100分急求大虾们看下marvell 8686 sdio wifi module在wince6.0 r3 的驱动问题
调试信息如下:哪位大虾指点下呀。急!在线等呀!大家帮忙看下红线的几个地方是怎么回事呀?
CESDHCBase::SetInterface: Setting for 1 bit mode
CESDHCBase::SetInterface: PROCTL value = 0x7000029
SDSetCardInterfaceForSlot - HC ClockRate differs desired setting: desired: 100000 Hz, Actual : 98958 Hz
SDBusDriver: Device Power Range:0x00FF8000 matches HC desired power: 0x00040000
SDBusDriver: Setting slot 0 power to 0x00040000
SDBusDriver: Power Set, checking card in slot 0, MaxRetries: 1000, Time: 2000 MS, Interval: 2 MS
SDBusDriver: Card in slot 0 ready
CSDDevice: Getting RCA from SD card in slot 0 ....
CSDDevice: Got RCA (0x0001) from SD card in slot 0
CSDDevice:Card in slot 0 is now selected
SDBusDriver: SDIO Card Function 0, CCCR 0x00 , Card Caps: 0x03, Spec Ver: 0
SDBusDriver: SDIO Card Function 1, CCCR 0x00 , Card Caps: 0x03, Spec Ver: 0
SDBusDriver: Function 1 Power Draw:
OpMinPower 0 mA
OpAvePower 0 mA
PB Debugger Loaded 'FLC-WF.DLL', no matching symbolic information found.
OpMaxPower 0 mA
SpAvePower33 0 mA
SpAvePower33 0 mA
HpAvePower33 0 mA
HpMaxPower33 0 mA
LpAvePower33 0 mA
LpMaxPower33 0 mA
SDBusDriver: Device 0xD898E780 , Function String: Device of Class Type: 7
SDBusDriver: Common Product String: Marvell
SDBusDriver: built custom SDIO path: \Drivers\SDCARD\ClientDrivers\Custom\MANF-02DF-CARDID-9103
SDBusDriver: Interface for slot 0 , Mode :1, Clock:25000000
CESDHCBase::SetInterface: Setting for 4 bit mode
CESDHCBase::SetInterface: PROCTL value = 0x700002B
SDSetCardInterfaceForSlot - HC ClockRate differs desired setting: desired: 25000000 Hz, Actual : 23750000 Hz
HandleAddDevice: LoadDevice type = 0, slot 0HandleAddDevice: LoadDevice type = 3, slot 0SDBusDriver: built custom SDIO path: \Drivers\SDCARD\ClientDrivers\Custom\MANF-02DF-CARDID-9103-FUNC-1
DEVICE!RegReadActivationValues RegQueryValueEx(\Drivers\SDCARD\ClientDrivers\Custom\MANF-02DF-CARDID-9103-FUNC-1\BusPrefix) returned 2
OSAXST1: >>> Loading Module 'flc-wf.dll' (0x8859609C) at address 0xC15A0000-0xC15CE000 in Process 'NK.EXE' (0x84EFBAA0)
sdio8686: DLL_PROCESS_ATTACH
+NDL_Init
-NDL_Init
DeviceFolder::LoadDevice(\Drivers\SDCARD\ClientDrivers\Custom\MANF-02DF-CARDID-9103-FUNC-1) last 1212 Ticks+LoadMiniport
Miniport Name [flc-wf]
==>NdisInitializeWrapper
<==NdisInitializeWrapper
==>NdisMRegisterMiniport: NdisWrapperHandle D8980E20
==>ndisRegisterMiniportDriver: NdisWrapperHandle D8980E20
<==ndisRegisterMiniportDriver: MiniBlock D8980E80
NdisMRegisterMiniport: MiniBlock D8980E80
<==NdisMRegisterMiniport: MiniBlock D8980E80, Status 0
==>NdisReadConfiguration
Keyword: PnPCapabilities
<==NdisReadConfiguration
Keyword: [NOTIFY] HandleSystemEvent 7 /ADD NDL1:
SlotNumber
Keyword: DeviceNumber
Keyword: FunctionNumber
NDIS:: SlotNumber calculated: [0x0]
Keyword: RemoteBootCard
Keyword: RequiresMediaStatePoll
Keyword: SysIntr
Keyword: NdisDriverVerifyFlags
ndisMInitializeAdapter: Miniport D898AF48, ==>ndisQueueMiniportOnDriver: Miniport D898AF48, MiniBlock D8980E80
<==ndisQueueMiniportOnDriver: Miniport D898AF48, MiniBlock D8980E80, rc 1
<==NdisOpenConfiguration: WrapperConfigurationContext D4D3FB28
==>NdisReadNetworkAddress: ConfigurationHandle D8981FE0
Keyword: NetworkAddress
<==NdisReadNetworkAddress: ConfigurationHandle D8981FE0
Keyword: AdhocWiFiDataRate
==>NdisCloseConfiguration: ConfigurationHandle D8981FE0
<==NdisCloseConfiguration: ConfigurationHandle D8981FE0
!ERROR: Calling EnterCriticalSection on a CS (d8b21548) that is not initialized! <==NdisOpenConfiguration: WrapperConfigurationContext D4D3FB28
Keyword: ActivePath
==>NdisCloseConfiguration: ConfigurationHandle D8B94A40
<==NdisCloseConfiguration: ConfigurationHandle D8B94A40
SDGetClientFunctions: +Init
SDGetClientFunctions: Invalid parameter
SDGetClientFunctions: -Init
==>NdisTerminateWrapper: NdisWrapperHandle D8980E20
<==NdisTerminateWrapper
NDIS: Freeing unallocated memory
Unknown: DEBUGCHK failed in file C:\ymzki\private\winceos\comm\ndis51\sys\.\debug.c at line 391
==>NdisMDeregisterAdapterShutdownHandler: Miniport D898AF48
<==NdisMDeregisterAdapterShutdownHandler: Miniport D898AF48
***NDIS*** (b, 2091) INIT FAILURE: Dequeueing the miniport from the driver block.
==>ndisDeQueueMiniportOnDriver, Miniport D898AF48, MiniBlock D8980E80
<==ndisDeQueueMiniportOnDriver: Miniport D898AF48, MiniBlock D8980E80
***NDIS*** (b, 2118) INIT FAILURE: Dereferencing the miniport block.
ndisDereferenceMiniport:Miniport D898AF48, Ref = 0
==>ndisMUnload: DriverObject D8980DA0
ndisMUnload: MiniBlock D8980E80
<==ndisMUnload: DriverObject D8980DA0, MiniBlock D8980E80
IOCTL_HAL_RTC_SYNC Fail, error 50
