf, sizeof(GenEpBuf));
                                                if(len != 0)
                                                        memcpy(paddr, GenEpBuf, len);
                                                        paddr += len;
                                                        if(bGetlen == 0 && (int)paddr >= (int)addr)
        length = *((unsigned int *)(addr-4));
        Uart_Printf("\r\nDownloading, size = %d(0x%x)... \r\n", length, length);
        bGetlen = 1;
                                                        if((int)paddr >= (int)addr + length)
        Uart_Printf("Download complete\r\n");
        return;
                                                        Uart_Printf("\rpaddr = 0x%08x, addr = 0x%08x", paddr, addr);
                                                        bEPPflags.bits.ep1_rxdone = 1;
                                        i_st &= ~D12_INT_ENDP1OUT;
                                if(i_st & D12_INT_ENDP2IN)
                                        main_txdone();
                                        i_st &= ~D12_INT_ENDP2IN;
                                if(i_st & D12_INT_ENDP2OUT)
                                        main_rxdone();
                                        i_st &= ~D12_INT_ENDP2OUT;
                                if(bEPPflags.bits.ep1_rxdone)
                                if (bEPPflags.bits.bus_reset) {
                                        DISABLE;
                                        bEPPflags.bits.bus_reset = 0;
                                        ENABLE;
                                } // if bus reset
                                if (bEPPflags.bits.suspend) {
                                        DISABLE;
                                        bEPPflags.bits.suspend= 0;
                                        ENABLE;
                                        suspend_change();
                                } // if suspend change
                                if (bEPPflags.bits.setup_packet){
                                        DISABLE;
                                        bEPPflags.bits.setup_packet = 0;
                                        ENABLE;
                                        control_handler();
                                } // if setup_packet
                                if(bEPPflags.bits.setup_dma) {
                                        DISABLE;
                                        bEPPflags.bits.setup_dma = 0;
                                        ENABLE;
                                        //setup_dma();
                                } // if setup_dma
好的好的,是啊,基础太差了,谢谢了  详情 回复 发表于 2009-7-29 20:01
87
这是C的基本语法,定义了一个指针变量paddr,这个指针变量指向unsigned char类型的数据。然后给它赋值为addr-4,(unsigned char *)是做了一个强制类型转换,使等号2端是同一类型。。。。。。
还是要把基础打好呀。。。
90
好的好的,是啊,基础太差了,谢谢了
