4026|7
85
wince eboot之flash管理问题 [复制链接]
我使用S3C2410芯片和K9F1208的FLASH。现在我的EBOOT可以实现直接下载NK.BIN并在RAM中启动,但是无法在FLASH中启动。
超级终端显示如下:
TFTP: Desktop losing ACK, block number = 18570, Ack again
TFTP: Desktop losing ACK, block number = 32099, Ack again
rom_offset=0x0.
ROMHDR at Address 8C300044h
::OEMLaunch, ImageStart:0x8C300000, ImageLength:0x1189134, LaunchAddr:0x8C301000
EbootWaitForHostConenct
Got EDBG_CMD_JUMPIMG
Got EDBG_CMD_CONFIG, flags:0x00000000
KitlTransport: 0x1
OEMLaunch: (IMAGE_TYPE_RAMIMAGE|IMAGE_TYPE_BINFS)
+WriteRegionsToBootMedia: ImageStart: 0x8C300000, ImageLength: 0x1189134, Launch
Addr:0x8C301000
INFO: OEMLaunch: Found chain extenstion: '' @ 0x8C300000
Writing single region/multi-region update, dwBINFSPartLength: 18387252
IsValidMBR: MBR sector = 0xFFFFFFFF
OpenPartition: Invalid MBR.  Formatting flash.
Enter LowLevelFormat [0x0, 0x7F].
Erasing flash block(s) [0x0, 0x7F] (please wait): EraseBlocks: found a bad block
(0x0) - skipping...
EraseBlocks: found a bad block (0x1) - skipping...
EraseBlocks: found a bad block (0x2) - skipping...
EraseBlocks: found a bad block (0x7F) - skipping...
Done.
BP_LowLevelFormat: no good blocks
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x101F.
CreatePartition: sectors [0x1F020, 0x8C60] requested are out of range or taken b
y another partition
ERROR: WriteRegionsToBootMedia: Failed to open/create BINFS partition.
WARNING: OEMLaunch: Failed to store BinFS regions to boot media.
另外eboot格式化FLASH功能也不好使
大家帮帮忙,看看该如何解决
我解决了,谢谢大家是 loader.h里面有个参数错了   详情 回复 发表于 2009-5-30 12:14
65
up
看样子,所有的Block都会被提示bad了。
先检查你的eboot里的flash部分的程序。重点是EraseBlock的,如果找不到问题就贴代码。
75
全部都被标记为了坏块。。。还怎么下载呢
87
全部被标记为坏块,估计驱动有问题
主引导程序MBR(Master Boot Record)错误。
检测MBR的有效性。通过函数IsValidMBR()实现。
检测MBR的有效性,首先要知道MBR保存在哪里,前面说过NANDFLASH的第0 BLOCK,第1 Sector为主引导扇区,也就是MBR,但是NAND如果被当作启动芯片,○地址一般被BOOTLOADER代码占据,MBR只有放在后面的BLOCK中。所以我把第0 个BLOCK放NBOOT,第1个BLOCK放TOC,第2个BLOCK放EBOOT,第3个BLOCK保留,第4个BLOCK就放MBR。
  1. static BOOL IsValidMBR()
  2. {
  3.     // Check to see if the MBR is valid
  4.     // MBR block is always located at logical sector 0
  5.     g_dwMBRSectorNum = GetMBRSectorNum();
  6.     RETAILMSG (1, (TEXT("IsValidMBR: MBR sector = 0x%x\r\n"), g_dwMBRSectorNum));
  7.
  8.     if ((g_dwMBRSectorNum == INVALID_ADDR) || !FMD_ReadSector (g_dwMBRSectorNum, g_pbMBRSector, NULL, 1)) {
  9.        RETAILMSG (1, (TEXT("IsValidMBR-----return FALSE-------------------\r\n")));
  10.         return FALSE;
  11.     }
  12.     return ((g_pbMBRSector[0] == 0xE9) &&
  13.          (g_pbMBRSector[1] == 0xfd) &&
  14.          (g_pbMBRSector[2] == 0xff) &&
  15.          (g_pbMBRSector[SECTOR_SIZE_FS-2] == 0x55) &&
  16.          (g_pbMBRSector[SECTOR_SIZE_FS-1] == 0xAA));
  17. }
复制代码
引用 2 楼 shuiyan 的回复:
很同意这种观点,肯定是你的flash 驱动有问题。
我解决了,谢谢大家是
loader.h里面有个参数错了
