1397|0
1700
msp430G2231 ADC10配置 [复制链接]
学习MCU外设操作首先要知道相应外设的寄存器有哪些和什么作用:
ADC10 Registers
ADC10 input enable register 0 ADC10AE0 Read/write 04Ah Reset with POR
ADC10 input enable register 1 ADC10AE1 Read/write 04Bh Reset with POR
ADC10 control register 0 ADC10CTL0 Read/write 01B0h Reset with POR
ADC10 control register 1 ADC10CTL1 Read/write 01B2h Reset with POR
ADC10 memory ADC10MEM Read 01B4h Unchanged
ADC10 data transfer control register 0 ADC10DTC0 Read/write 048h Reset with POR
ADC10 data transfer control register 1 ADC10DTC1 Read/write 049h Reset with POR
ADC10 data transfer start address ADC10SA Read/write 01BCh 0200h with POR
至于这些外设的工具配置,我就不截图列出来了,上传一份网友整理的ADC外设说明见附件
分享一份ADC的源码:配置P1.1为ADC功能,主要功能是实现3.3V时LED1亮,否则灭。
#include "msp430g2231.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  ADC10CTL0 = ADC10SHT_2 + ADC10ON + ADC10IE; // 转换时钟选择 ADC10ON(打开ADC10), interrupt enabled(使能中断)
  ADC10CTL1 = INCH_1;                       // input A1(选择输入通道A1,对应P1.1口)
  ADC10AE0 |= BIT1;                         // PA.1 ADC option select (使能P1.1模拟输入)
  P1DIR |= BIT0;                            // Set P1.0 to output direction (P1.0为输出模式)
  P1OUT&=~BIT0;
  for (;;)
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start (ADC10开始采样转换)
    __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit (开总中断,低功耗模式)
    /*******翻转P1.0口状态******/
    if (ADC10MEM < 0x3FF)
      P1OUT &= ~BIT0;                       // Clear P1.0 LED off
    else
      P1OUT |= BIT0;                        // Set P1.0 LED on
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
  __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
使用特权更多操作
