5423|10
在CE下怎么获取当前的网络类型?? [复制链接]
想通过API程序来获取当前手机连接的网络类型,比如是GPRS,还是edwg,还是3G,还是CDMA等??
谢谢啦
什么时候结贴给分呀  详情 回复 发表于 2009-9-16 13:31
[HKEY_CURRENT_USER\ControlPanel\Phone]
  "Features"=dword:0002B820  // CDMA
  "Features"=dword:0206C7D8  // GSM
直接判别使用的电话卡的类型
24
HRESULT WINAPI ConnMgrQueryDetailedStatus(
  CONNMGR_CONNECTION_DETAILED_STATUS *pStatusBuffer,
  DWORD *pcbBufferSize
dwType==CM_CONNTYPE_CELLULAR
时的dwSubtype
可能的值为:
CM_CONNSUBTYPE_CELLULAR_UNKNOWN
The connection subtype is unknown.
CM_CONNSUBTYPE_CELLULAR_CSD
A CSD cellular connection. This type is treated as a dial-up connection. The CSD subtype is the default connection subtype for cellular connections.
CM_CONNSUBTYPE_CELLULAR_GPRS
A GPRS cellular connection.
CM_CONNSUBTYPE_CELLULAR_1XRTT
A 1xRTT cellular connection.
CM_CONNSUBTYPE_CELLULAR_1XEVDO
A 1xEVDO cellular connection. This connection subtype is treated the same as the CM_CONNSUBTYPE_CELLULAR_1XRTT subtype.
CM_CONNSUBTYPE_CELLULAR_1XEVDV
A 1xEVDV cellular connection. This connection subtype is treated the same as the CM_CONNSUBTYPE_CELLULAR_1XRTT subtype.
CM_CONNSUBTYPE_CELLULAR_EDGE
An EDGE cellular connection. This connection subtype is treated the same as the CM_CONNSUBTYPE_CELLULAR_GPRS subtype.
CM_CONNSUBTYPE_CELLULAR_UMTS
A UMTS cellular connection. This connection subtype is treated the same as the CM_CONNSUBTYPE_CELLULAR_GPRS subtype.
CM_CONNSUBTYPE_CELLULAR_VOICE
A voice cellular connection.
CM_CONNSUBTYPE_CELLULAR_PTT
A Push-To-Talk cellular connection. This is currently not supported.
CM_CONNSUBTYPE_CELLULAR_HSDPA
A High Speed Downlink Packet Access connection.
不好意思,发的是WM的,不是WINCE的。
呵呵,谢谢各位。。
ultrapro,靠这个判断有没有相关的资料和说明啊,你只给了2个值;
91program ,靠电话卡好像判断不出来的,上次测试3G网络的时候,那个拨号网络的标记还不停的变呢。一会G,一会E的。
还有其它的好方法吗??
是WInodws Mobile 么?如果是的话用ConnMgrQueryDetailedStatus。如果不是的话,那我也不知道了
解决,谢谢ultrapro,谢谢各位快过年了还来给我解决问题;
Window CE就是mobile平台上的操作系统啦。。
测试可以了
This function returns detailed information about all existing connections.
系统要求:
OS Versions: Windows CE .NET 4.2 and later.(发现只能CE5.0以上的平台使用;)
Header: Connmgr_status.h.
Link Library: Cellcore.lib.
不懂,学习一下
如果是串口设备的话,可以用相应的com at命令来查
什么时候结贴给分呀
中星联华&ADI明日直播
直播主题:大咖面对面,轻松玩转高速ADC性能测试
直播时间:3月25日(周二)14:00
活动奖励:京东卡、双肩包
