2364|3
82
小问题:make不通过是什么问题? [复制链接]
是什么问题呢?
[root@localhost qt-serial]# make
gcc -c -pipe -Wall -W -O2 -fno-default-inline -DNO_DEBUG -I/working/qt/qt-2.3.7/include -o gps.o gps.c
cc1: warning: ignoring command line option '-fno-default-inline'
cc1: warning: (it is valid for C++ but not the selected language)
gps.c: In function `set_speed':
gps.c:28: warning: comparison between signed and unsigned
gps.c:140:1: unterminated comment
make: *** [gps.o] Error 1
贴 gps.c:140:1: unterminated comment 前后的语句出来   详情 回复 发表于 2009-6-22 10:17
67
make的信息是全部的吗?
67
全部信息
前后的语句出来
