3887|0
6828
仿真器Debug错误原因及解决办法 [复制链接]
错误现象:
在使用xds100v3仿真器调试tms320c6747处理器时,出现如下一堆错误。
C674X_0: Power Failure on Target CPU
Error connecting to the target:
(Error -1265 @ 0x0)
Device ID is not recognized or is not supported by driver. Confirm device and debug probe configuration is correct, or update device driver.
(Emulation package 7.0.188.0)
(Error -516 @ 0x0)
The user selected specific frequency failed the scan-path reliability test.
The utility or debugger requested the JTAG controller and cable,
that generate the JTAG clock, to provide a user selected fixed
frequency. The built-in scan-path reliability test has failed.
This indicates that the JTAG controller and its cable cannot
reliably communicate with the target system at that frequency.
IcePick_C_0: Error connecting to the target: (Error -516 @ 0x0) The user selected specific frequency failed the scan-path reliability test. The utility or debugger requested the JTAG controller and cable, that generate the JTAG clock, to provide a user selected fixed frequency. The built-in scan-path reliability test has failed. This indicates that the JTAG controller and its cable cannot reliably communicate with the target system at that frequency. (Emulation package 7.0.188.0)
IcePick_C_0: Error connecting to the target: (Error -1265 @ 0x0) Device ID is not recognized or is not supported by driver. Confirm device and debug probe configuration is correct, or update device driver. (Emulation package 7.0.188.0)
(Error -154 @ 0x0)
One of the FTDI driver functions used to
write data returned bad status or an error.
原因:
查了很多硬件原因和软件原因,都无解。
解决办法:
更换仿真器为几千块的xds560v2,问题解决。
