2921|4
63
关于SD卡的读取问题 DE2 [复制链接]
这是SD_card.h文件的内容:
#ifndef   __SD_Card_H__
#define   __SD_Card_H__
//  SD Card Set I/O Direction
#define SD_CMD_IN   IOWR(SD_CMD_BASE, 1, 0)
#define SD_CMD_OUT  IOWR(SD_CMD_BASE, 1, 1)
#define SD_DAT_IN   IOWR(SD_DAT_BASE, 1, 0)
#define SD_DAT_OUT  IOWR(SD_DAT_BASE, 1, 1)
//  SD Card Output High/Low
#define SD_CMD_LOW  IOWR(SD_CMD_BASE, 0, 0)
#define SD_CMD_HIGH IOWR(SD_CMD_BASE, 0, 1)
#define SD_DAT_LOW  IOWR(SD_DAT_BASE, 0, 0)
#define SD_DAT_HIGH IOWR(SD_DAT_BASE, 0, 1)
#define SD_CLK_LOW  IOWR(SD_CLK_BASE, 0, 0)
#define SD_CLK_HIGH IOWR(SD_CLK_BASE, 0, 1)
//  SD Card Input Read
#define SD_TEST_CMD IORD(SD_CMD_BASE, 0)
#define SD_TEST_DAT IORD(SD_DAT_BASE, 0)
#define BYTE    unsigned char
#define UINT16  unsigned int
#define UINT32  unsigned long
void Ncr(void);
void Ncc(void);
BYTE response_R(BYTE);
BYTE send_cmd(BYTE *);
BYTE SD_read_lba(BYTE *,UINT32,UINT32);
BYTE SD_card_init(void);
BYTE read_status;
BYTE response_buffer[20];
BYTE RCA[2];
BYTE cmd_buffer[5];
const BYTE cmd0[5]   = {0x40,0x00,0x00,0x00,0x00};
const BYTE cmd55[5]  = {0x77,0x00,0x00,0x00,0x00};
const BYTE cmd2[5]   = {0x42,0x00,0x00,0x00,0x00};
const BYTE cmd3[5]   = {0x43,0x00,0x00,0x00,0x00};
const BYTE cmd7[5]   = {0x47,0x00,0x00,0x00,0x00};
const BYTE cmd9[5]   = {0x49,0x00,0x00,0x00,0x00};
const BYTE cmd16[5]  = {0x50,0x00,0x00,0x02,0x00};
const BYTE cmd17[5]  = {0x51,0x00,0x00,0x00,0x00};
const BYTE acmd6[5]  = {0x46,0x00,0x00,0x00,0x02};
const BYTE acmd41[5] = {0x69,0x0f,0xf0,0x00,0x00};
const BYTE acmd51[5] = {0x73,0x00,0x00,0x00,0x00};
void Ncr(void)
  SD_CMD_IN;
  SD_CLK_LOW;
  SD_CLK_HIGH;
  SD_CLK_LOW;
  SD_CLK_HIGH;
void Ncc(void)
  int i;
  for(i=0;i<8;i++)
    SD_CLK_LOW;
    SD_CLK_HIGH;
    BYTE x,y;
    SD_CMD_OUT;
    SD_DAT_IN;
    SD_CLK_HIGH;
    SD_CMD_HIGH;
    SD_DAT_LOW;
    read_status=0;
    for(x=0;x<40;x++)
    Ncr();
    for(x=0;x<5;x++)
    cmd_buffer[x]=cmd0[x];
    y = send_cmd(cmd_buffer);
    do
      for(x=0;x<40;x++);
      Ncc();
      for(x=0;x<5;x++)
      cmd_buffer[x]=cmd55[x];
      Ncr();
      if(response_R(1)>1) //response too long or crc error
      return 1;
      Ncc();
      for(x=0;x<5;x++)
      cmd_buffer[x]=acmd41[x];
      Ncr();
    } while(response_R(3)==1);
    Ncc();
    for(x=0;x<5;x++)
    cmd_buffer[x]=cmd2[x];
    Ncr();
    if(response_R(2)>1)
    return 1;
    Ncc();
    for(x=0;x<5;x++)
    cmd_buffer[x]=cmd3[x];
    Ncr();
    if(response_R(6)>1)
    return 1;
    RCA[0]=response_buffer[1];
    RCA[1]=response_buffer[2];
    Ncc();
    for(x=0;x<5;x++)
    cmd_buffer[x]=cmd9[x];
    cmd_buffer[1] = RCA[0];
    cmd_buffer[2] = RCA[1];
    Ncr();
    if(response_R(2)>1)
    return 1;
    Ncc();
    for(x=0;x<5;x++)
    cmd_buffer[x]=cmd7[x];
    Ncr();
    if(response_R(1)>1)
    return 1;
    Ncc();
    for(x=0;x<5;x++)
    cmd_buffer[x]=cmd16[x];
    Ncr();
    if(response_R(1)>1)
    return 1;
    read_status =1; //sd card ready
