41
sbit   b0 =P2^3;
sbit   b1 =P2^4;
sbit   b2 =P2^5;
sbit   b3 =P0^4;
sbit   b4 =P0^5;
sbit   b5 =P0^3;
sbit   b6 =P0^2;
uchar  get_p2(void)
        uchar  ss=0;
        if (b6==0)
                ss|=0x40;
        if (b5==0)
                ss|=0x20;
        if (b4==0)
                ss|=0x10;
        if (b3==0)
                ss|=0x08;
        if (b2==0)
                ss|=0x04;
        if (b1==0)
                ss|=0x02;
        if (b0==0)
                ss|=0x01;
        return ss;
     两者竟然不一样, 前者才可以,,后者虽不报错,但不能读端口。
#define    pin0    P2^3
#define    pin1    P2^4
#define    pin2    P2^5
#define    pin3    P0^4
#define    pin4    P0^5
#define    pin5    P0^3
#define    pin6    P0^2
#define low_data  ((pin0?0:1)|(pin1?0:0x02)|(pin2?0:0x04)|(pin3?0:0x08)|(pin4?0:0x10)|(pin5?0:0x20)|(pin6?0:0x40)&0x7F)
75
42
不能用#define,必须用sbit....
sbit pin0=P2^3
sbit pin1=P2^4
sbit pin2=P2^5
sbit pin3=P0^4
sbit pin4=P0^5
sbit pin5=P0^3
sbit pin6=P0^2
这样该可以.
43
引用 41 楼 great_bug 的回复:
sbit pin0=P2^3
sbit pin1=P2^4
sbit pin2=P2^5
sbit pin3=P0^4
sbit pin4=P0^5
sbit pin5=P0^3
sbit pin6=P0^2
#define low_data ((pin0?0:1)|(pin1?0:0x02)|(p……
  果然可以,刚才试了
