1760|0
1704
基于msp430的点阵显示设计 [复制链接]
#include<msp430.h>
const unsigned char  tab[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
const unsigned char  digittab[10][8]={   //字模取模方式 阴码 逆向 逐列式
{0x7C,0x55,0x5F,0x45,0x5F,0x55,0x7C,0x00},/*"西",0*/
{0x16,0x12,0xB2,0x5B,0xB6,0x12,0x12,0x16},/*"安",1*/
{0x7C,0x54,0x7F,0x54,0x7C,0xFE,0x2A,0x3E},/*"邮",2*/
{0x00,0x3E,0x2A,0xFF,0xAA,0xBE,0xC0,0x00},/*"电",3*/
{0x44,0x24,0x14,0x0F,0x14,0x24,0x44,0x00},/*"大",4*/
{0x06,0x23,0xAA,0xAB,0xFA,0x23,0x22,0x06},/*"学",5*/
{0x00,0x00,0x3E,0x49,0x49,0x32,0x00,0x00},/*"6",6*/
{0x00,0x00,0x03,0x71,0x09,0x07,0x00,0x00},/*"7",7*/
{0x00,0x00,0x36,0x49,0x49,0x36,0x00,0x00},/*"8",8*/
{0x00,0x00,0x26,0x49,0x49,0x3E,0x00,0x00},/*"9",9*/
unsigned int timecount;
unsigned char cnta;
unsigned char cntb;
#define SD_H      P1OUT|=BIT4;        //串行数据输入
#define SD_L      P1OUT&=~BIT4;
#define ST_H    P1OUT|=BIT5;        //存储寄存器时钟输入
#define ST_L    P1OUT&=~BIT5;
#define SH_H    P1OUT|=BIT6;   //移位寄存器时钟输入
#define SH_L    P1OUT&=~BIT6;
void Ser_IN(unsigned char Data)
        unsigned char i;
        for(i=0; i < 8; i++)
                SH_L;                        //clock_MAX=100MHz
                IF(Data&0x80)
                    SD_H;
                else
                    SD_L;
                Data <<= 1;
                SH_H;
void Par_OUT(void)
        ST_L;
        ST_H;
void sysclock()
   TACTL=TASSEL0+TACLR;
   CCTL0=CCIE;
   CCR0=2000;
   TACTL|=MC0;
   _EINT();
   //LPM0;
void main()
    WDTCTL=WDTPW+WDTHOLD;
    P1SEL&=~(BIT4+BIT5+BIT6);
    P1DIR|=BIT4+BIT5+BIT6;
    sysclock();
    while(1)
        Ser_IN(tab[cnta]);//8X8点阵列扫描
        Ser_IN(digittab[cntb][cnta]);//8X8点阵行送扫描数据
        Par_OUT();//74HC595输出显示
        cnta++;
        if(cnta==8)
        cnta=0;
#pragma vector=TIMER0_A0_VECTOR
__interrupt void timeA0(void)
       // Ser_IN(tab[cnta]);//8X8点阵列扫描
        //Ser_IN(digittab[cntb][cnta]);//8X8点阵行送扫描数据
        //Par_OUT();//74HC595输出显示
        //cnta++;
   timecount++;
  if(timecount==1)
      timecount=0;
      cntb++;
    if(cntb==6)
          cntb=0;