    return 0;
BYTE SD_read_lba(BYTE *buff,UINT32 lba,UINT32 seccnt)
  BYTE c=0;
  UINT32  i,j;
  lba+=101;
  for(j=0;j   {
      Ncc();
      cmd_buffer[0] = cmd17[0];
      cmd_buffer[1] = (lba>>15)&0xff;
      cmd_buffer[2] = (lba>>7)&0xff;
      cmd_buffer[3] = (lba<<1)&0xff;
      cmd_buffer[4] = 0;
      lba++;
      Ncr();
    while(1)
      SD_CLK_LOW;
      SD_CLK_HIGH;
      if(!(SD_TEST_DAT))
      break;
    for(i=0;i<512;i++)
      BYTE j;
      for(j=0;j<8;j++)
        SD_CLK_LOW;
        SD_CLK_HIGH;
        c <<= 1;
        if(SD_TEST_DAT)
        c |= 0x01;
      *buff=c;
      buff++;
    for(i=0; i<16; i++)
        SD_CLK_LOW;
        SD_CLK_HIGH;
  read_status = 1;  //SD data next in
  return 0;
BYTE response_R(BYTE s)
  BYTE a=0,b=0,c=0,r=0,crc=0;
  BYTE i,j=6,k;
  while(1)
    SD_CLK_LOW;
    SD_CLK_HIGH;
    if(!(SD_TEST_CMD))
    break;
    if(crc++ >100)
    return 2;
  crc =0;
  if(s == 2)
  j = 17;
  for(k=0; k   {
    c = 0;
    if(k > 0)                      //for crc culcar
    b = response_buffer[k-1];
    for(i=0; i<8; i++)
      SD_CLK_LOW;
      if(a > 0)
      c <<= 1;
      else
      i++;
      a++;
      SD_CLK_HIGH;
      if(SD_TEST_CMD)
      c |= 0x01;
      if(k > 0)
        crc <<= 1;
        if((crc ^ b) & 0x80)
        crc ^= 0x09;
        b <<= 1;
        crc &= 0x7f;
    if(s==3)
      if( k==1 &&(!(c&0x80)))
      r=1;
    response_buffer[k] = c;
  if(s==1 || s==6)
    if(c != ((crc<<1)+1))
    r=2;
  return r;
BYTE send_cmd(BYTE *in)
  int i,j;
  BYTE b,crc=0;
  SD_CMD_OUT;
  for(i=0; i < 5; i++)
    b = in;
    for(j=0; j<8; j++)
      SD_CLK_LOW;
      if(b&0x80)
      SD_CMD_HIGH;
      else
      SD_CMD_LOW;
      crc <<= 1;
      SD_CLK_HIGH;
      crc ^= 0x09;
      b<<=1;
    crc &= 0x7f;
  crc =((crc<<1)|0x01);
  b = crc;
  for(j=0; j<8; j++)
    SD_CLK_LOW;
    if(crc&0x80)
    SD_CMD_HIGH;
    else
    SD_CMD_LOW;
    SD_CLK_HIGH;
    crc<<=1;
  return b;
#endif
下面是主程序:
#include "basic_io.H"
#include "SD_Card.H"
#include "altera_avalon_pio_regs.H"
int main(void)
    IOWR_ALTERA_AVALON_PIO_DATA(PIO_LED_BASE,1);
    UINT16 i=0,Tmp1=0;
    UINT32 j=720;
    BYTE Buffer[512]={0};
    usleep(500000);
   //下面是SD卡播放wav音频的主要程序:
    while(1)
        SD_read_lba(Buffer,j,1);
        while(i<512)
            if(!IORD(AUDIO_0_BASE,0))
                Tmp1 = (Buffer[i+1]<<8)|Buffer;
                IOWR(AUDIO_0_BASE,0,Tmp1);
                i+=2;
        j++;
        i=0;
为什么一执行到SD_read_lba(Buffer,j,1);这句就不出来了,好像陷入死循环了,而且Buffer里面的值全是0,并没有读出SD卡中的内容.
各位大侠帮帮忙,看一下!!!
老大,在这儿撞见你了。。。不容易呀   哈哈哈哈  详情 回复 发表于 2010-4-10 16:50
没仔细看,SD_card_init执行了吗,是否成功
79
引用 1 楼 seemknow 的回复:
SD_card_init已经执行了,初始化成功,问题出在SD_read_lba(Buffer,j,1);出不来,调试了一下,在
     while(1)
      SD_CLK_LOW;      //送时钟给SD卡,准备接受DAT上面的数据
      SD_CLK_HIGH;
      if(!(SD_TEST_DAT))//SD卡的DAT线也是以0为startbit
      break;
陷入这个循环,没出来。if(!(SD_TEST_DAT))//SD卡的DAT线也是以0为startbit   这句不太明白.
是DE2示例程序吧?
