3759|9
OALPAtoVA函数问题 [复制链接]
void main(void)
        unsigned long i = 0;
        unsigned long dly;
        volatile S3C2410X_IOPORT_REG *s2410IOP = (S3C2410X_IOPORT_REG *)OALPAtoVA(S3C2410X_BASE_REG_PA_IOPORT, FALSE);
        //volatile S3C2410X_IOPORT_REG *s2410IOP = 0x91600000;
        s2410IOP->GPBDAT=0;
        while (1)
                for(dly = 50000; dly > 0; dly--)
                s2410IOP->GPBDAT = (~(i<<5));                 // 根据i的值,点亮LED1-4
                if(++i == 16)
                        i = 0;
    // Clear LEDs.
    OEMWriteDebugLED(0, 0xf);
    // Common boot loader (blcommon) main routine.
    BootloaderMain();
    // Should never get here.
    SpinForever();
我在MIAN中做了一个死循环点LED
        volatile S3C2410X_IOPORT_REG *s2410IOP = (S3C2410X_IOPORT_REG *)OALPAtoVA(S3C2410X_BASE_REG_PA_IOPORT, FALSE);   由于前面开了MMU了。使用这句LED不会闪,
        volatile S3C2410X_IOPORT_REG *s2410IOP = 0x91600000; 使用这句LED就可以闪烁了。这个是什么问题呢???
我怀疑是OALPAtoVA没启作用,是不是呢?
BIB文件
TARGETNAME=eboot
TARGETTYPE=PROGRAM
RELEASETYPE=PLATFORM
EXEENTRY=StartUp
SYNCHRONIZE_DRAIN=1
WINCECPU=1
NOMIPS16CODE=1
INCLUDES=$(INCLUDES);$(_PUBLICROOT)\common\oak\drivers\block\msflashfmd\inc
ADEFINES=-pd "_TGTCPU SETS \"$(_TGTCPU)\"" $(ADEFINES)
CDEFINES= $(CDEFINES) -DPPSH_PROTOCOL_NOTIMEOUT -DCOREDLL
LDEFINES=-subsystem:native /DEBUG /DEBUGTYPE:CV /FIXED:NO
NOLIBC=1
TARGETLIBS= \
    $(_PLATCOMMONLIB)\$(_CPUDEPPATH)\oal_cache_arm920t.lib      \
    $(_TARGETPLATROOT)\lib\$(_CPUDEPPATH)\oal_rtc_devemu.lib    \
    $(_PLATCOMMONLIB)\$(_CPUINDPATH)\oal_kitl.lib               \
    $(_PLATCOMMONLIB)\$(_CPUINDPATH)\oal_log.lib                \
    $(_PLATCOMMONLIB)\$(_CPUINDPATH)\oal_blnk.lib               \
    $(_PLATCOMMONLIB)\$(_CPUINDPATH)\oal_blcommon.lib           \
    $(_PLATCOMMONLIB)\$(_CPUINDPATH)\oal_blmemory_arm.lib            \
    $(_COMMONOAKROOT)\lib\$(_CPUDEPPATH)\eboot.lib              \
    $(_COMMONOAKROOT)\lib\$(_CPUINDPATH)\cs8900dbg.lib          \
    $(_COMMONOAKROOT)\lib\$(_CPUINDPATH)\ne2kdbg.lib            \
    $(_COMMONOAKROOT)\lib\$(_CPUINDPATH)\ddk_io.lib             \
    $(_COMMONOAKROOT)\lib\$(_CPUINDPATH)\gsnull.lib             \
    $(_TARGETPLATROOT)\lib\$(_CPUINDPATH)\smflashk_lib.lib      \
    $(_TARGETPLATROOT)\lib\$(_CPUINDPATH)\amdnork.lib           \
    $(_COMMONOAKROOT)\lib\$(_CPUINDPATH)\fulllibc.lib
SOURCES= \
    startup.s   \
    util.s      \
    main.c      \
    debug.c     \
    ether.c     \
    flash.c     \
    nand.c      \
    name.c
WINCETARGETFILES=BootImage
找到原因了。是2410上移植到2440上的,2410头文件少定义了一些寄存器,所以导致转换后的地址不正确。  详情 回复 发表于 2009-10-9 21:33
OALPAtoVA这个函数是根据oem_addresstable这个映射表进行转换的,看这个表有什么问题没!或者你直接跟踪下找找。
在而eboot中我刚使用过,很好啊,没有什么问题。
63
引用 1 楼 dot_line 的回复:
这个表没问题,最主要是用那个函数转出来的LED不会闪,我直接写对应表的地址写上去,LED就会闪。
在那个死循环里面。
引用 2 楼 gooogleman 的回复:
能借个2440的EBOOT参考参考吗?目前这个问题是一个,还有一个问题就是时钟我都设置不来。谢谢。
一般这个问题
1:oalpatova 有没有使用uncache
2;mmu有没有开启;
3;延时是不是太短,快得让人看不到灯闪了
63
查查你OALPAtoVA的返回是多少,应该也是0x91600000,否则就要跟踪进去瞧瞧。io memory都会有两个静态映射,看看你返回的是哪个。
目前我准备先开串口,但是时钟一直设置不对,我是2440 12MHz的晶振,大家一般是怎么设置的。
82
最好去看看那个函数体,记得只是CE6是系统给了这个函数吧。不过也能看到这个函数,eboot中药用uncahe地址,你也可以直接把你转化的地址和0x91600000比较一下,我感觉你这样转可能是转成了cahe地址了
他妈的天使 该用户已被删除
提示: 作者被禁止或删除 内容自动屏蔽
