2686|3
66
安装QTOPIA的问题 [复制链接]
make: [clean] 错误 123 (忽略)
cd tutorial; make clean
make[1]: Entering directory `/utulinux/qtopia-1.7-tp/qt-embedded-2.3.7/tutorial'
Some requirements (standard configuration) are not met.
Skipped.
make[1]: Leaving directory `/utulinux/qtopia-1.7-tp/qt-embedded-2.3.7/tutorial'
cd examples; make clean
make[1]: Entering directory `/utulinux/qtopia-1.7-tp/qt-embedded-2.3.7/examples'
Skipped.
make[1]: Leaving directory `/utulinux/qtopia-1.7-tp/qt-embedded-2.3.7/examples'
cd tools; make clean
make[1]: Entering directory `/utulinux/qtopia-1.7-tp/qt-embedded-2.3.7/tools'
make[1]: Nothing to be done for `clean'.
make[1]: Leaving directory `/utulinux/qtopia-1.7-tp/qt-embedded-2.3.7/tools'
make[1]: *** [.obj/linux-ipaq-g++//calendar.o] 错误 1
make[1]: Leaving directory `/utulinux/qtopia-1.7-tp/qtopia-free-1.7.0/src/libraries/qtopia'
make: *** [libraries/qtopia] 错误 2
FEDORA和REDFLAG都出现这个问题
N久没解决了
检查一下 各个目录下的 pro文件 重新 configure 一下看看  详情 回复 发表于 2009-5-31 09:55
没人回答啊,再加50分
88
来人啊
64
检查一下 各个目录下的 pro文件
重新 configure 一下看看
